lxgirl
17.10.2016 19:18:02
Arvuti Uuendamine |
Tere
Ärge väga vihastage kui teema valesse kohta tegin
Vaja oleks arvutit uuendada või kui ei saa siis välja vahetada.
Tegin AIDA64 Extreme Edition'iga riistvara raporti
ehk keegi oskab aidata mida antud arvuti juures uuendada.
http://www.filedropper.com/report2
aitäh
Flab
17.10.2016 19:21:51
Koht on okei, aga ülesehitus on jõle sitt. Keegi ei taha midagi alla tõmmata.
Pane enda conf. siia kirja ja siis võib soovitada.
| Kommentaarid: 990 loe/lisa |
782 |
ummy
96 |
lxgirl
17.10.2016 19:50:59
Sooviks uuemaid mänge mängida.
Video:
Video Adapter AMD Radeon HD 7700
Name [SIW] Advanced Micro Devices, Inc. [AMD/ATI] Cape Verde XT [Radeon HD 7770/8760 / R7 250X] [Gigabyte Technology Co., Ltd Radeon R7 200 Series]
Code Name Not Available
Video Processor AMD Radeon Graphics Processor (0x683D)
Technology Not Available
Adapter DAC Type Internal DAC(400MHz)
Emaplaat:
Manufacturer MSI
Model H61M-P31 (G3) (MS-7788)
CPU:
CPU Socket Socket 1155 LGA
Max CPU Speed 3800 MHz
Mälu:
Memory Type DDR3
Installed Memory 8192.0 MB
Device Locator Slot 1
Memory Type DDR3 [PC3-10600]
Manufacturer G.Skill
Model F3-10666CL9-4GBNT
Device Locator Slot 2
1TB WD HD
ja 126 GB SSD
System Summary Top
Property Value
Computer
Manufacturer MSI
Family Not Available
Product Name MS-7788
Model MS-7788
Version 1.0
Serial Number Not Available
SMBIOS Asset Tag Not Available
SKU Number Not Available
Chassis Not Available
PC System Type Desktop
Machine Type AT/AT COMPATIBLE
Firmware Type BIOS
Infrared (IR) Supported No
UUID 00000000-00000000-00008C89-A5C660AE
Windows System Assessment
CPU Score 6.80 (Calculations per second)
Memory Score 7.70 (Memory operations per second)
Graphics Score 7.40 (Desktop performance for Windows Aero)
D3D Score 7.40 (3D business and gaming graphics performance)
Disk Score 6.90 (Disk data transfer rate)
Windows Experience Index 6.80 (Base score)
Disk Space
Disk C: 53.5 GB Available, 111.4 GB Total, 53.5 GB Free
Disk D: 193.7 GB Available, 931.4 GB Total, 193.7 GB Free
Disk E: Not Available
Disk F: Not Available
Memory
Memory 8156 MB Total, 5546 MB Free
Memory Load 32%
Virtual Memory 16310 MB Total, 13484 MB Free
Pagefile
PageFile Name C:\pagefile.sys
PageFile Size 8155 MB
In use 0 MB
Max used 0 MB
Registry Size
Current Size 140 MB
Maximum Size 2048 MB
The system clock interval 15 ms |
ummy
96 |
rewer
17.10.2016 20:01:22
| Oleneb jah eelarvest mida tasuks vahetada aga i5+mingi võimsam kaart peaks olema ok.
| Kommentaarid: 1308 loe/lisa |
922 |
lxgirl
17.10.2016 20:02:51
uue arvuti jaoks olin 1000€ kõrvale pannud
nüüd ei teagi kas vana uuendada või uus osta
Üks tuttav arvas, et vana uuendada oleks odavam
raimzu
17.10.2016 20:07:57
| alles jäta SSD ja HDD (vb ka toide ja kast) aga ülejäänud peaksid uued ostma.
| Kommentaarid: 48 loe/lisa |
45 |
Auron
18.10.2016 09:37:56
Kui sul 1000 eurtsa olemas siis soovitaks kindlasti uuendada.
Vanast kastist saad ju korpuse (kuigi eks natuke oleneb milline on), SSD ja tavalise ketta. Toite kohta ei tea aga kahtlustan, et üleüldine vanus ja kvaliteet on selline mida 1000 eurasesse tutikasse kasti ei tahaks panna.
Seega näituseks: https://www.1a.ee/order/shopping_cart?content=MzQxMzU0sDK0NjQxtzCzBDMsTCAiliamZqZABgA%3D
Ja kasutaja Liiv käest 425.- euraga EVGA GTX1070 SC
Sellisel kooslusega oleks sul sisuliselt tippkomplekt millest parema saaks aint siis kui kulutada juba oluliselt rohkem raha ehk võtta i7 tippprose mis hinnaklasiss 320 eura.- (foorumist kui vaeva näha leiaks ummes 270-280'ga) ja võtta GTX1080 kaart mille enda hind juba pmst 700.-
NÜÜD - kui ei mõista kindlasti mitte kasvõi natukene kellata (kuigi praegu väikest OC'd saab lihtsalt valida biossist ilma pisidetailidesse minemata) ja absoluutselt kindlasti mitte ei hakka kunagi SLI'd tegema siis saaks ka plate hinna umbes 100 peale ehk ligi 50.- eura võitu. Ideena saaks ka 20-30 eura odavama toite võtta aga võrreldes antud isendiga mis on absoluutne tipp ja paarkümmend eura odavam on lihtsalt hea siis ei näe pointi kust pigistada.
Vana plate, prose, mälu ja toide lükka maha - mõnikend eura ikka saad.
133 |
