praegune kellaaeg 18.11.2026 01:26:43
McKlein
21.10.2014 16:49:18
C++ stack loomine |
Tere, jah, tegu on koolist saadud ylesandega ja ma olen selle siia maani (ehk ka korrektselt) ara lahendanud, aga nüüd sai moistus otsa ja ei ole yhetgi edasiaitavat opetust leidnud.
CStaticStack.h faili sisu on jube eelnevalt ette antud ja selles ei peaks muudatusi tegeam, kui just ei ole hadavajalik.
Ma ei tea mida voi kuidas deklareerida stack´i, et sisestada CComputer klassi objekte. Ma ei ole ka paris kindel, et kysimus on taiesti oigesti pystitatud, aga oskajad saavad ilmselt aru.
Leidsin küll yhe opetuse, kuidas seda yldiselt teha, aga seal oli naidiseks stack, kuhu sisestati yhe kaupa taisarve, mul on aga erinevatest arvutyypidest jadad.
Siinkohal lisan failide sisud:
//Main
#include <iostream>
#include "CComputer.h"
#include "CStaticStack.h"
using namespace std;
int main()
CComputer C1(100,110,111);
CComputer C2(200,210,211);
CComputer C3;
C1.Display();
C2.Display();
C3.Display();
return 0;
#ifndef CCOMPUTER_H
#define CCOMPUTER_H
#include <iostream>
class CComputer
private:
double m_uProcessorFrequency;// processor frequency in GHz;
int m_uHD; // HD size in GB;
int m_uRAM;// RAM size in GB;
public:
CComputer (double PF, int HD,int RAM);// constructor
CComputer ();// default constructor
void Display();// print all the information about a computer
// ~CComputer ();// destructor
#endif
#include <iostream>
CComputer::CComputer (double PF, int HD,int RAM)// constructor
m_uProcessorFrequency=PF;
m_uHD=HD;
m_uRAM=RAM;
CComputer::CComputer ()// default constructor
m_uProcessorFrequency=0.0;
m_uHD=1;
m_uRAM=2;
void CComputer::Display()
cout<<"Computer parameters are:"<<endl;
cout<<"Processor: "<<m_uProcessorFrequency<<endl;
cout<<"HDD: "<<m_uHD<<endl;
cout<<"RAM: "<<m_uRAM<<endl;
//STACK H FILE
#ifndef CSTATICSTACK_H
#define CSTATICSTACK_H
#include <iostream>
#include <stack>
typedef CComputer stack_item;
class CStaticStack
public:
CStaticStack ();
CStaticStack (unsigned usize);
bool IsEmpty() const;
void Push (int stack_);
stack_item Pop();
stack_item LookAtTop();
~CStaticStack();
private:
unsigned m_uSize;
stack_item* m_pMem;
stack_item* m_pTop;
#endif // CSTATICSTACK_H
//STACK CPP FILE
CStaticStack::CStaticStack ()
m_uSize=0;
CStaticStack::CStaticStack(unsigned usize)
m_uSize=usize;
bool CStaticStack::IsEmpty()const
return 0;
void CStaticStack::Push(stack_item)
??stack_list??[?????]=stack_item;
| Kommentaarid: 11 loe/lisa |
napoleon
Unknown virus
21.10.2014 17:36:15
Ülesandepüstitus on küll natuke ebamäärane, aga ehk aitab kui googledad c++ LIFO stack
Konkreetset lahendust ei paku sul kooliülesandele keegi, see on juba reeglites kirjas, aga kui mingi konkreetse koha peal hätta jääd, siis konkreetsematele küsimustele keegi ehk ikka vastab
| Kommentaarid: 79 loe/lisa |
60 |
Equinox
21.10.2014 17:40:32
Re: C++ stack loomine |
| McKlein kirjutas: |
...Ma ei tea mida voi kuidas deklareerida stack´i, et sisestada CComputer klassi objekte. Ma ei ole ka paris kindel, et kysimus on taiesti oigesti pystitatud, aga oskajad saavad ilmselt aru.
Leidsin küll yhe opetuse, kuidas seda yldiselt teha, aga seal oli naidiseks stack, kuhu sisestati yhe kaupa taisarve....
Sa oled osaliselt juba enda küsimusele vastanud Ehk näites sisestatakse arve, sina aga tahad objekte sisestada stacki. Seega sisesta siis objekte. Seda see ülesanne sulle õpetama peakski. Kuidas seda teha antud keeles, selle kohta peaks nüüd küll Googles infot piisavalt olemas.
_________________ Live long and prosper!
RIP, Spock. Leonard Nimoy 1931-2015 |
| Kommentaarid: 27 loe/lisa |
26 |
andresv
22.10.2014 07:48:29
kas seal CStaticStack.h ei peaks selle
asemel ei peaks olema
void Push(stack_item * item)
