praegune kellaaeg 21.09.2026 08:40:38
13.01.2015 14:28:30
Linus Torvalds Says Apple's HFS+ Is the Worst, Probably Designed by Monkeys |
Lugege ja otsustage ise, et kas on nii nagu Linus pajatab või siis ei ole...
Ja eks näis kas siis Apple ka sellele vastab või ei lasku sõnasõtta.
He used a lot of other expletives that can't be reproduced
Linus Torvalds doesn't usually talk about things he doesn't know, so it's probably fair to imagine that, when he says that the HFS+ file system used on Mac OS X is garbage, he's not wrong.
The discussion regarding the HFS+ file system started after the Git developers found out that there was a problem. Apparently, both the NFTS and HFS+ file systems are case insensitive, and that creates a problem. The devs had to release a new version of Git a while ago that was only fixing the problems only for Windows and Mac OS X system. Linux was not affected.
This was basically a security issue, which was best described in CVE-2014-9390, and the fix for it was made available a few weeks ago. Linus also made some comments about that problem and he did more than just detail the issue. He explained point by point why HFS+ is the worst file system in existence right now and why Apple doesn't really want to fix it.
Linus Torvalds is seldom wrong
The creator of the Linux kernel and Git says a lot of things that are not too popular with some of the users, but that doesn't mean he knows not what he's talking about. In fact, he probably has a better grasp of file systems than many other developers, given the fact that the Linux kernel is built to run on pretty much anything and that he's pulling FS patches all the time.
"Quite frankly, HFS+ is probably the worst filesystem ever. Christ what [expletive] it is. NTFS used to have similar issues with canonicalizing utf8 (ie using non-canonical representations of slashes etc). I think they at least fixed them. The OS X problems seem to be fundamental. "
"The true horrors of HFS+ are not in how it's not a great filesystem, but in how it's actively designed to be a bad filesystem by people who thought they had good ideas. The case insensitivity is just a horribly bad idea, and Apple could have pushed fixing it. They didn't. Instead, they doubled down on a bad idea, and actively extended it - very very badly - to unicode," wrote Linus on Google+.
He continued to explain some of the bad decisions taken by Apple in regards to HFS+, including issues with NFD normalization. The conclusion is that Apple probable let monkeys code for the file system.
http://news.softpedia.com/news/Linus-Torvalds-Says-Apple-s-HFS-plus-Is-the-Worst-Probably-Designed-by-Monkeys-469801.shtml
iFlop
13.01.2015 15:07:59
| See ei tohiks nüüd küll eriline uudis olla, et HFS+ pole just kõige modernsem failisüsteem. Aastal 2007 oleks Apple peagu selle ZFS'i vastu välja vahetanud, aga paraku nii ei läinud.
ThedEviL
13.01.2015 16:21:06
Kogu häda ongi selles, et ta pole case sensitive??
Suur hunnik vingumist, aga reaalset viga pole välja toodud....
ThedEviL
13.01.2015 17:02:16
Dogbert, seal on vingumine GIT'i üle, et see paneb case insensitive failisüsteemidel segast.
Umbes selline teema, et naelrehvid on kehvad kuna 300kmh kiiruse juures plahvatavad.... Who cares...
Milles ikkagi probleem on, miks HFS+ ei sobi kasutajale, kes ei tea git'ist midagi?
sa ei või postitada uusi teemasid siia foorumisse sa ei või vastata selle foorumi teemadele sa ei või muuta oma postitusi selles foorumis sa ei või kustutada oma postitusi selles foorumis sa ei või vastata küsitlustele selles foorumis sa ei saa lisada manuseid selles foorumis sa ei või manuseid alla laadida selles foorumis
