praegune kellaaeg 21.09.2026 07:04:43
27.03.2016 17:48:02
Qualcommilt ametlik teade: Nüüd on olemas 1Gbit/s kiirusega LTE Chip nutitelefonide ja IoT seadmetele |
Seega on koke-kohe käes siis ammuoodatud ja kardetud ning paljude poolt ka vihatud aeg kus mobiilkiirused on muutumas kiiremaks kui on püsiühenduste kiirused.
1. Qualcomm's Latest Chip Provides Gigabit LTE Speeds
Hold on to your data contracts: Qualcomm’s latest modem chip will enable mobile devices to achieve LTE download speeds of up to 1Gbps. Now you just need to find a network that can support it.
The new Snapdragon X16 modem offers what are known as Category 16 LTE download speeds. For normal humans, that means it can provide speeds of up to 1Gbps—2 or 3 times faster than most modern smartphones, which tend to top out at either 300Mbps or 450Mbps. The new chip will also let you upload at speeds of up to 150Mbps.
http://gizmodo.com/qualcomms-latest-chip-provides-gigabit-lte-speeds-1758677631
2. Ja siis ametlik Pressiteade:
Qualcomm Announces Mobile Industry’s First Gigabit Class LTE Modem
Qualcomm Incorporated (NASDAQ: QCOM) today announced that its subsidiary, Qualcomm Technologies, Inc., has introduced its sixth-generation discrete LTE multimode chipset -- the Qualcomm® Snapdragon™ X16 LTE modem, which is built on a leading-edge 14nm FinFET process -- and the Qualcomm RF Transceiver, WTR5975. The Snapdragon X16 LTE modem is the first commercially announced Gigabit Class LTE chipset designed to deliver fiber-like LTE Category 16 download speeds of up to 1 Gbps, supporting up to 4x20 MHz downlink Carrier Aggregation (CA) across FDD and TDD spectrum with 256-QAM, and 2x20 MHz uplink carrier aggregation plus 64-QAM for uplink speeds up to 150 Mbps.
https://www.qualcomm.com/news/releases/2016/02/11/qualcomm-announces-mobile-industrys-first-gigabit-class-lte-modem
puna
27.03.2016 22:33:01
See aeg on reaalselt veel väga kaugel
Tehnoloogia olemasolu ei tähenda veel seda, et mobiilioperaatorid seda kasutusele võtavad
Keegi peab arenduse kinni maksma ja see keegi on kasutaja
Hetkel vingutakse ka paar eur kallima teenuse üle
sa ei või postitada uusi teemasid siia foorumisse sa ei või vastata selle foorumi teemadele sa ei või muuta oma postitusi selles foorumis sa ei või kustutada oma postitusi selles foorumis sa ei või vastata küsitlustele selles foorumis sa ei saa lisada manuseid selles foorumis sa ei või manuseid alla laadida selles foorumis
