praegune kellaaeg 21.09.2026 08:39:47
01.11.2014 00:17:04
DARPA creates first 1THz computer chip, earns Guinness World Record |
DARPA, the US military’s R&D division, has been awarded a Guinness World Record for creating the world’s fastest solid-state chip, clocked at one terahertz — or 1,000 gigahertz, if that’s easier to digest. DARPA’s chip handily beats out the previous record holder, which was only capable of a paltry 850GHz. Computers and radio systems that operate up in the terahertz range have some very interesting and powerful properties, from the creation of hand-held tricorders and security scanners, through to wireless networks that are hundreds of times faster than 2.4 and 5GHz WiFi.
DARPA has been interested in terahertz chips for a long while now — not so much for super-fast computers (though they are being looked at), but for creating radio waves in the sub-millimeter-wave terahertz range. These waves (sometimes called T-rays), as far as the military are concerned, are a prime way of supercharging everything from radar, to imaging and reconnaissance, to ultra-high-bandwidth wireless networks. Basically, because the wavelength of T-rays are so short (less than a millimeter), they can provide much higher resolution than, say, conventional radar, which uses frequencies of a much longer wavelength (anywhere from 100 meters to a few centimeters). The density of T-rays makes them very good for carrying large amounts of data, too — and, as an added bonus, they’re very good at safely penetrating a few millimeters of skin (yes, airports are interested in terahertz security scanners).
Edasi juba jutt ja pildid siis lingil:
http://www.extremetech.com/extreme/193343-darpa-creates-first-1thz-computer-chip-earns-guinness-world-record
sa ei või postitada uusi teemasid siia foorumisse sa ei või vastata selle foorumi teemadele sa ei või muuta oma postitusi selles foorumis sa ei või kustutada oma postitusi selles foorumis sa ei või vastata küsitlustele selles foorumis sa ei saa lisada manuseid selles foorumis sa ei või manuseid alla laadida selles foorumis
