praegune kellaaeg 27.06.2026 21:26:56
_Knight_
14.10.2015 15:42:40
Deus Ex: Revision mod |
veebileht
Kuna mängul endal threadi ei olnud, tegin eraldi.
Deus Ex: Revision is a community-made overhaul of the 2000 classic. It features new environments, new music, and new world-building detail. It also bundles in some of the best modifications that the fanbase has made over the years, including Direct3D 9 rendering, high-resolution textures, high-detail 3D models, and alternative gameplay modes.
Key features:
*Locations throughout the game world have been re-designed with new aesthetic and gameplay detail.
*A new soundtrack has been composed by the symphonic electronica duo EdenShard, based on the original score.
*High Resolution Textures courtesy of New Vision.
*High Detail 3D models courtesy of Project HDTP.
*Direct3D 9 Rendering courtesy of Chris Dohnal.
Deus Ex: Revision mod steam link
Hetkel saab mod mängida ainult steami kaudu. Kellel veel mingi imeläbi mängu steamis ei ole, hetkel mäng 80% off = 1.39 eur
On olemas ka workaround, mitte steam versioonile. Quote moddb lehelt:
Hey folks...since there are some people who own cd/gog version of Deus Ex and don't intend to buy it again (me included..and no money is not the issue here) ...well guess what...no steam version needed.
Use the standalone installer (from ModDB page) and ignore steam at the end.
Then download Kentie's launcher http://kentie.net/article/dxguide/index.htm , extract it into your Deus Ex/System.
Make a copy of the Deusex.exe and rename it to Revision.exe
Now run the Revision.exe..configure it how you see fit...and finally in Data Directories make sure to check everything..you can uncheck BioMod and/or Shifter if you don't want to play with them.
..and that's it. have fun. In case you have no music in game...check if you have a Deus Ex folder in your Documents. If you do delete it and try to run the game again. |
| Kommentaarid: 10 loe/lisa |
10 |
| Kommentaarid: 92 loe/lisa |
Vael
30.09.2025 15:52:08
| Just lõpetasin MD ua mõtlesin, et kõik teised mängud Remasteri saanud aga see 2000ndate klassika mitte;)
| Kommentaarid: 17 loe/lisa |
16 |
Prozer
| Kommentaarid: 69 loe/lisa |
68 |
MatchMaker
