praegune kellaaeg 21.09.2026 06:21:38
heretic666
27.10.2017 19:57:59
Google chrome eemaldab Symanteci trust listist |
https://security.googleblog.com/2017/09/chromes-plan-to-distrust-symantec.html
Starting with Chrome 66, Chrome will remove trust in Symantec-issued certificates issued prior to June 1, 2016. Chrome 66 is currently scheduled to be released to Chrome Beta users on March 15, 2018 and to Chrome Stable users around April 17, 2018.
If you are a site operator with a certificate issued by a Symantec CA prior to June 1, 2016, then prior to the release of Chrome 66, you will need to replace the existing certificate with a new certificate from any Certificate Authority trusted by Chrome. |
LKits
27.10.2017 20:23:06
| On January 19, 2017, a public posting to the mozilla.dev.security.policy newsgroup drew attention to a series of questionable website authentication certificates issued by Symantec Corporation’s PKI. Symantec’s PKI business, which operates a series of Certificate Authorities under various brand names, including Thawte, VeriSign, Equifax, GeoTrust, and RapidSSL, had issued numerous certificates that did not comply with the industry-developed CA/Browser Forum Baseline Requirements. During the subsequent investigation, it was revealed that Symantec had entrusted several organizations with the ability to issue certificates without the appropriate or necessary oversight, and had been aware of security deficiencies at these organizations for some time. |
~March 15, 2018
Chrome 66 released to beta, which will remove trust in Symantec-issued certificates with a not-before date prior to June 1, 2016. As of this date Site Operators must be using either a Symantec-issued TLS server certificate issued on or after June 1, 2016 or a currently valid certificate issued from any other trusted CA as of Chrome 66.
Site Operators that obtained a certificate from Symantec’s old infrastructure after June 1, 2016 are unaffected by Chrome 66 but will need to obtain a new certificate by the Chrome 70 dates described below.
~April 17, 2018
Chrome 66 released to Stable. |
sa ei või postitada uusi teemasid siia foorumisse sa ei või vastata selle foorumi teemadele sa ei või muuta oma postitusi selles foorumis sa ei või kustutada oma postitusi selles foorumis sa ei või vastata küsitlustele selles foorumis sa ei saa lisada manuseid selles foorumis sa ei või manuseid alla laadida selles foorumis
