praegune kellaaeg 09.11.2026 18:06:23
szd4
28.03.2015 13:43:31
Android Kitkatil automaatne lennurežiim |
Tere
Kasutan Kitkati ja lugesin netist, et mu 10 automaatse lennurežiimi appi ei tööta kuna:
| No, Tasker cannot do this under KitKat or even (pretty certain) Jelly Bean. The latest versions of Android OS have moved Airplane mode into the "protected" settings group and apps cannot change this mode. Some can do it only if the phone is rooted but I don't believe that works either with KitKat 4.4.2. |
Kas keegi teab kuidas saada selle settingule luba. Hetkel appid lihtsalt jooksevad kokku lülituse hetkel/ei toimi.
| Kommentaarid: 30 loe/lisa |
30 |
eckh
30.03.2015 13:26:03
| Taskeriga airplane mode lülituse käima saamiseks tuleb teha root ja installida secure settings.
103 |
