praegune kellaaeg 10.11.2026 04:21:40
uvuv
15.10.2017 13:01:31
Windowsi paigaldamine 29GB kettale |
Asus E403S notebook, 29GB NVMe, algselt oli peal Windows 10 Home
Windows 10 peal hävis, nüüd üritan paigaldada uuesti... jõuab kuni ketta, partitsiooni valimiseni, edasi annab vaid üldsõnalist teadet "Windows cannot be installed to this disk. The computer's hardware may not support booting to this disk. Ensure that disk controller is enabled in the computer's BIOS menu".
Paigaldamise logist kuvatakse info
2017-10-14 14:11:34, Info IBSLIB CanBeSystemVolume: Volume at disk [0] offset [0x7e00] doesn't meet criteria for system volumes...
2017-10-14 14:11:34, Info IBSLIB DiskRegionSupportsCapability:Disk [0] is BLOCKED against capability [CanBeSystemVolume] for the following reasons...
2017-10-14 14:11:34, Info IBSLIB LogReasons: [BLOCKING reason for disk 0: CanBeSystemVolume] The selected disk is not the computer's boot disk.
2017-10-14 14:11:34, Info IBSLIB DiskRegionSupportsCapability:Disk [0] is WARNED against capability [CanBeSystemVolume] for the following reasons...
2017-10-14 14:11:34, Info IBSLIB LogReasons: [WARNING reason for disk 0: CanBeSystemVolume] This computer's hardware may not support booting to this disk. Ensure that the disk's controller is enabled in the computer's BIOS menu.
2017-10-14 14:11:34, Info IBSLIB DiskRegionSupportsCapability:Region on disk [0] (offset = [0x7e00]) is BLOCKED against capability [CanBeSystemVolume] for the following reasons...
2017-10-14 14:11:34, Info IBSLIB LogReasons: [BLOCKING reason for {disk 0 offset 0x7e00}: CanBeSystemVolume] The partition is too small.
Milline mõttekild kusagile nurga taha kinni on jääänud? Kuidas paigaldada windowsi?
| Kommentaarid: 36 loe/lisa |
ummy
97 |
uvuv
15.10.2017 13:46:18
BIOS on antud seadmel väga minimaalsete valikutega ja mitmeid kord läbi käidud: secure boot on väljas, ketta valikuid- ahci, jm ei ole, bootseadmed- usb 3.0 pulgad- on tuvastatavad.
Sama tulemus on ka win7 paigaldamisel.
ricom2ger
15.10.2017 13:49:00
Diskpartiga kustuta partid ära, tee uus, aktiveeri part ja uus boot installerisse.
_________________ Kamehameha in your face! |
111 |
