praegune kellaaeg 21.09.2026 05:44:01
05.08.2017 22:14:32
Liitiumi-sõda vol.3: Saksamaa tahab saada Afanigistani liitiumimaardlat enda kontrolli alla. |
1. Nonii. ei läinudki kaua aega selleks, et näha milline Riik tahab saada oma kontrolli alla saada, alles hiljuti avastatud - ning maailma suurimaks maardlaks peetavat, Afanigistanis asuvat liitiumimaardlat.
Selleks riigiks on hetkel siis Saksamaa.
1. Link kus on siis sellet uuest maarlast pikemalt juttu:
Afghanistan’s Potential Billions in Lithium: Why It’s Important
https://www.fastcompany.com/1659795/afghanistans-potential-billions-lithium-why-its-important
2. Ja nüüd tegid sakslased siis enda "Liitium-RoadShow" - lootustega saada see uus liitiumimaardla oma kontrolli alla.
- eks näis millised riigid on siis järgmised, sama sooviga ning loodetavasti ei tooda selleks relvi välja - nii nagu käib Põhja-Jäämeres pidevalt vastastikune "relvade näitamine"...
Germany Asked To Use Afghanistan’s Lithium In Automotive Industry
German President Frank-Walter Steinmeier said his country continues its support of different sectors in Afghanistan.
President Ashraf Ghani in a meeting with German President Frank-Walter Steinmeier at the Presidential Palace on Thursday discussed Afghanistan’s security, peace and economy.
The German president arrived in Kabul with a high ranking delegation on Thursday.
Pointing to the importance of Afghanistan’s mineral resources, Ghani suggested that German automobile companies should use the country’s lithium in their automotive industry, a press release issued by the Presidential Palace said.
“Afghanistan’s mineral resources requires proper management. The quality of Helmand’s lithium is very high and it can be used in the automotive industry,” Ghani said.
In response to this, the German president said they will work on the use of Afghanistan’s lithium by Dutch companies.
He said Germany will continue its support to different sectors in Afghanistan.
Steinmeier said his country supports the Afghan peace talks process adding that he met with German troops in Balkh where they said the Afghan forces are becoming more capable.
Ghani said the Afghan government continues its efforts to bring basic reforms particularly in the ministries of interior and defense.
He said the ministries will be made professional and apolitical.
The two sides also discussed the upcoming parliamentary elections.
He welcomed Germany’s technical support to the process and said the elections will be held in a transparent environment.
http://www.tolonews.com/index.php/business/germany-asked-use-afghanistan%E2%80%99s-lithium-automotive-industry
marcor1
05.08.2017 23:27:17
maavarade kättesaamiseks ja transpordiks on vaja infrat. Ehk tekib sinna moonipõldude, telkide ja punkrite vahele jälle elamisväärsem keskkond - riik on juba ~40 aastat pahupidi olnud.
_________________ War. War never changes.
Malkavian: [to a stop sign] No, you stop! |
sa ei või postitada uusi teemasid siia foorumisse sa ei või vastata selle foorumi teemadele sa ei või muuta oma postitusi selles foorumis sa ei või kustutada oma postitusi selles foorumis sa ei või vastata küsitlustele selles foorumis sa ei saa lisada manuseid selles foorumis sa ei või manuseid alla laadida selles foorumis
