praegune kellaaeg 21.09.2026 08:39:07
15.11.2014 21:01:51
Leiutavad: Wet iPhone? Patented Solution Sucks the Water Out of Your iDevice, Restores Everything – Gallery, Video |
Taas leiutatakse - kes tahab, see usub ja kes ei taha, see ei usu...
A company called TekDry claims to have found the best solution to drain the water out of a device, restoring its functionality, and saving the content stored on its memory bank.
TekDry’s patented solution will allegedly repair your water-damaged phone in just 20 minutes, restoring contacts, pictures, and every type of media that used to be in there.
“One satisfied customer at a time, TekDry's goal is to recover every wet, non-working phone. In only 20 minutes, TekDry can fully restore your water damaged phone back to its previous condition through our exclusive patented process. This means contacts, photos, emails, everything...as if it never happened,” the company says on its web site.
The DOs and DON’Ts
If you’ve accidentally submerged your iDevice in water, TekDry says the safest bet is to do nothing to it and just send it over to them. They say sending it in under 48 hours is crucial (so that the water doesn’t have time to do damage), and you’ll only be paying for the service if they manage to save the device.
“Do NOT plug in your phone if it gets wet - this is critical to recovering your phone! Call TekDry before you try rice! We offer a zero risk model so you only pay when we recover your phone,” says the company. “The most successful recoveries are devices that we receive within 48 hours from getting wet.”
Under no circumstances should the user attempt to turn it back on or plug it in a computer or a charger. The one good thing a tech savvy user can do is remove the battery, if they have the necessary tools and knowhow. If not, it’s best just to leave it like that and send it in as soon as possible.
Rice is also no good
The firm also says not to rely on rice. While it’a proven method of sucking water out of things, it’s also very slow-acting. As noted by TekDry, time is of the essence, “It is critical to get the moisture out quickly to increase the chances of your phone working again,” the firm stresses.
Finally, TekDry says its service isn’t limited to any device brand or type. You can send in any smartphone, tablet, or even a computer and let them repair it for you.
The videos below show parts of the process, but TekDry is reluctant to offer more details, such as what exactly is being used to force the water out of the device. The image gallery below also includes more DOs and DON’Ts
Jutt ja videod siis lingil:
http://news.softpedia.com/news/Wet-iPhone-Patented-Solution-Sucks-the-Water-Out-of-Your-iDevice-Restores-Everything-465025.shtml
sa ei või postitada uusi teemasid siia foorumisse sa ei või vastata selle foorumi teemadele sa ei või muuta oma postitusi selles foorumis sa ei või kustutada oma postitusi selles foorumis sa ei või vastata küsitlustele selles foorumis sa ei saa lisada manuseid selles foorumis sa ei või manuseid alla laadida selles foorumis
