uus teema   vasta Raud »  Protsessorid »  Intel Core i3/i5/i7/i9/Xeon protsessorite arutelu vol2 märgi kõik teemad loetuks
mine lehele eelmine  1, 2, 3 ... 15, 16, 17 ... 158, 159, 160  järgmine
anubis
anubis
sõnum 06.06.2018 11:08:08 vasta tsitaadiga
SP3/TR4 71,42x57,2mm (4085,224mm²)
Hetkeinfol sõidetakse sellega kuni 64c/128t.
LGA3647 paigaldamine on täielik porr, lisaks on pesa valideeritud 30x protsessori liigutamiseks (install/deinstall)
http://www.te.com/commerce/DocumentDelivery/DDEController?Action=srchrtrv&DocNm=1-1773883-1_LGA3647_Socket_Flyer&DocType=DS&DocLang=English&DocFilename=ENG
Kommentaarid: 316 loe/lisa Kasutajad arvavad:  :: 2 :: 0 :: 270
sõnum 06.06.2018 11:19:15 vasta tsitaadiga
piki pikkust lugesid veidi vähemaks. ja prose on veidi suurem kui pin area ka icon_wink.gif
aga close enough.
edit:
nüüd leidsin:
58.5 x 75.4 mm = 4410,9 mm²
- londiste
Kommentaarid: 237 loe/lisa Kasutajad arvavad:  :: 0 :: 1 :: 212
anubis
anubis
sõnum 06.06.2018 12:00:12 vasta tsitaadiga
Ah, pagan, ma võtsin socketi/pingrid mõõtmed.
sõnum 06.06.2018 21:59:08 vasta tsitaadiga
Intel @ full panic mode: https://www.hardocp.com/news/2018/06/06/did_intel_throw_in_28core_towel_at_computex
#28CoreCoolingGate
Kommentaarid: 89 loe/lisa Kasutajad arvavad:  :: 0 :: 0 :: 79
anubis
anubis
sõnum 06.06.2018 23:18:31 vasta tsitaadiga
https://www.techpowerup.com/244918/asus-rog-dominus-pictured-core-i9-xcc-confirmed-to-feature-6-channel-memory
Clearly bigger than ATX, in being either E-ATX or SSI form-factor, this board draws power from two 24-pin ATX, two 8-pin EPS, and three 6-pin PCIe, and has a gargantuan 16-phase VRM with two fan-heatsink blocks. Six DDR4 DIMM slots flank the socket on either side, each with its dedicated 64-bit wide path to the socket. The XCC silicon features a 48-lane PCI-Express gen 3.0 root complex, and so the board could feature at least two PCI-Express 3.0 x16 capable of full bandwidth, among a boat load of PCIe based storage connectivity, and onboard devices.
Jeebus.
MW TDP confirmed.
edit:
Link
terav...
ceemic
24/7@kalal
ceemic
sõnum 06.06.2018 23:47:13 vasta tsitaadiga
anubis kirjutas:
Link
Kommentaarid: 418 loe/lisa Kasutajad arvavad:  :: 0 :: 0 :: 321
eix666
eix666
sõnum 07.06.2018 01:02:15 vasta tsitaadiga
See 1,7kw (9,6A icon_lol.gif ) chiller on küll huumorinurga teema, aga see ei tohiks kellelegi üllatusena tulla, arvestades mis juba 4-6 tuumased 5GHzi peal teevad (ja 10nm on veel suurte kivide jaoks pigem kaugel).
sõnum 08.06.2018 14:17:06 vasta tsitaadiga
sõnum 08.06.2018 14:23:16 vasta tsitaadiga
Vale emaplaat
Kommentaarid: 161 loe/lisa Kasutajad arvavad:  :: 0 :: 0 :: 150
sõnum 08.06.2018 14:24:48 vasta tsitaadiga
huvitav, kuidas asus xelle õige x399 plate nimetab? x299-a on neil olemas icon_biggrin.gif
- londiste
NATAS999
sõnum 08.06.2018 15:35:04 vasta tsitaadiga
ei jaga praegu esimese matsuga nalja ära :/
sõnum 08.06.2018 15:42:40 vasta tsitaadiga
x299 on inteli socket 2066 chipset.
x399 on amd socket tr4 chipset.
- londiste
NATAS999
sõnum 08.06.2018 15:58:40 vasta tsitaadiga
londiste, seda küll, a kus see nali ikkagi on? mingi vietnami keeles miskit kirjutatud mingit asja ja siis asuse mobo amd kiibiga ja pildi peale inteli logod pandud... ja mis asi see 8086k on? mingi lahtiste kordajatega 086? mingi troll post raudselt.
sõnum 08.06.2018 16:18:42 vasta tsitaadiga
NATAS999 kirjutas:
Kiire googel ei tee paha? https://www.intel.com/content/www/us/en/products/processors/core/i7-processors/i7-8086k.html
DeTHiCa.
DeTHiCa.
sõnum 08.06.2018 22:34:57 vasta tsitaadiga
Tomorrow kirjutas:
#28CoreCoolingGate
Just a note. The HAILEY HC 1000B used by Intel is illegal to be imported and sold to Europe and NA because it is using R22 gas for freezing medium. A banned gas for over 14 years now. The other models of the series using R134a are still illegal to be sold and imported to Europe and NA also, since there is more resent ban on the gas (3-5 years).
Kommentaarid: 144 loe/lisa Kasutajad arvavad:  :: 0 :: 0 :: 136
NATAS999
sõnum 09.06.2018 12:49:24 vasta tsitaadiga
DeTHiCa. kirjutas:
Tomorrow kirjutas:
#28CoreCoolingGate
wtf icon_eek.gif normaalse jahutusega ei kannata seda jahutada, et peab külmkapp kõrval olema?
pots4t4j4
sõnum 09.06.2018 14:57:43 vasta tsitaadiga
Link
Kommentaarid: 486 loe/lisa Kasutajad arvavad:  :: 4 :: 3 :: 394
sõnum 09.06.2018 15:36:20 vasta tsitaadiga
NATAS999 kirjutas:
DeTHiCa. kirjutas:
Tomorrow kirjutas:
#28CoreCoolingGate
Kannatab aga mitte 5Ghz peal. Paljud on öelnud, et Intel oleks võinud minna nt custom loopi teed ja nt 4GHz näiteks. See oleks ikka olnud väga impressive 4Ghz @ 28c/56t. Ma ei tea kelle loll mõte see oli teha 5Ghz OC ja jätta ekslik mulje justkui aasta lõpus tuleb 5Ghz 28c/56t kiip. Ei tule. Samahästi oleks loll olnud reklaamida 8086K 7,2Ghz. Jah LN2 all tegi selle kella aga tavakasutuses ei saavuta 5Ghz isegi mitte kõigil tuumadel - ainult ühel. Ja see on 6c/12t seega annab aimu, et kui 6c/12t ei tee out of box 5Ghz kõigil tuumadel, siis ammugi ei tee seda prose millel ~4,5x rohkem tuumi.
TL;DR on see, et Intelil on ees rasked ajad. Serverites on nad ilmselt mõnda aega veel ok seisus kuna seal pikaajalised seosed aga HEDT liidripositsiooni kaotavad nad juba Augusti kuus ja vaadates seda, et üle 28 tuuma neil midagi tulemas ei ole, siis järgnevad aastad saavad olema veelgi viletsamad kui AMD keerab tuumasid ja kellasid järjest juurde. Järgmine aasta võime vabalt näha 4,5Ghz turbokellaga 64c/128t TR3xxx proset mis ehitatud 7nm peal.
Mainstreamis Intelil see aasta veel edu on (ainult taktsageduse osas) ja järgmine aasta kah kui nad toovad välja 8c/16t Coffee Lake prose Z390 peal aga kauaks seda pidu ei jätku. AMD toob välja 7nm 12c/24t mainstream prose mis on odavam ja saavutab arvatavasti sarnased kellad.
Seega lähiaastatel on Intel liiider ainult serverite vallas aga kui AMD aasta-aastalt paremaid, kiiremaid ja odavamaid tooteid väljastab läheb lõpuks ka seal olukord hapuks.
Seega kuii teil on Inteli prose, siis nautige kaua saate. Varsti on AMD parem valik ja siis on väga raske õigustada endale Inteli ostu.
Ja kui te arvate, et INtel langetab hindu, siis unistage edasi. Intel pigem müüb 10x 2000€ proset kui 100x 200€ proset.
Ma ei ütle, et Intelil nüüd üldse pole tulevikkuvaatavaid tooteid. Näiteks ma ise olen suur Optane fänn. Kahjuks Intel on seda võrdlemisi vähe ja valesti reklaaminud. Sellel on kindlasti oma nišš high end arvutitetes.
10Fold
10Fold
sõnum 09.06.2018 21:27:39 vasta tsitaadiga
NATAS999 kirjutas:
DeTHiCa. kirjutas:
Tomorrow kirjutas:
#28CoreCoolingGate
Kui sul on mõni normaalne jahuti mis suudab ligi 2000W jahutada siis ei pea icon_lol.gif
Kommentaarid: 269 loe/lisa Kasutajad arvavad:  :: 2 :: 0 :: 229
heretic666
heretic666
sõnum 10.06.2018 01:13:22 vasta tsitaadiga
https://www.caseking.de/intel-core-i7-8086k-4-0-GHz-coffee-lake-sockel-1151-boxed-hpit-516.html
Kommentaarid: 70 loe/lisa Kasutajad arvavad:  :: 0 :: 0 :: 68
Vael
sõnum 10.06.2018 10:43:39 vasta tsitaadiga
Mis siin ebareaalset on? OC ja kuumus tekitavad lekkevoole, 300w saabki lihtsalt 1kw ülekellates, füüsikaseaduste vastu ei saa(veel).
Pole see ei Inteli vms firma süü, lihtsalt seõgitus puudus, et OC.
Ja turuosa paanikast ka ei saa aru, Intelil kukub kohati 90% pealt 70-60% peale, pankrotti ikka sellest ei lähe...
10Fold
10Fold
sõnum 10.06.2018 12:05:17 vasta tsitaadiga
Vael kirjutas:
300w icon_lol.gif ? 300w on VRM soojuskadu juba. Ebareaalne on et see prose sellisel kujul kunagi turule jõuab. 2000w prose toitmisega tekib million üks probleemi...
Näiteks milline toide ainult selle prosega üksigi hakkama saaks icon_lol.gif
sõnum 10.06.2018 12:27:37 vasta tsitaadiga
28-core skylake-xp xeonid jooksevad 2.1/2.5 GHz baastaktil, 165/205w tdp.
- londiste
degreal
sõnum 11.06.2018 18:28:40 vasta tsitaadiga
Intel tõestas praegu, et "overclocking headroom"-ist pole midagi kasu.
Kommentaarid: 25 loe/lisa Kasutajad arvavad:  :: 0 :: 0 :: 23
Anna tooli
sõnum 12.06.2018 08:26:32 vasta tsitaadiga
https://www.anandtech.com/show/12945/the-intel-core-i7-8086k-review
Kommentaarid: 351 loe/lisa Kasutajad arvavad:  :: 0 :: 0 :: 293
uus teema   vasta Raud »  Protsessorid »  Intel Core i3/i5/i7/i9/Xeon protsessorite arutelu vol2 mine lehele eelmine  1, 2, 3 ... 15, 16, 17 ... 158, 159, 160  järgmine
