Ise ootan, et FS hakkaks peale settingutest ON lükkamist ka reaalselt kasutama.
Display settings pole ikka väga kaua olnud- vanast heast CP leiab ainult.
BFV võiks stabiilsemaks FPS minna...
Sul tooks prose vahetus ilmselt stabiilsema fps'i.
auto overclock/undervolt jooksubtab masina lihtsalt kinni, upgrade advisor jääbki skännima. So far ükski uus asi ei tööta, aga noh lihtsalt draiveri uuendusest tuli shadow of tomb raideri benchis 3fps juurde
edit: sain auto asjad tööle. kui mul muidu oc 1600mhz gpu/870mhz hbm2, siis auto tuuning pakub 1500/800.
No need automaatsed asjad pole kunagi "optimaalsed" olnud.
Kõige parem on ikka nüüd see, et saad kõiki core Pstate väärtusi muuta! Nii mhz kui volte, ilma registry SoftPowerPlatTable hackita (OverDriveTooliga sai ennem ainult). Ning see 5 punkti fan curva ka vastavalt tempile
Ning tänu muudetavale P1-P7 väärtustele saab väga täpselt undervoltida/overclockida oma Vega.
Selle üle on mul isiklikult kõige rohkem hea meel. Muidu kasutasin selleks MSI Aferburnerit, aga enam ple selle jaoks otsest vajadust.
See meeldib mulle ka, AGA ma oleks soovinud näha, et curve saab vajadusel nullist alguse või palju madalamalt.
Seda ei saa teha, sest see sõltub jahutusest. Need kelle on olemas see 0db variant (mingi tempi juures vendid seisavad)tehase poolt sisseehitatud siis seal see toimib.
Rayfield was disengaged and very superficial. He would delete all his emails each week that he could not get around reading and would never work weekends or after 5 PM. He would pontificate in an abrassive manner and couldn’t remember any names [ of his peers].
Rayfield denied to Lisa Su that there was a talent problem and that the talent that had recently exited form AMD wasn’t actually an issue. He diend that there was a talent war going on.
He presented suggestions that werent really feasible such as ‘Radeon VII ‘ which was to be a Vega 20 based consumer facing part that cost $750 to build and would barely tie in with an [NVIDIA] GTX 1080 Ti.
AMD muidugi eitab seda. Samas tundub lihtsalt, et inimesel on pere ja ei tahtnud ületunde teha.
Huvitav, AMD-l oli pikalt Vega II plaanis. Siis otsustati, et ainult Navi tuleb ja viimatine Radeon grupist lahkuja oli ka nugade peal selles asjas?
Ja nüüd ikkagi tuleb Vega II. Selline kannapööre oleks arusaadav kui nad said RT mõistlikult tööle...
vaatasid, et nvidia jätkab oma kallite kaartide teemat ja selles hinnaklassis õnnestub vega2 ka antud sektorisse ajada?
või siis olid yieldid paremad kui eeldatud.
_________________ - londiste
Juhul KUI AMD peaks otsustama Vega20 mängukaardi välja tuua siis on neil ~50% (331mm2 vs 487mm2) Väiksem kivi kui Vega10, mis käib umbes 20% kõrgemal taktsagedusel (1500mhz boost vs 1800mhz).
Vega56 on hetkel sama jõudlusega kui RTX2060
Vega20 "56" oleks seega RTX2070 ja RTX2080 vahele.
Vega20 "64" oleks seega RTX2080 juures, võibolla veidi kiirem.
331mm2 Vega20 on samas võrreldes TU106 441mm2 ja TU104 545mm2 märgatavalt väiksem.
