ABC
08.03.2015 12:14:37
Ülevaade: Kingston HyperX Cloud II virtuaalne 7.1 peakomplekt mänguritele |
Kingston on tuntud oma mälude ja muude sarnaste toodete poolest. Eelmine aasta hakati tootma ka väliseid lisaseadmeid mänguritele nagu kõrvaklapid ja hiirematid. HyperX Cloud II paisati müüki 9. veebruaril ja välimuselt sarnaneb see äravahetamiseni oma eelkäijaga, erinevus peitub aga sisemuses.
Cloud II puhul on tegu suletud virtuaalse 7.1 peakomplektiga.
Tehnilised andmed, funktsioonid:
FEATURES/BENEFITS
> Audio experience — hardware-driven virtual surround sound
> Comfortable — 100% memory foam on headband and
leatherette cushions
> Pro-gaming optimised — closed-cup design for passive noise
cancellation
> Compatible — USB connectivity for PC & Mac. Stereo compatible with
PS4, Xbox One1 and mobile
> Guaranteed — two-year warranty, free technical support
SPECIFICATIONS
Headset:
> Transducer type: dynamic Ø 53mm with neodymium magnets
> Operating principle: closed
> Frequency response: 15Hz–25,000 Hz
> Nominal impedance: 60 Ω per system
> Nominal SPL: 98±3dB
> THD: < 2%
> Power handling capacity: 150mW
> Sound coupling to the ear: circumaural
> Ambient noise attenuation: approx. 20 dBa
> Headband pressure: 5N
> Weight with microphone and cable: 320g
> Cable length and type: 1m + 2m extension
> Connection: single mini stereo jack plug (3.5 mm)
Microphone:
> Transducer type: condenser (back electret)
> Operating principle: pressure gradient
> Polar pattern: cardioid
> Power supply: AB powering
> Supply voltage: 2V
> Current consumption: max 0.5 mA
> Nominal impedance: ≤2.2 kΩ
> Open circuit voltage: at f = 1 kHz: 20 mV / Pa
> Frequency response: 50–18,000 Hz
> THD: 2% at f = 1 kHz
> Max. SPL: 105dB SPL (THD≤1.0% at 1 KHz)
> Microphone output: -39±3dB
> Length mic boom: 150mm (include gooseneck)
> Capsule diameter: Ø6*5 mm
> Connection: single mini stereo jack plug (3.5mm)
Välimine karp on kena, selge kirjaga ning taaskasutatav.
Sisemise karbi kaan on pealt tõstetav, pakkimiseks on kasutatud kvaliteetset poroloni mida ümbritseb tugev pappkarp.
Karbis on kiirjuhend kasutamiseks, juhend informatsiooni hankimiseks, lennuki adapter, mikrofon, kott hoiustamiseks või kaasas kandmiseks, USB helikaart(edaspidi ka juhtpult) ja peakomplekt ise. Kaasa tulevad ka vahetatavad kõrvapadjad, millel on veluurist kate. Algselt on peakomplekti külge paigaldatud nahast kattega padjad.
Kaasa tulev kott on väga kasulik, ise kasutasin seda klappide kandmise asemel tahvelarvuti kandmiseks ning see toimis väga kenasti.
Sellel on 2 taskut- üks suur kõrvaklappide jaoks ja umbes poole väiksem muu tavaari jaoks.
Minul lennuki adapteriga midagi peale hakata pole aga kui peaks vaja minema, siis nendel klappidel on selline vidin kaasas.
Pole küll kullatud kuid arvan, et see ei oma siin erilist tähtsust.
Lisana kaasas olevad kõrvapadjad võimaldavad vestlust arendada ka kõrval seisvate inimestega ilma, et peaks klappe peast võtma.
Nahast kattega patjadega on see veidi keerulisem.
Patju on lihtne vahetada – Nahast patjade peale panemine võtab ligikaudu poolteist minutit ja veluurist patjadele kulub 2 minutit.
Usun, et see ajavahe tuleb sellest, et nahast klappidel on vahele venitatav osa nahast, veluurist patjadel on see kummi-kile-plastiku segust.
Kuigi ise eelistan nahast patju, on ka teine variant varuks väga teretulnud.
Juhtpuldi kaudu saab vaigistada mikrofoni ja muuta helitugevusi. Puldi keskel on „7.1“ nupp, mis lülitab sisse või välja virtuaalse 7.1 surroundi.
Kui see on sisse lülitatud, kumab see nupp punaselt. Punaselt põleb ka HyperX kiri kui klapid on USB kaudu ühendatud.
Toimimiseks läheb vaja vaid draivereid, mis automaatselt klappide ühendamisel laaditakse. Ühtegi teist tarkvara antud klappidele ei eksisteerigi.
USB helikaart täidab oma ülesannet, kuid minu jaoks on sellel mõningad puudujäägid.
Nimelt näpits selle tagaküljel on särgi külge kinnitamiseks, mul oli selle kasutamine ebamugav kuid mõnele teisele, kes klappe katsuda sai meeldis see variant.
Läbi OTG juhtme katsetasin, kuidas klapid töötavad läbi helikaardi Nexus 7 tahvliga. Kõik töötas nii, nagu pidi.
Mikrofon on painutatav ning hoiab peale painutamist kenasti sellele antud kuju. Helikvaliteet on hea, kuid vahest võib mürasummutus ka peakomplekti kandjat vaigistada nt. ülipikkade häälikute puhul (Rääkides seda ei kohanud, kuid oma mängukaaslastele laulda nende klappidega ei saa).
Mitmetunniste Skype kõnede puhul anomaaliaid ei kohanud. Kõne teine pool kiitis mikrofoni taevani.
Kaasas olev mikrofon käib klappide küljes olevasse pesasse.
Mikrofoni ühendamiseks tuleb täielikult eemaldada pisike kummist kaitse klappide küljest.Nagu pisikeste asjade puhul ikka, on ka sellel tavaks ära kaduda.
Koostekvaliteet on väga hea – Palju alumiiniumit, siidise tekstuuriga korralik plastik, mis õnneks ei võta ka näpujälgi külge.
Peatoel on täies pikkuses nahast kattega pehme padi, mis on kena kontrastse õmblusega ühendatud teisel pool oleva nahast kattega.
Klapid istuvad minu pähe nagu valatult. See on esimene peakomplekt mille puhul pole kõrvad või pea valutama hakanud.
Selles mängib kindlasti rolli pehmendus kõrva ja plastiku vahel, mida paljudel klappidel lihtsalt ei ole.
Survet klappide poolt on tunda vaid kõrvade ümber, mujal ei ole see eriti tajutav.
Mikrofoni pesa kõrvalt tuleb välja ühe meetrine juhe, mida ei saa eemaldada.
Selle juhtme saab ühendada kas helikaarti, mis on USB’sse ühendatud või kasutada ilma kaardita. Kui klapid pole ühendatud läbi kaardi, siis on 7.1 asemel lihtsalt stereo.
7.1 nupp juhtpuldil annab muusikat kuulates mitmekesisema helipildi ja olenevalt lindistusest võib kuulda ka surround-heli.
Mängudega täpselt samuti, olenevalt mängust on klappide 7.1 funktsioonist kasu. See eeldab, et mängule on vajalikud sätted sisendatud.
Eriti paistis silma klappide vägevus NFS Carbonis - vana mäng aga siiski. Driftimise tegi see ülilõbusaks. Tuli kasu ka mõnes FPS mängus aga elamusele see nii palju neis juurde ei andnud kui eelmainitud Need for Speed'is.
Helipildis oli veidi rohkem kesk- ja kõrghelisi, madalad tundusid muule natuke alla jäävat.
Minu eelistatud helipilt on õrnalt kaarjas, kus madal- ja kõrgsagedusi on veidi rohkem kui kesksagedusi.
Et need klapid oleks mulle veel rohkem meele järele, peaks sellel olema vähemalt natukene rohkem madalsagedusi.
Minu arvamus klappidest kipub sinna hea-väga hea vahele jääma ehk esinevad mõningad pisihädad, mis varjuvad rohkelt ülekaalus olevate plusside taha.
Väga mugavad
Väga hea koostekvaliteet
Korralik karp, vahetatavad kõrvapadjad, kott ja muud lisavidinad
Virtuaalne 7.1 surround-heli ja hea heli kvaliteet
Saab kasutada ka ilma USB helikaardita (Stereo heli)
Mikrofoni helikvaliteet on päris hea
Kõik kaablid on sleevitud
Mina eelistaksin laual püsivat juhtpulti kerge ja kaasaskantava asemel
Minu jaoks on juhe liiga pikk, ning enamus sellest seisab laual ja võtab ruumi
Tarkvara puudub
Bassi natuke vähe minu kõrvade jaoks
Pisike mikrofonisisendi kaitsekate kaob kergesti ära
Sooviksin tänada Kinston'it, kes oli nõus mulle selle toote ülevaate kirjutamiseks saatma.
Eestis on see peakomplekt HinnaVaatluse andmetel müügil Arvutitargas, Surfdatas, Galadoris, Neostore's ja Digisalongis.
PS! Toode, millest ülevaadet lugesite on Cloud II mitte Cloud.
https://www.hinnavaatlus.ee/products/pricelist/?Product=hyperx%20cloud
Vabandan, et ei tõlkinud tehnilisi andmeid. Mina nende tõlkimisel mõtet ei näe.
Toode tootja lehel: http://www.kingston.com/en/hyperx/cloud#hscp
Teabeleht: http://www.kingston.com/datasheets/KHX-HSCP_en.pdf
Kasutusjuhend: http://media.kingston.com/support/downloads/HX_Cloud2_Headset_Manual.pdf
Tehniline tugi: http://www.kingston.com/en/support/technical/products?model=KHX-HSCP
viimati muutis ABC 09.09.2015 21:48:13, muudetud 4 korda |
| Kommentaarid: 11 loe/lisa |
-FoX-
08.03.2015 13:02:33
Ma vaatasin youtubest siis öeldi, et bass ja muidu ka helid lähevad väga heaks kui võimendust kasutada.
Mingi väike AMP vahele ja peaks hea olema.
Nad kasutavad seda bayerdynamicu tehonooligat vms.
_________________ Aita suve, söö lund! |
| Kommentaarid: 366 loe/lisa |
6 :: |
307 |
Syncmahv
08.03.2015 13:10:02
| Kas elemente on tal füüsiliselt siiski 2 ?
102 |
ABC
08.03.2015 13:24:43
Selline tekst Cloud I kohta nende pressiväljaandest“HyperX worked with Swedish manufacturer QPAD to create a headset that delivers comfort and superb sound for long game play. This is a winning combination as QPAD is known for high-quality gaming peripherals throughout Europe,” said Lawrence Yang, business manager, HyperX. “We think the hours will pass by without notice as gamers wear the HyperX Cloud headset.”
Jah, elemente on kaks. Lõik teabelehelt "HyperX Cloud II is Hi-Fi capable, with 53mm drivers for superior audio performance
and rich sound quality with crystal-clear low, mid and high tones and enhanced bass
via the sound card."
LKits
| Kommentaarid: 13 loe/lisa |
haldz
08.03.2015 17:04:05
Endal suts vanem versioon aga kiita võin. Bass on hea kui korralik võim või helikaart. Ise kasutan Asus xonar Stx taga ja bassi piisavalt.
Mujal katsetades oli palju vähem.
| Kommentaarid: 153 loe/lisa |
138 |
ABC
08.03.2015 18:54:21
Logitechi marketing osakonnaga oli millalgi ühendus. Võin järele uurida, kas saaks võrdluseks.
Haldz, sa võiks rääkida erinevustest, mis silma jäid ülevaadet lugedes. Cloud I vs Cloud II.
Sooviks teilt ka tagasisidet ülevaate enda kohta - mis kuidas meeldis, mida võiks rohkem või vähem olla ning mis üldse välja jäi.
haldz
08.03.2015 22:26:16
| ABC kirjutas: |
Sooviks teilt ka tagasisidet ülevaate enda kohta - mis kuidas meeldis, mida võiks rohkem või vähem olla ning mis üldse välja jäi. |
Isiklikult oman Cloud I.
Minu arust II hetkel nagu tundub suht paberi sepc järgi vaadates sama .
Klapid on oma raha väärt, ei oska kommenteerida kas see usb helikaart annab 60ohm välja jne.
Kinnitada võin et bass on parem kui on korralik helikaart või peasi et korralik klapi võim on.
See jutt et keera equalizerist bassi peale on jama saad aint moonutatud heli.
Cloud I
Kuulokkeiden tyyppi: korvan ympärille asetettava
Pehmustettu nahkainen pääpanta sekä viskoelastiset korvatyynyt
Suljettu rakenne vähentää taustamelua jopa 20 dBa
Taajuusvaste 15 - 25 000 Hz
Nimellinen impedanssi 60 Ohm
Nimellinen herkkyys: 98 ± 3 dB
Kuulokekupin sisähalkaisija: 53 mm
Mikrofonin taajuusvaste: 100 - 12.000 Hz
Mikrofonin herkkyys: -39 ± 3 dB
Mikrofoni varren pituus: 150 mm
Paino (kaapelin ja mikrofonin kanssa): 350 g
Kaapelin pituus 1 m + erillinen 2 m jatkojohto
Liitin: 2 kpl Analoginen 3,5 mm liitin
Cloud II
Surround Sound 7.1
Mikrofonin taajuusvaste: 50 - 18.000 Hz
Paino (kaapelin ja mikrofonin kanssa): 320 g
Liitin: USB, analoginen 3,5 mm liitin
Verkkokaupast lõigatud, keda tekst häirib siis vabandan.
Ülevaade hästi kirjutatud!!
Meeldib stereo ka muidugi, et surroundi meestega vaielda ei viitsi
138 |
Scart
11.03.2015 09:58:41
Huvitav ning põnev ülevaade. Kindlast jääks ootama ka teiste samataoliste surround-klappide ülevaateid, kui õnnestub need hankida
101 |
angel
11.03.2015 10:24:44
Väga palju on kirjutatud ainult sellest, mis pakendis on ja kuidas peast istuvad aga reaalselt seda kuidas asjad toimivad nagu juttu ei olegi
"Kui mängudes oli vastaste asukohta vaja kindlaks teha, siis 7.1 nupust kasu mul polnud. " -> sellest lausest saaks aru nagu, et neist klappidest ei ole muhvigi kasu. Kui antud nuppu ei vajuta siis 7.1 virtualiseerimist ei toimi ja klapid töötavad stereo mode´is ?
"7.1 nupp juhtpuldil annab mitmekesisema helipildi kuid surround-heli eriti tunda ei saa. " -> see lause nagu kinnitaks väidet.
Veider ülevaade.
157 |
ABC
12.03.2015 12:42:16
angel, Kui nuppu vajutatud pole siis 7.1 on välja lülitatud.
Muus osas ongi täpselt nii nagu kirjas. Annab mitmekesisema helipildi (muusikat palju mõnusam kuulata) kuid mängudes pole neist kasu.
Räägi siis täpsemalt, mida teada tahaksid? Kõike saab ju ülevaatesse lisada.
LKits
ABC
12.03.2015 13:12:09
Proovisin erinevaid FPS-e, ilma seda funktsiooni kasutamata oli selgelt aru saada, kust tulevad, selle funktsiooniga tekkisid valearusaamad.
Süvenen täna uuesti sellesse ja annan teada.
LKits
12.03.2015 13:21:53
Mängus "built-in" surround on kohe kindlasti parem, kui illusiooni läbi tekitatud virtuaalne surround.
Ma lihtsalt ei saa aru, kas on tõesti raske mängumootorisse sisse ehitada X-helikanaliga lahendust? Kasutaja määrabki ära mitu kanalit ta väljundseadmetel on ja vastavalt sellele siis mängumootor genereerib 3D heli.
Kui ukse kriuksumine tuleb "kella nelja" suunast, siis nii ongi. Ei ole "kella kuue" ega ka "kella kolme" suunast. Ning mängumootor peakski selle siis vastavalt väljastama, millistesse kõlaritesse/elementidesse ning mis helitugevusega.
Ma usun, et tegelikkuses nii ongi, aga nii mõnedki mängud lihtsalt ei toeta surroundi. Liiga nišiteema.
angel
12.03.2015 13:45:53
Kui sellist toodet poodi ostma läheks siis eeldaks, et saan nende abil mängudes helis virtuaalse 7.1 elamuse. Kui seda ei saa ja parem on steroe mode'is asja kasutada siis võiks öelda, et antud tööde on täiesti läbikukkunud ja ... jura. Hetkel pakuvad mitmed tootjad 5.1 või 7.1 virtuaal heliga klappe.
Ehk olid helikaardi, mängu sound settingud määratud valesti? Ehk siis oli stereo mode'i peale jäänud vms mitte sobivat.
Ise oman speedlink väga vana kooli 5.1 kõrvaklappe kus kõik kanalid peaks olema eraldi ja väga täpselt sai aru kus keegi tuleb, pms nagu 5.1 kõlari komplekt oleks peas istunud. Ainult helikvaliteet jätab soovida võrreldes korraliku 2.0 klappi või välise 5.1 kõlari süsteemiga.
Välismaised reviewd igatahes kiidavad antud klappe. Seega ootaks review'sse täpsemat testimist virtuaal ruumilise heli toimimise kohta. Mängud, filmid.
157 |
12.03.2015 13:51:19
| LKits kirjutas: |
See on küll veider, et mängides kasu pole...
Kas tänapäeval mängumootorid ei suudagi tekitada 3D-mootoriga surround heli efekti? |
Mängumootorid suudavad, aga see eeldabki seda, et sa kasutad klappe stereo reziimis nii nagu mäng seda eeldab.
| Kommentaarid: 85 loe/lisa |
ABC
17.03.2015 00:01:12
angel, Parandasin sinu väljatoodud kohta vastavalt testimisele.
Filmides ei ole siiani tuvastanud erilisi muudatusi surroundi ja stereo vahel, mõni üksik detail.
arny
22.04.2015 16:08:13
| olude sunnil sain neid klappe paar tundi kasutada. Välja näevad head, eriti pakend, peas tunduvad kah mõnusad. Kuna ise kasutan arvuti taga pioneeri se-me290 klappe siis saan aint nendega võrrelda. Raskus on neil suht sama, pioneerid on kuidagi kergemad peas, kõrvade ümber on kingstonil suurem surve aga see võib ka sellest olla, et uued lihtsalt. Heli poolest raske võrrelda kuna pioneerid on audio ja kingstonid mänguri klapid. Aga no mulle see mänguri heli kvaliteet ei meeldinud. Tundusid aint kõrged helid olema, bassi oli väga vähe. Ilmselt aitab jah mingi helikaart kus saab EQ sättida. Mängudes tundus, et minu vanad pioneerid annavad mulle rohkem infot kui see 7.1. Filmide ja muusika puhul samuti. Teatud lugude puhul andis see 7.1 lihtsalt sellist imelikku kaja taustale mis isegi häiris mind, kuna kõlas ebaloomulikult. Aga see läbi minukõrvade ja võrreldes audio klappidega. Vennal on corsairi mängurid, eks mingi aeg proovi läbi nende heli kuulata eks siis kuulen vahet. Hetkel jään ise ikkagi audio klappidele truuks, korralik heli jne. See real 5.1 või 7.1 on ehk parem kui virtual 5.1 või 7.1 aga ei tea, kui bassi ei ole siis on jama. Milleks toota klappe mis vajavad paremaks heliks eraldi võimendit või helikaarti. Audio klappidega mul pole midagi vaja. Kunagi olid mul sony audiod siis pioneerid on selles osas ikka paremad kui sonyd olid. Aga nagu ütlesin läbi minu kõrvade ja võrreldes audio ja mänguri klappe. Mänguri klappide seltskonnas on võibolla tõesti head.
| Kommentaarid: 10 loe/lisa |
9 |
Diesel
30.04.2015 19:08:09
Enda HyperX Cloud II klappidel USB controllerit kasutades veider staatiline ja prõksuv heli juures.
Otse Maximus Hero VII taha lükates ilma controllerita heli oluliselt puhtam.
Ei tea, kas tegemist praagiga, või kõik HyperX Cloudid sellised?
| Kommentaarid: 37 loe/lisa |
37 |
ABC
30.04.2015 20:45:55
| Diesel, Mina sellist asja ei täheldanud.
Markokene
01.07.2015 10:24:34
| Mul on ka need klapid olnud ja ütleme nii, et pettumus. Need on mugavad, aga lähevad kergesti katki, mikrofoni võimsust ei saa muuta, helikaardist tuleb alati juhe välja. Võibolla on asi minus
| Kommentaarid: 6 loe/lisa |
ABC
01.07.2015 11:59:37
Markokene, Räägi täpsemalt oma kogemustest, siis on teistel ka kasu.
Kust need katki läksid, kaua selleks aega kulus jne.
Mina müüsin enda omad ära ning olen ka väga pettunud (endas) - ei oleks ikka pidanud müüma.
Markokene
01.07.2015 14:51:31
| Juhtmest läks lambist katki. Ei tea milles viga. Tundub nagu midagi on lahti.
ABC
01.07.2015 22:54:21
| Juhe läks katki või arvad, et juhtmes on viga?
Markokene
02.07.2015 10:53:40
| ABC kirjutas: |
| Juhe läks katki või arvad, et juhtmes on viga? |
Ei oska isegi öelda. Tundub nagu oleks juhtmes viga. Peaksin kuhugile linna teise otsa ka veel minema, et neile pakk oma kõrvaklappidega. Ennem nemad uusi ka ei saada. Kui küsisin, et mis tegema peab siis nemad ainult rääkisid, et vaata ups kodulehelt.
