uus teema   vasta Raud »  Kõvad kettad »  IDE 40-se ja 80-se kaabli vahe ? märgi kõik teemad loetuks
ObiWan Kenobi
sõnum 14.11.2003 22:19:32 IDE 40-se ja 80-se kaabli vahe ? vasta tsitaadiga
Mis vahet on nendel kahel kaablil, lisaks soonte suuremale arvule. Kontaktiosa paistab ju sama olevalt peaaegu.
Let the Force be with You !
Kommentaarid: 22 loe/lisa Kasutajad arvavad:  :: 1 :: 0 :: 20
SCREAMER
SCREAMER
sõnum 14.11.2003 22:46:24 vasta tsitaadiga
40-se läbi lase kiirus 33 mb/s, 80-se kuni 133 mb/s
Kommentaarid: 442 loe/lisa Kasutajad arvavad:  :: 1 :: 2 :: 394
cbr
cbr
sõnum 16.11.2003 16:54:46 vasta tsitaadiga
80-sooneline toetab Ultra DMA transfer mode't. 40-sooneline mitte.
The obvious question, of course, is this: what's the point of adding 40 extra wires to a cable if they aren't connected to anything? :^) Well for starters, the 40 wires are connected to something, just not their own pins on the interface connectors. The extra 40 wires don't carry new information, they are just used to separate the "real" 40 signal wires, to reduce interference and other signaling problems associated with higher-speed transfers. So the 40 extra conductors are connected to ground, interspersed between the original 40 conductors of the old cable. Any stray signals that would "cross-talk" between adjacent wires on the 40-conductor cable are "absorbed" by these extra ground wires, improving signal integrity. The extra ground wires can be either all of the even-numbered wires, or all of the odd-numbered wires in the cable.
Loe siis rohkem:
40-sooneline
80-sooneline
Kommentaarid: 48 loe/lisa Kasutajad arvavad:  :: 0 :: 0 :: 39
konn
konn
sõnum 16.11.2003 16:56:36 vasta tsitaadiga
kuna 2 t2pselt sama teemat siis ma ei hakka ennast kordama
https://foorum.hinnavaatlus.ee/viewtopic.php?t=67102&highlight=
Kommentaarid: 49 loe/lisa Kasutajad arvavad:  :: 0 :: 3 :: 41
ObiWan Kenobi
sõnum 16.11.2003 17:17:53 vasta tsitaadiga
Tnx , Cobra - see oli just see õige vastus mida otsisin.
Computer Doctor
sõnum 16.11.2003 17:26:35 vasta tsitaadiga
Lühidalt maakeeli niipalju juurde, et 40 soonelist juhet võid panna kumbapidi soovid, kuid 80-se korral tuleb kindlasti jälgida värvikoodi s.t. et sinine pistik peab minema emaplaadil olevasse IDE pessa ning must pistik Master-ketta külge.
Ja soovitus - HDD korral tasuks 40 sooneline kabla "üldse ära unustada" ning kasutada 80 soonelist kablat thumbs_up.gif
Karel
Karel
sõnum 16.11.2003 17:59:02 vasta tsitaadiga
Kas polnud mitte nii, et 80-soonelisel kaablil oli emaplaadile minevas pistikus üks auk kinni topitud ja seetõttu ta vanemale emaplaadile (ajast mil oli ainult 40-sooneline kaabel) lihtsalt ei läinud sisse? Või oli siis see defektne kaabel...
