uus teema   vasta Raud »  Videokaardid / Monitorid / TV »  AMD Navi arutelu märgi kõik teemad loetuks
mine lehele eelmine  1, 2, 3, 4, 5, 6 ... 200, 201, 202  järgmine
sõnum 27.05.2019 13:13:24 vasta tsitaadiga
londiste, Ilmselt Augustis Hot Chips konverentsil räägitakse sügavuti arhitektuuridest.
Kommentaarid: 89 loe/lisa Kasutajad arvavad:  :: 0 :: 0 :: 79
sõnum 27.05.2019 14:39:50 vasta tsitaadiga
Tomorrow kirjutas:
Vaatame mis perf teeb aga väljakäidud +25% IPC ja 1,9Ghz kõlab paljutõotavalt. Kahju ainult, et 2070 konkurent. Vaja on 2080 Ti konkurenti aga see tuleb alles järgmine aasta thumbs_down.gif . Selleks ajaks on Nvidial juba uued kaardid väljas.
nii. detaile:
https://www.amd.com/en/press-releases/2019-05-26-amd-announces-next-generation-leadership-products-computex-2019-keynote
AMD unveiled RDNA, the next foundational gaming architecture that was designed to drive the future of PC gaming, console, and cloud for years to come. With a new compute unit [10] design, RDNA is expected to deliver incredible performance, power and memory efficiency in a smaller package compared to the previous generation Graphics Core Next (GCN) architecture. It is projected to provide up to 1.25X higher performance-per-clock [11] and up to 1.5X higher performance-per-watt over GCN[12], enabling better gaming performance at lower power and reduced latency.
10. AMD APUs and GPUs based on the Graphics Core Next and RDNA architectures contain GPU Cores comprised of compute units, which are defined as 64 shaders (or stream processors) working together. GD-142
11. Testing done by AMD performance labs 5/23/19, showing a geomean of 1.25x per/clock across 30 different games @ 4K Ultra, 4xAA settings. Performance may vary based on use of latest drivers. RX-327
12. Testing done by AMD performance labs 5/23/19, using the Division 2 @ 25x14 Ultra settings. Performance may vary based on use of latest drivers. RX-325
edit:
https://www.anandtech.com/show/14412/amd-teases-first-navi-gpu-products-rx-5700-series-in-july-25-improved-perf
Lisa Su kirjutas:
And then, when you put that together, both the architecture – the design capability – as well as the process technology, we're seeing 1.5x or higher performance per watt capability on the new Navi products
ehk siis võrdlused peaks olema vs 14nm vega.
samast loost, estimated die size ~275mm².
see peaks olema 10b transistorit, natukene siia-sinna. ehk siis rtx2070 südameks oleva tu106 umbestäpselt samas suurusjärgus.
- londiste
Kommentaarid: 237 loe/lisa Kasutajad arvavad:  :: 0 :: 1 :: 212
sõnum 31.05.2019 09:38:05 vasta tsitaadiga
londiste, Die size väidetavalt isegi väiksem @ ~255mm²
https://wccftech.com/amd-navi-rx-5700-is-only-the-mid-range-brings-rtx-2070-performance-at-half-the-die-size/
See on veidi suurem kui Polaris 10 (RX580) ja veidi väiksem kui TU116 (GTX 1660) aga transistorite arv ja perf on ~445mm² RTX 2060 ja 2070 kandis.
Eks see olegi 7nm vs 12nm eelis.
Viilutaja
Viilutaja
sõnum 31.05.2019 13:54:31 vasta tsitaadiga
Tomorrow kirjutas:
Coreteks oma viimases videos väidab, et RX5700 hind saab olema 399, juhul kui RTX2070 hinnad jäävad prageusele tasemele. Kuid kui Nvidia otsustab vahepeal neid langetada, siis RX5700 tuleb välja 379 usdiga.
Jutt käib siis hetkel sellest Navi kaardist, mis konkreetselt RTX2070 vastane.
Link
11:50 peal hakkab rääkima sellest hinnast, mida allikas andis.
Kommentaarid: 222 loe/lisa Kasutajad arvavad:  :: 0 :: 1 :: 192
sõnum 31.05.2019 14:03:01 vasta tsitaadiga
ehk siis see näidatud navi tuleb tegelikult üldpildis rtx2060 ja rtx2070 vahele nii perfi kui hinna poolest. võimalik, et efektiivsuse arvelt lähemal rtx2070-le ja rtx kaartidest parema perf/$ suhtega.
- londiste
1dumbpcuser
sõnum 03.06.2019 20:00:11 vasta tsitaadiga
Navi 10-based AMD Radeon RX 5700 still has elements of GCN, 'pure' RDNA coming only in 2020
Link
Edit:
AMD lands deal with Samsung, will bring AMD's RDNA graphics to smartphones
https://www.google.com/amp/s/www.techspot.com/amp/news/80347-samsung-bringing-amd-rdna-graphics-smartphones.html
M: AMD Ryzen 5 7600X Box
M: AMD Ryzen™ 9 7900X Desktop Processor
Kommentaarid: 96 loe/lisa Kasutajad arvavad:  :: 1 :: 0 :: 91
sõnum 10.06.2019 10:50:12 vasta tsitaadiga
xbox scarletti jutt räägib hw raytracingust.
- londiste
Viilutaja
Viilutaja
sõnum 10.06.2019 11:25:08 vasta tsitaadiga
londiste kirjutas:
See on tõenäoliselt Navi20'l. Ei usu, et Navi 10'l seda juba sisse pannakse.
sõnum 10.06.2019 11:26:56 vasta tsitaadiga
juba vist käis läbi, aga:
https://www.techpowerup.com/256411/amd-radeon-rx-5700-xt-slide-leaked-picture-and-specs
Viilutaja kirjutas:
londiste kirjutas:
speci järgi on konsoolides navi10.
- londiste
Viilutaja
Viilutaja
sõnum 10.06.2019 11:52:44 vasta tsitaadiga
londiste kirjutas:
Viilutaja kirjutas:
londiste kirjutas:
Ei tundu loogiline, et 2020 lõpus välja tulevale konsoolile läheb sisse praegu välja tulev GPU. Seda enam, et Xbox reklaamis välja eile ka 8K gameplayd (mingi Indie tõenäoliselt ja mitte FPS), enamus rõhku läks 4k 60FPS peale.
Ning osadele mängudele lubati 120FPSi (1080P reso siis).
sõnum 10.06.2019 20:36:29 vasta tsitaadiga
https://twitter.com/SpartanGeekTV/status/1138091993459056640
- londiste
ceemic
24/7@kalal
ceemic
sõnum 11.06.2019 06:37:07 vasta tsitaadiga
RX 5700 - ~380$/€
RX 5700 XT - ~450$/€
Kommentaarid: 418 loe/lisa Kasutajad arvavad:  :: 0 :: 0 :: 321
sõnum 11.06.2019 10:39:29 vasta tsitaadiga
oh sa raisk, numbrid tulid väga tuttavad ette.
kas me saame turing vs navi clock vs clock võrdluse nüüd ?!
36cu, 2304sp, 144 tmu, 64 rops. 448gb/s mälu ka kui nii võtta.
see on täpipealt rtx2070 spec.
edit:
https://www.computerbase.de/2019-06/navi-radeon-rx-5700-xt/
slaidid ütlevad, et jätkuvalt 4 ace. jätkuv gcn pärand?
uus cu disain ja improved cached näevad väga head välja.
miks need reference kaardid sellised sulanud väljanägemisega mõlgiga on, ma muidugi aru ei saa icon_biggrin.gif
- londiste
kuccu
sõnum 11.06.2019 11:40:47 vasta tsitaadiga
Naljahambad juba leidsid seose:
Viilutaja
Viilutaja
sõnum 11.06.2019 11:58:10 vasta tsitaadiga
Hinnad on pasad. Ei vaheta küll oma Vega64 välja...
Optimist
Optimist
sõnum 11.06.2019 13:37:42 vasta tsitaadiga
TSMC 7nm tundub toimetab GPUdega hästi, saab näha kuidas nVidial Samsungi transistoridega läheb
Kommentaarid: 10 loe/lisa Kasutajad arvavad:  :: 0 :: 1 :: 8
Viilutaja
Viilutaja
sõnum 11.06.2019 14:25:53 vasta tsitaadiga
Huvitavaid slaide.
sõnum 11.06.2019 14:31:28 vasta tsitaadiga
design frequency and power improvement on loogiline.
mida nad peavad silmad performance per clock enhancement all? suuremat takti?
aga eelmistega samas kontekstis 7nm process gains?
see performance per area illustreeriv pilt on muidugi marketing enda kastmes icon_biggrin.gif
- londiste
Viilutaja
Viilutaja
sõnum 11.06.2019 14:33:35 vasta tsitaadiga
londiste kirjutas:
See suuruste vahe on küll kahtlane, ei tea nüüd mida ma seal vaatama pean icon_biggrin.gif
Kuid 2x suurema die'ga oleks 80CU'd, mis oleks vist isegi piisav, et RTX2080Ti kinni püüda?
Evil
Hull
Evil
sõnum 11.06.2019 16:34:12 vasta tsitaadiga
RX5700XT on nii kuum kaart, et jahutus on isegi ära sulanud veidi. icon_smile.gif Eriti sitasti disainitud jahutus.
Kommentaarid: 230 loe/lisa Kasutajad arvavad:  :: 0 :: 2 :: 192
Aeg maha 1p
sõnum 11.06.2019 16:38:10 vasta tsitaadiga
Ühtlasi võib sealt välja lugeda vana mustri jätkumise... NVIDIA on ühtlasema perfiga.
Kommentaarid: 194 loe/lisa Kasutajad arvavad:  :: 0 :: 0 :: 180
Vael
sõnum 11.06.2019 16:56:50 vasta tsitaadiga
Kallis on. 2gen hiljem peaks see olema (high) mid range ehk 350.-
RX 2070 600.- msrp-ga näitas halba eeskuju...
sõnum 11.06.2019 17:16:22 vasta tsitaadiga
Vael, 499 != 600
- londiste
heretic666
heretic666
sõnum 11.06.2019 17:54:28 vasta tsitaadiga
Kommentaarid: 70 loe/lisa Kasutajad arvavad:  :: 0 :: 0 :: 68
Vael
sõnum 12.06.2019 06:05:16 vasta tsitaadiga
Mis imevidinad need AMD Anti-lag ja RIS veel on?
https://www.youtube.com/watch?v=uPpdtXFx7gQ
200-250 raha eest oleks kaarti küll olnud: https://www.youtube.com/watch?v=7mJCOSXe_zc&t=806s
nüüd tuleb 2x hinnaga:S Siis jääb juba täiskivi ootama.
uus teema   vasta Raud »  Videokaardid / Monitorid / TV »  AMD Navi arutelu mine lehele eelmine  1, 2, 3, 4, 5, 6 ... 200, 201, 202  järgmine
