fred7162
07.03.2016 21:54:48
Probleem heliga |
| Selline kummaline probleem on arvutiga(windows 10), et heli kaob vahepeal ära ja start menüü ja taskbaril olevad ikoonid ei reageeri enam, pärast restarti töötab jälle ilusti. Mingit põhjust pole ma ise suutnud välja mõelda, paistab juhtuvat täiesti suvaliselt. Mõtlesin, et võibolla on mingi probleem helikaardiga või siis kõrvaklapi pordiga aga see ei seleta miks start menüü ja taskbari ikoonid ei reageeri.
trip
07.03.2016 22:08:28
| vaata computer management, event logs-windows logs- system/ application, on seal mingid punased hoiatused/vead
303 |
725 |
fred7162
07.03.2016 22:21:43
| trip kirjutas: |
| vaata computer management, event logs-windows logs- system/ application, on seal mingid punased hoiatused/vead |
Distributed COM:
The application-specific permission settings do not grant Local Activation permission for the COM Server application with CLSID
{D63B10C5-BB46-4990-A94F-E40B9D520160}
and APPID
{9CA88EE3-ACB7-47C8-AFC4-AB702511C276}
to the user NT AUTHORITY\SYSTEM SID (S-1-5-18) from address LocalHost (Using LRPC) running in the application container Unavailable SID (Unavailable). This security permission can be modified using the Component Services administrative tool.
Service Control Manager:
The Sync Host_523ae7 service terminated unexpectedly. It has done this 1 time(s). The following corrective action will be taken in 10000 milliseconds: Restart the service.
The Contact Data_523ae7 service terminated unexpectedly. It has done this 1 time(s). The following corrective action will be taken in 10000 milliseconds: Restart the service.
The User Data Storage_523ae7 service terminated unexpectedly. It has done this 1 time(s). The following corrective action will be taken in 10000 milliseconds: Restart the service.
The User Data Access_523ae7 service terminated unexpectedly. It has done this 1 time(s). The following corrective action will be taken in 10000 milliseconds: Restart the service.
A timeout was reached (30000 milliseconds) while waiting for the User Data Storage_523ae7 service to connect.
A timeout was reached (30000 milliseconds) while waiting for the Sync Host_523ae7 service to connect.
trip
08.03.2016 02:10:40
ei paista sealt midagi huvitavamat
proovi cmd.exe + sfc /scannow
on see puhas w10 install v upgrade?
303 |
fred7162
08.03.2016 14:59:50
| trip kirjutas: |
on see puhas w10 install v upgrade? |
Windows Resource Protection did not find any integrity violations.
Upgrade on.
trip
303 |
Bilderberg
| Kommentaarid: 11 loe/lisa |
10 |
