Taavi_R
06.12.2003 00:42:54
Veateade |
Isal laptopil (Win2k) on mingi imelik probleem.
Polw just 2k kursis. Aga ei lase midagi muuta.
Nagu poleks administraatorina sisse logitud.
Kuigi tal on ainult üks kasutaja. Folder Option´i
ei lase ka ligi.
Veateade on taoline:
"The operatsion has been cancelled due to restictions on this computer.
Please contact your system administrator."
Veel ... Kui internetti tahad minna (läbi IE) siis mingi 30 sekundit on
IE`l all real tekst "Decting proxy settings". Millest see võiks tulla?
_________________ raamatupidamine | laadakalender
viimati muutis Taavi_R 06.12.2003 00:53:23, muudetud 1 kord |
165 |
Porno Parm
mugavuspagulane
| Kommentaarid: 66 loe/lisa |
6 :: |
47 |
Taavi_R
06.12.2003 00:53:50
Sorry, viga parandatud
Keegi seda esimest veateate lahendust pisut emakeelsemaks ei taha tõlkida?
_________________ raamatupidamine | laadakalender |
165 |
Porno Parm
mugavuspagulane
06.12.2003 01:07:10
ermed
you're receiving the Administrative error, this should be the registry restriction
that has been set. If you have any programs installed (TweakUI) that you have changed,
the setting will return after rebooting. If Pol-edit is installed and you do have
an Administrator, this won't work!
Select Start/Run, type REGEDIT in the 'Open' box and press enter. When Registry Editor
opens, click 'Edit' on the toolbar and then 'Find'. Next in the 'Find what:' window,
type NoSetFolders and press enter. If the entry is found, it will show in
the right pane. Right click it and select 'Delete' from the menu, or select 'Modify'
and change the value form '1' to '0'.
NoSetFolders = enable/disable Folder settings
6 :: |
47 |
Taavi_R
165 |
