Tere!
Üritan siis käima ajada oma isiklikku dyndnsi serverit.
Õpetuseks kasutan seda:
https://www.nooblet.org/blog/2014/self-hosted-dynamic-dns-with-bind9-php/
Masinal peal jookseb webmin/virtualmin
Asjast saan pm aru aga küsimus on hetkel kahes kohas:
Õpetuses on näidatud siin see dnssec võtme lisamine nii:
Create /etc/bind/named.conf.dyndns
// key used by web1.example.com
key "web1.example.com" {
   algorithm hmac-md5;
   secret "f3QY8vTQwgX0mo/7hYUR9m5Vw+X3GsKmRLp850vPTOtgzLmGmIokB9Q1MxYk76CTmVkqPlIyMQxpwizfrLgHsA==";
zone "dyndns.example.com" {
   type master;
   file "/etc/bind/db/dyndns.example.com";
   allow-update {
      key "web1.example.com";
aga ma ei saa seal kasutada    algorithm hmac-md5-te sest siis kukub kohe karjuma:
.. creation failed : dnssec-keygen: fatal: a key with algorithm 'HMAC-MD5' cannot be a zone key
kui nüüd kasutada näiteks:
RSHSHA1
Private-key-format: v1.3
Algorithm: 5 (RSASHA1)
Modulus: yLUWXIhnm+03tZ9QVVgp2BKjK5lNF3eZ43LHpdNplA9E7FDcKgftuYbi8RTkpyp+hE34G+PwC33/+GxUubslveJ0miaynf86vBkrUQlvMHBV8Aun+sHkJ6G68T2d+Ng2Ov5z+hVBFYzkxoRpdYbmGKDCCrF/NNWBSq/j6Y0S4guLc592g/okglwqdm1hzd3rxpoQ/Qswn4VMpwFs9qB0OQ==
PublicExponent: AQAB
PrivateExponent: h5hwBwvQk7Nr07RSHZZ2jpfozOfBAX235cYBw7JUvcajFdR7KZo5rQHICH/JCnbXCqNyX8VawyjY6gimJOSe1u5LQGmsermYAMQwU4tAJ0RK7SUwIcalaAR7EdoYFA4dGXywNtB9ocU4wgJTIJ40t3RutbD55U/UjR+INJMeJAw2xiJV1Fs5TJQQeHh30hbYTtQ1/NjhvEJWqYi/tsrskQ==
Prime1: 7YeiWrWD0u+//Rg+Nmzw9Xd3EzSTIaHflCBX6kzo/F6mHJnfstI1JbRWaJgKO+Cs4OCUSdl+alJHIQlIRfDSL0oZ8kHy80SNJcXtmu6MZm8=
Prime2: 2FBzTwi/YPJxEaYWRD3D9BkRUxsfb3b76OysAUPqVyZeyf6NJL4sc6ZvUjzUjKw5amkdo6Tu4CN6GtANIxR62hSfB+53v77WPV/Tyjj8+49c=
Exponent1: 66YWQhu2bnyAYh29Cs3FuCEPNzR/i2xGnXQBBGfM9SMJdXKK5aN6Kq/g0d+Ut5bMrEThmOp3ag+6lWHaG9kxDM1dNGSNHR8zUPguI/jpvW0=
Exponent2: gedGaBcrvw+5gUzJoG+rRuLq+YqXRRt4kEfRp8/ktizIgEhSAiA727q+WsYheZDkLjRmN3KqoYDpSh+SyvYXzD1FDFMbrUvOapbqNyyaGv8=
Coefficient: rLQ2LhqeRFHCsMarfaORGPhvpuv1zBtkmPx7I5WJGLq5hD6rHSRoXeAzk/Au32WRimGsE/tJMIoagM/eSCkNqk33sIIkIog+R0RUr6T4ljw=
Created: 20171209095101
Publish: 20171209095101
Activate: 20171209095101
seal algorütmina siis kuidas tuleks see võti sinna faili nüüd sisestda mis üleval näites? Või miks see õpetuses antud variant ei toimi nö.
Siis ei saand täpselt sellest ka aru et kuidas ja millised õigused ma sellele DB kaustale annan mis ma sinna bind kausta tegin,
et see asi toimiks kindlasti.
Ning need ip aadressid mis on antud seal õpetuses sisevõrgu omad need tuleb ju mul panna ikka nö välisvõrgu(dns serveri aadressi omad)?
Tänud!
