uus teema   vasta Tarkvara »  Turvalisus »  Veateade märgi kõik teemad loetuks
Taavi_R
Taavi_R
sõnum 06.12.2003 00:42:54 Veateade vasta tsitaadiga
Isal laptopil (Win2k) on mingi imelik probleem.
Polw just 2k kursis. Aga ei lase midagi muuta.
Nagu poleks administraatorina sisse logitud.
Kuigi tal on ainult üks kasutaja. Folder Option´i
ei lase ka ligi.
Veateade on taoline:
"The operatsion has been cancelled due to restictions on this computer.
Please contact your system administrator."
Veel ... Kui internetti tahad minna (läbi IE) siis mingi 30 sekundit on
IE`l all real tekst "Decting proxy settings". Millest see võiks tulla?
raamatupidamine | laadakalender
viimati muutis Taavi_R 06.12.2003 00:53:23, muudetud 1 kord
Kommentaarid: 186 loe/lisa Kasutajad arvavad:  :: 2 :: 3 :: 166
Porno Parm
mugavuspagulane
Porno Parm
sõnum 06.12.2003 00:48:04 vasta tsitaadiga
operetsion
http://www.google.com/search?hl=et&ie=UTF-8&oe=UTF-8&q=The+operation+has+been+cancelled+due+to+restictions+on+this+computer&lr=
proxy eest linnuke ka maha
tundub et peal
Kommentaarid: 66 loe/lisa Kasutajad arvavad:  :: 1 :: 6 :: 47
Taavi_R
Taavi_R
sõnum 06.12.2003 00:53:50 vasta tsitaadiga
Keegi seda esimest veateate lahendust pisut emakeelsemaks ei taha tõlkida?
Porno Parm
mugavuspagulane
Porno Parm
sõnum 06.12.2003 01:07:10 vasta tsitaadiga
ermed
you're receiving the Administrative error, this should be the registry restriction
that has been set. If you have any programs installed (TweakUI) that you have changed,
the setting will return after rebooting. If Pol-edit is installed and you do have
an Administrator, this won't work!
Select Start/Run, type REGEDIT in the 'Open' box and press enter. When Registry Editor
opens, click 'Edit' on the toolbar and then 'Find'. Next in the 'Find what:' window,
type NoSetFolders and press enter. If the entry is found, it will show in
the right pane. Right click it and select 'Delete' from the menu, or select 'Modify'
and change the value form '1' to '0'.
NoSetFolders = enable/disable Folder settings
Taavi_R
Taavi_R
sõnum 06.12.2003 01:21:46 vasta tsitaadiga
