praegune kellaaeg 21.09.2026 06:21:40
12.01.2018 16:22:43
Taas järjekordne Inteli protsessorite turvaprobleem. Probleemseid arvuteid on miljonites. |
Lugege ning otsustage ise.
New Intel Security Vulnerability Discovered, Millions of Laptops Affected
The vulnerability fiasco continues for Intel with new bug
As if the Meltdown and Spectre bugs weren’t enough trouble for Intel already, security researcher Harry Sintonen working for Finnish company F-Secure discovered another vulnerability that potentially affects millions of corporate laptops.
This time, the security bug exists in Intel’s Active Management Technology (AMT) and can be exploited by hackers to take complete control of a vulnerable device “in a matter of seconds,” as the researcher explains.
What’s important to note from the very beginning is that unlike Meltdown and Spectre, a successful exploit of this vulnerability (which doesn’t yet have a name) requires physical access to the device. But this is still a critical flaw, Sintonen points out, as a hacker can compromise a system in less than a minute and then remotely control it by connecting to the same network.
The vulnerability can be exploited even if other security measures are in place, including here a BIOS password, BitLocker, TPM Pin, or a traditional antivirus.
Edasi:
http://news.softpedia.com/news/new-intel-security-vulnerability-discovered-millions-of-laptops-affected-519355.shtml
friik1
12.01.2018 17:59:38
Fake news, AMT on SMB mode-s nii 10kond aastat töötanud...
See rünnak läheb samasse auku, et kui ma saan füüsiliselt masinale ligi, saan rootkiti/keyloggeri/VNC/whatever masinasse panna.
Ja kui AMT pilt üle võtta, siis on see alati ekraanil näha, nii et raske seda ette kujutada...
sa ei või postitada uusi teemasid siia foorumisse sa ei või vastata selle foorumi teemadele sa ei või muuta oma postitusi selles foorumis sa ei või kustutada oma postitusi selles foorumis sa ei või vastata küsitlustele selles foorumis sa ei saa lisada manuseid selles foorumis sa ei või manuseid alla laadida selles foorumis
