sõnum |
Kommentaarid: 89 loe/lisa |
79 |
dohc-48v12
Aeg maha 1p
29.06.2017 10:26:17
parajalt suur et kõik driver-d ära mahuks
_________________ Ime tala, Nagu ime kepike.
Miks ADMIN Anti112 ambusib mind? andis 1p cooldowni aga ma ei saa peale selle enam mitteühtegi postitust teha! üks päev ei kuid! |
Kommentaarid: 112 loe/lisa |
6 :: |
85 |
anubis
04.07.2017 14:42:59
http://research.nvidia.com/publication/2017-06_MCM-GPU%3A-Multi-Chip-Module-GPUs
tsitaat: |
8 CONCLUSIONS
Many of today’s important GPU applications scale well with GPU
compute capabilities and future progress in many fields such as exascale
computing and artificial intelligence will depend on continued
GPU performance growth. The greatest challenge towards building
more powerful GPUs comes from reaching the end of transistor density
scaling, combined with the inability to further grow the area of
a single monolithic GPU die. In this paper we propose MCM-GPU,
a novel GPU architecture that extends GPU performance scaling at
a package level, beyond what is possible today. We do this by partitioning
the GPU into easily manufacturable basic building blocks
(GPMs), and by taking advantage of the advances in signaling technologies
developed by the circuits community to connect GPMs
on-package in an energy efficient manner.
We discuss the details of the MCM-GPU architecture and show
that our MCM-GPU design naturally lends itself to many of the
historical observations that have been made in NUMA systems. We
explore the interplay of hardware caches, CTA scheduling, and data
placement in MCM-GPUs to optimize this architecture. We show
that with these optimizations, a 256 SMs MCM-GPU achieves 45.5%
speedup over the largest possible monolithic GPU with 128 SMs.
Furthermore, it performs 26.8% better than an equally equipped
discrete multi-GPU, and its performance is within 10% of that of a
hypothetical monolithic GPU that cannot be built based on today’s
technology roadmap. |
Pole päris 100% õige koht aga huvitav lugemine. Ehk midagi mis tuleb peale Voltat.
Kommentaarid: 316 loe/lisa |
270 |
04.07.2017 18:20:13
anubis, Tundub jah, et nii AMD kui ka Nvidia plaanivad tulevikus ühe suure kiibi ehitamise asemel minna seda teed, et panna kokku mitu väiksemat ühele interposerile. Interposer ei maksa kah eriti midagi. Ühel PCB-l olevad kaks GPU-d mis ühendatud PLX kiibiga on samas läbikäidud etapp ja pole eriti parem SLI/CF lahendusest. Seega jutt käib ilmselt ikkagi kas mitmest väiksemast ühel interposeril või 3D stackingust, kuigi selle juures võib jahutamisega probleeme tekkida.
Eks näis. Huvitavad ajad
79 |
04.07.2017 22:25:32
ilmselt on suund ikkagi eraldi kivide, mitte interposerile ladumise suunas. interposer on kallis ja piiratud suurusega.
plx on pci-e bridge ja see ongi üsna täpselt sli/cf lahendus.
nvlink ja infinity fabric mõlemad on native ühenduslahendused, mis toimivad üle pcb päris hästi.
_________________ - londiste
Kommentaarid: 237 loe/lisa |
212 |
anubis
04.07.2017 22:30:51
Mõte on vist jah, liikuda samas suunas kuhu AMD on prosede-otsaga just jõudnud (infinityfabricu lingid või paar igal kivil millega neid n+1 kokku siduda) ja mis nagu näha heaste toimib.
270 |
04.07.2017 22:31:01
londiste, No vaadates viimase aja arenguid pole mingi probleem teha 600mm² kuni 1000mm² interposer. Hind on muidugi iseasi.
NVLink ega IF pole veel kasutatud samal PCB-l olevate kiipide ühendamiseks (vähemalt mitte graafikaartidel) seega me ei tea kui hästi see toimib tegelikult.
79 |
anubis
270 |
10.08.2017 14:35:28
pigem hind ja qc ikka.
212 |
hempadonok
Kommentaarid: 10 loe/lisa |
10 |
15.08.2017 12:11:32
Jep. Kui konkurents puudub ja 1080Ti on kõigutamatu pole vaja ka kiirustada. Ise olen tavalise 1080 peal. Kahtlen, et 1080Ti peale viitsin uuendada.
79 |
Scart
Kommentaarid: 119 loe/lisa |
101 |
12.11.2017 11:33:03
https://videocardz.com/newz/samsung-16gb-gddr6-memory-receives-ces-innovation-award
GDDR6 siis consumer Volta kaartidel. 1,35v vs 1,5v. Suuremamahulised kiibid ja mõistagi suurem kiirus (kuni 16Gbps). Lingil ka potentsiaalsed kiirused ära toodud. Mahud peaksid olema: 12GB, 16GB, 24GB ja 48GB (viimane ilmselgelt ainult workstation mudelitel). Low end mudelitel võüidakse ka 8GB kasutada, aga isiklikult loodan küll, et mingeid 3GB vms mõttetusi enam ei näe. GDDR6 on nii kiire, et isegi 8GB @ 128bit mälusiiniga peaks pakkuma üsna head kiirust. xx50 võibolla tuleb väiksema mälumahuga aga loodan, et xx60 seeria ja kiiremad tulevad vähemalt 8GB-ga. Mis oleks ka loogiline arvestades, et 1060 on juba 6GB olemas.
Vaadates Vega probleeme HBM2-ga kahtlen, et Nvidia seda consumer kaartidel kasutab. Äärmisel juhul Titan mudelitel, kuna need ei käi läbi AIB'de ja müüdav kogus on väiksem ja hind pole probleem.
Samas GDDR5X satub veidi kummalisse positsiooni seoses GDDR6-ga. Micron on öelnud, et G5X suudab samuti teha 16Gbps aga mitte kõik sisemised voldid ei jookse 1.35v peal seega voolutarve on vist veidi kõrgem vs GDDR6 ja arvatavasti ka mahueelist pole. Võimalik siiski, et G5X leiab kasutust low end mudelitel kus hind on olulisem kui mahud ja otsene kiirus.
79 |
Gap
Kommentaarid: 20 loe/lisa |
16 |
HZo
Kommentaarid: 30 loe/lisa |
20.11.2017 20:06:18
TL;DR läbi google tõlke on see, et spekulaaritakse justkui Ampere oleks 10nm mitte 12nm nagu Volta. Ja et Volta jäetakse üldse vahele (v.a siis see ainuke GV100).
Eks näis. Kui see tõsi on, siis Nvidia pidi nihutama Ampere ettepoole. Vaevalt neil oli plaanis see välja tuua enne 2019 ja väheusutav, et samal aastal oleks mõtet välja tuua 12nm Volta ja 10nm Ampere.
Samas kindlalt ei tea me ju midagi. Võimalik, et Volta siiski tuleb aga läheb aega, et 12nm yieldid normaalseks saada. Pascalil oli kah alguses tõsiseid probleeme. Kaarte suudeti toota väga vähe ja mitu kuud olid hinnad üsna kõrged.
Kui nad suudavad järgmise aasta kevadel 10nm kaardid letti tuua, siis see oleks omaette saavutus imo.
79 |
20.11.2017 22:19:35
miks pidi nihutama ettepoole? miks mitte gaming volta vahele jätmine, sest sel ei paista majanduslikku mõtet olema. konkurenti pole ja aastaga oodata nagu ka ei ole. sama hea spekulatsioon nagu iga teinegi. see lugu samuti arvab, et full node shrink 10nm peale tooks ilmselt muiljetavaldavamaid tulemusi.
pascali tootmisprobleemite jutt on väga ülepaisutatud. need lihtsalt müüdi esimesed kolm-neli kuud läbi kiiremini kui neid toota suudeti.
212 |
20.11.2017 22:31:16
londiste, Ega ikka polnud ülepaisutatud. Oli poode mis said vähem kui 10 kaarti korraga ainult. Üritasin praegu linke ja pilte leida, aga pooleteise aasta vanused uudised paraku mattuvad kiiresti uue müra alla. Olukord paranes paari kuu joooksul. Jah eks nõudlus oli kah meeletu aga ega supply kah teab mis vapustav polnud. On olnud ka suurema nõudlusega launche kus pole nii kitsaks kätte läinud. Mul endal vedas, et sain Juuli 2016 700€ eest GTX 1080 mis sel hetkel oli hea hind. Enamus kohtades küsiti sel hetkel 900+ ja 700 poehinda nägi alles kuskil Augusti lõpus, Septembris. Läbi kasutaja liiv tellisin siis.
Loodan, et Volta/Ampere launch tuleb siis sujuvam. Ja ma arvan, et tuleb kah - me pole 5 aastat istunud 16nm peal ja pole paisu taha kogunenud niipalju uuendajaid.
79 |
20.11.2017 23:37:45
miks peaks? high-profile reliisid on viimasel ajal ju kõik nii käinud. vega, 1080ti, amd midrange puhul mining sinna otsa. ja ega prosedega lugu parem pole, 8000 seeria ja ryzenid mõlemad olid esimesed paar kuud umbes.
212 |
21.11.2017 10:48:26
londiste, 1080Ti midagi väga hullu polnud. Vega oli ja on AMD enda ära käkitud. Polaris refresh oli ok kuni kaevandamislaine peale tuli. Coffee Lake on Inteli süü, et toodi mitu kuud varem turule kui algselt plaanis. Ryzeni prosede saadavusega polnud üldse mingit probleemi. Probleem oli emaplaatides mida eriti saada polnud. Selles osas ma väljendasin ka oma muret juba enne Ryzeni launchi ja kahjuks emaplaaditootjad ei saanud oma tööga hakkama kuigi oli tükk aega ette teada millal launch on erinevalt nt Coffee Lake-st.
79 |
heretic666
21.11.2017 11:57:05
Ti ei olnud uue arhitektuuri launch. Kui 1080 non Ti tuli välja siis oli ikka ka meeletu põud pascalitest pikka aega.
Kommentaarid: 70 loe/lisa |
68 |
21.11.2017 12:17:02
ma vaatasin just huvi pärast järgi. juulis, ehk siis äkki kuu peale launchi olen msrp eest gtx1070 ostnud. mitte, et see olnuks esimene võimalus vaid too hetk tekkis lõpuks huvi vaadata kuidas 980ti võrdluses välja paistab ja masinat jahedamaks ajada. ma ei tea, millest te räägite. jah, letilt võtta ei olnud. ja eesti edasimüüjad olid mõttetud nagu tavaliselt. aga kaarte liikus piisavalt ja regulaarselt.
mis seda situatsiooni näiteks vegast eristab? neid liigub ka. aga seekord lihtsalt ei ole mitte kellelgi huvi kohe kaardi saamiseks +100 raha maksta.
mitte polaris refresh vaid esimene polaris, rx480/470? neid polnud ka päris pikalt saada, isegi enne kui õige kaevandamismaania hakkas?
coffee lake on algusest peale üsna stabiilselt saadaval olnud, välja arvatud popimad mudelid nagu 8700k. 8400 või 8700 on praktiliselt kogu aeg olnud ladudes olemas, mine ja võta poest. sealhulgas ka eestist.
ryzeni esimesed paar nädalat oli kindlasti ka prosedest puudus, need lihtsalt osteti kohe ära. üsna sarnaselt sellele, mis toimus psacalitega. emaplaatide situatsioon sinna otsa.
see on lihtsalt praegune aeg, kus on piisavalt palju piisava rahalise võimekusega huvilisi-entusiaste, et vähegi kõrgema otsa või bang-for-buck raua tulles ostetakse laod tühjaks. keegi ei suuda sinna piisavalt laoseisu kohe alguses tekitada.
212 |
heretic666
21.11.2017 17:20:16
londiste, tuttav ka tahtis 1080 kaarte launchi ajal ja pidi kaua ootama. Algul tulid need "moneyman editionid" blower cooleriga mida keegi eriti ei tahtnud ja siis riburadapidi tilkus millalgi non reference jahutusega kaarte ka kusagilt napi saadavusega. Lõpuks sai casekingist osta.
68 |
08.12.2017 09:15:57
https://wccftech.com/nvidia-titan-v-volta-gpu-hbm2-announcement/
Volta confirmed. Kahju ainult, et 12GB. Oleks võinud olla 16GB nagu Tesla V100. See siis ikkagi kinnitab, et 11 seeria tuleb Volta mitte Ampere?
Sellest muide oli kuskil suvel väike leke kah. Nime osas ennustasin õigesti.
Esimene päris compute kaart alates esimest Titanist siis. Tensor tuumad kah olemas.
Mängimiseks muidugi mõttetu väljaminek, aga kindlasti ostetakse ka mängimiseks kuni GV102 välja tuleb. Iseasi kui Titan on nüüd 3K hinnaga kas see tähendab, et AMD poolse konkuretsi puuduse tõttu on ka teiste Volta kaartide hinnad veel kõrgemad? Ma kardan küll jah. 999$ GV102? Võibolla...
79 |
p1lv1k
Kommentaarid: 3 loe/lisa |
