praegune kellaaeg 30.10.2026 07:01:59
Tõnna
21.01.2017 16:45:01
Tõrge Zadig draiveritega |
21.01.17 - 0 vastust... et nagu mitte keegi ei oska midagi arvata?
Tahan lisada Windows 7 PE buildile Zadigi installeriga RTL2832U kividraivereid et seda SDRina käima saada. Kui Zadigi alt installeerib muidu 2 draiverit Bulk-in interface 0 ja Bulk -in interface 1. siis PE alt setupapi.dev.log vaadates asi jookseb kokku. Keegi oskab öelda,mis krdi faili ta sealt ei leia? See oem44.inf on omal kohal täiesti olemas. Ma olen oma pöidla juba kondini veriseks imenud...
dvi: {DIF_INSTALLINTERFACES - exit(0x00000000)} 16:04:49.952
ndv: Installing device...
dvi: {DIF_INSTALLDEVICE} 16:04:49.952
dvi: Looking for class installer for 'Bulk-In, Interface (Interface 1)'...
dvi: No class installer for 'Bulk-In, Interface (Interface 1)'
dvi: CoInstaller 1: Enter 16:04:49.952
inf: Opened INF: 'X:\windows\INF\oem44.inf' ([strings])
!!! dvi: CoInstaller 1: failed(0x00000002)!
!!! dvi: Error 2: The system cannot find the file specified.
dvi: {DIF_INSTALLDEVICE - exit(0x00000002)} 16:04:50.022
!!! ndv: Error(00000002) installing device!
All neist ühe draiveri installimise logi. Suht pikk, kusagil lõpupoole viskab selle errori ette
[Boot Session: 2016/12/21 15:49:09.459]
>>> [Device Install (DiShowUpdateDevice) - USB\VID_0BDA&PID_2838&MI_01\6&38A180A5&0&0001]
>>> Section start 2016/12/21 16:04:46.667
cmd: "X:\Windows\System32\mmc.exe" /b X:\windows\System32\devmgmt.msc
dvi: {DIF_UPDATEDRIVER_UI} 16:04:46.667
dvi: Looking for class installer for 'Bulk-In, Interface'...
dvi: No class installer for 'Bulk-In, Interface'
dvi: CoInstaller 1: Enter 16:04:46.667
dvi: CoInstaller 1: Exit
dvi: CoInstaller 2: Enter 16:04:46.667
dvi: CoInstaller 2: Exit
dvi: Default installer: Enter 16:04:46.667
dvi: Default installer: Exit
dvi: {DIF_UPDATEDRIVER_UI - exit(0xe000020e)} 16:04:46.667
ndv: {Update Driver Software Wizard for USB\VID_0BDA&PID_2838&MI_01\6&38A180A5&0&0001}
inf: {SetupCopyOEMInf: X:\windows\INF\oem44.inf} 16:04:49.692
inf: Driver Store location: X:\windows\System32\DriverStore\FileRepository\bulk-in_interface_(interface_1).inf_x86_neutral_c98f767b46b908bb\bulk-in_interface_(interface_1).inf
inf: Published Inf Path: X:\windows\INF\oem44.inf
inf: Installing catalog Bulk-In_Interface_(Interface_1).cat as: oem44.CAT
inf: OEM source media location: X:\windows\INF\
inf: {SetupCopyOEMInf exit (0x00000000)} 16:04:49.702
dvi: Searching for hardware ID(s):
dvi: usb\vid_0bda&pid_2838&rev_0100&mi_01
dvi: usb\vid_0bda&pid_2838&mi_01
dvi: Searching for compatible ID(s):
dvi: usb\class_ff&subclass_ff&prot_ff
dvi: usb\class_ff
inf: PNF ignored: 'bulk-in_interface_(interface_1).PNF' (??????????h??????????l???????e??????????????????????????????????)
inf: Opened INF: 'X:\windows\System32\DriverStore\FileRepository\bulk-in_interface_(interface_1).inf_x86_neutral_c98f767b46b908bb\bulk-in_interface_(interface_1).inf' ([strings])
dvi: Created Driver Node:
dvi: HardwareID - USB\VID_0BDA&PID_2838&MI_01
dvi: InfName - X:\windows\System32\DriverStore\FileRepository\bulk-in_interface_(interface_1).inf_x86_neutral_c98f767b46b908bb\bulk-in_interface_(interface_1).inf
dvi: DevDesc - Bulk-In, Interface (Interface 1)
dvi: DrvDesc - Bulk-In, Interface (Interface 1)
dvi: Provider - libwdi
dvi: Mfg - Realtek Semiconductor Corp.
dvi: ModelsSec - libusbDevice_WinUSB.NTx86
dvi: InstallSec - USB_Install
dvi: ActualSec - USB_Install
dvi: Rank - 0xf0ff0001
dvi: Signer -
dvi: Signer Score - Not digitally signed
dvi: DrvDate - 03/30/2015
dvi: Version - 6.1.7600.16385
dvi: Selected driver installs from section [USB_Install] in 'x:\windows\system32\driverstore\filerepository\bulk-in_interface_(interface_1).inf_x86_neutral_c98f767b46b908bb\bulk-in_interface_(interface_1).inf'.
dvi: Class GUID of device remains: {88bae032-5a81-49f0-bc3d-a4ff138216d6}.
dvi: Set selected driver complete.
dvi: {Plug and Play Service: Device Install for USB\VID_0BDA&PID_2838&MI_01\6&38A180A5&0&0001}
ump: Creating Install Process: DrvInst.exe 16:04:49.712
ndv: Infpath=X:\windows\INF\oem44.inf
ndv: DriverNodeName=bulk-in_interface_(interface_1).inf:libusbDevice_WinUSB.NTx86:USB_Install:6.1.7600.16385:usb\vid_0bda&pid_2838&mi_01
ndv: DriverStorepath=X:\windows\System32\DriverStore\FileRepository\bulk-in_interface_(interface_1).inf_x86_neutral_c98f767b46b908bb\bulk-in_interface_(interface_1).inf
ndv: Building driver list from driver node strong name...
dvi: usb\class_ff
dvi: Signer -
ndv: {Core Device Install} 16:04:49.802
dvi: {DIF_ALLOW_INSTALL} 16:04:49.832
dvi: Looking for co-installer modules for 'Bulk-In, Interface (Interface 1)'.
dvi: Using exported function 'WdfCoInstaller' in module 'X:\windows\system32\WdfCoInstaller01011.dll'.
dvi: CoInstaller 1 == WdfCoInstaller01011.dll,WdfCoInstaller
dvi: Using exported function 'CoDeviceInstall' in module 'X:\windows\system32\WinUSBCoInstaller2.dll'.
dvi: CoInstaller 2 == WinUSBCoInstaller2.dll
dvi: CoInstaller 1: Enter 16:04:49.842
dvi: CoInstaller 2: Enter 16:04:49.842
dvi: Default installer: Enter 16:04:49.842
dvi: {DIF_ALLOW_INSTALL - exit(0xe000020e)} 16:04:49.842
ndv: Installing files...
dvi: {DIF_INSTALLDEVICEFILES} 16:04:49.842
dvi: Default installer: Enter 16:04:49.852
dvi: {Install FILES}
inf: Opened INF: 'x:\windows\system32\driverstore\filerepository\bulk-in_interface_(interface_1).inf_x86_neutral_c98f767b46b908bb\bulk-in_interface_(interface_1).inf' ([strings])
inf: INF not found: 'x:\windows\system32\driverstore\filerepository\bulk-in_interface_(interface_1).inf_x86_neutral_c98f767b46b908bb\winusb.inf'
inf: INF not found: 'X:\windows\INF\winusb.inf'
inf: {Install Inf Section [USB_Install]}
inf: Copyfiles: none
inf: Renfiles: none
inf: Delfiles: none
inf: No (Copy/Ren/Del)Files directives found
inf: {Install Inf Section [USB_Install] exit (0x00000000)}
inf: {Install Inf Section [WINUSB.NT]}
inf: Renfiles: none
inf: Delfiles: none
inf: {Install Inf Section [WINUSB.NT] exit (0x00000000)}
dvi: Processing co-installer registration section [USB_Install.CoInstallers].
inf: {Install Inf Section [USB_Install.CoInstallers]}
inf: CopyFiles=CoInstallers_CopyFiles (bulk-in_interface_(interface_1).inf line 69)
cpy: Open PnpLockdownPolicy: Err=2. This is OK. Use LockDownPolicyDefault
flq: QueueSingleCopy...
flq: Inf : 'x:\windows\system32\driverstore\filerepository\bulk-in_interface_(interface_1).inf_x86_neutral_c98f767b46b908bb\bulk-in_interface_(interface_1).inf'
flq: SourceInf: 'x:\windows\system32\driverstore\filerepository\bulk-in_interface_(interface_1).inf_x86_neutral_c98f767b46b908bb\bulk-in_interface_(interface_1).inf'
flq: SourceSection: [sourcedisksfiles.x86]
flq: Source root path based on SourceInf
flq: SourceRootPath: 'X:\windows\System32\DriverStore\FileRepository\bulk-in_interface_(interface_1).inf_x86_neutral_c98f767b46b908bb'
flq: {FILE_QUEUE_COPY}
flq: CopyStyle - 0x00000000
flq: SourceRootPath - 'X:\windows\System32\DriverStore\FileRepository\bulk-in_interface_(interface_1).inf_x86_neutral_c98f767b46b908bb'
flq: SourcePath - '\x86'
flq: SourceFilename - 'WinUSBCoInstaller2.dll'
flq: TargetDirectory- 'X:\windows\system32'
flq: TargetFilename - 'WinUSBCoInstaller2.dll'
flq: SourceDesc - 'Bulk-In, Interface (Interface 1) Install Disk'
flq: {FILE_QUEUE_COPY exit(0x00000000)}
flq: SourceFilename - 'WdfCoInstaller01011.dll'
flq: TargetFilename - 'WdfCoInstaller01011.dll'
inf: Renfiles: none
inf: Delfiles: none
inf: {Install Inf Section [USB_Install.CoInstallers] exit (0x00000000)}
dvi: Co-installers registered.
dvi: {Install INTERFACES}
dvi: Installing section [USB_Install.Interfaces]
dvi: {Install INTERFACES exit 00000000}
dvi: {Install FILES exit (0x00000000)}
dvi: {DIF_INSTALLDEVICEFILES - exit(0x00000000)} 16:04:49.862
ndv: Pruning file queue...
dvi: {_SCAN_FILE_QUEUE}
flq: ScanQ flags=620
flq: SPQ_SCAN_PRUNE_COPY_QUEUE
flq: SPQ_SCAN_FILE_COMPARISON
flq: SPQ_SCAN_ACTIVATE_DRP
flq: ScanQ number of copy nodes=2
flq: File 'X:\windows\system32\WinUSBCoInstaller2.dll' pruned from copy.
cpy: DrpSetRegFileProt 'X:\windows\system32\WinUSBCoInstaller2.dll' Status=0 Class=OEM Legacy
flq: File 'X:\windows\system32\WdfCoInstaller01011.dll' pruned from copy.
cpy: DrpSetRegFileProt 'X:\windows\system32\WdfCoInstaller01011.dll' Status=0 Class=OEM Legacy
flq: ScanQ action=200 DoPruning=32
flq: ScanQ end Validity flags=620 CopyNodes=0
dvi: {_SCAN_FILE_QUEUE exit(0, 0x00000000)}
ndv: Committing file queue...
flq: {_commit_file_queue}
flq: CommitQ DelNodes=0 RenNodes=0 CopyNodes=0
flq: CommitQ early exit: No nodes are queued
flq: {_commit_file_queue exit OK}
ndv: Registering CoInstallers...
dvi: {DIF_REGISTER_COINSTALLERS} 16:04:49.932
dvi: CoInstaller 1: Enter 16:04:49.942
dvi: CoInstaller 2: Enter 16:04:49.942
dvi: Default installer: Enter 16:04:49.942
inf: UpdateInis: none
inf: UpdateIniFields: none
inf: DelReg: none
inf: AddReg=CoInstallers_AddReg (bulk-in_interface_(interface_1).inf line 68)
inf: HKR,,CoInstallers32,0x00010000,WdfCoInstaller01011.dll,WdfCoInstaller,WinUSBCoInstaller2.dll (bulk-in_interface_(interface_1).inf line 72)
inf: BitReg: none
inf: Ini2Reg: none
dvi: {DIF_DESTROYPRIVATEDATA} 16:04:49.942
dvi: {DIF_DESTROYPRIVATEDATA - exit(0xe000020e)} 16:04:49.942
dvi: {DIF_REGISTER_COINSTALLERS - exit(0x00000000)} 16:04:49.952
ndv: Installing interfaces...
dvi: {DIF_INSTALLINTERFACES} 16:04:49.952
dvi: CoInstaller 2: Enter 16:04:49.952
dvi: Default installer: Enter 16:04:49.952
ndv: Device install status=0x00000002
ndv: Performing device install final cleanup...
! ndv: Queueing up error report since device installation failed...
ndv: {Core Device Install - exit(0x00000002)} 16:04:50.022
dvi: {DIF_DESTROYPRIVATEDATA} 16:04:50.022
dvi: CoInstaller 1: Enter 16:04:50.022
dvi: CoInstaller 2: Enter 16:04:50.022
dvi: Default installer: Enter 16:04:50.032
dvi: {DIF_DESTROYPRIVATEDATA - exit(0xe000020e)} 16:04:50.032
ump: Server install process exited with code 0x00000002 16:04:50.102
ump: {Plug and Play Service: Device Install exit(00000002)}
ndv: {Update Driver Software Wizard exit(00000002)}
<<< Section end 2016/12/21 16:04:51.584
<<< [Exit status: FAILURE(0x00000002)]
| Kommentaarid: 31 loe/lisa |
29 |
