praegune kellaaeg 21.09.2026 05:43:42
sooty
18.04.2017 20:41:40
Meet PINLogger, the drive-by exploit that steals smartphone PINs |
https://arstechnica.com/security/2017/04/meet-pinlogger-the-drive-by-exploit-that-steals-smartphone-pins/
Malicious webpages—or depending on the browser, legitimate sites serving malicious ads or malicious content through HTML-based iframe tags—can mount the attack by using standard JavaScript code that accesses motion and orientation sensors built into virtually all iOS and Android devices. To demonstrate how the attack would work, researchers from Newcastle University in the UK wrote attack code dubbed PINLogger.js. Without any warning or outward sign of what was happening, the JavaScript was able to accurately infer characters being entered into the devices.
"That means whenever you are typing private data on a webpage and this webpage for example has some advert banners at the side or the bottom, the advert provider as part of the page can 'listen in' and find out what you type in that page," Siamak F Shahandashti, one of the Newcastle University researchers who demonstrated the attack, told Ars. "Or with some browsers as we found, if you open a page A and then another page B without closing page A (which most people do) page A in the background can listen in on what you type in page B."
sa ei või postitada uusi teemasid siia foorumisse sa ei või vastata selle foorumi teemadele sa ei või muuta oma postitusi selles foorumis sa ei või kustutada oma postitusi selles foorumis sa ei või vastata küsitlustele selles foorumis sa ei saa lisada manuseid selles foorumis sa ei või manuseid alla laadida selles foorumis
