praegune kellaaeg 21.09.2026 08:40:38
20.10.2014 09:20:46
WiFi calling-u tutvustus: T-Mobile Wi-Fi calling, Personal CellSpot bring a clear signal |
Sissejuhtatuseks: WiFi-maailmas räägitakse palju sellisest helistamisvariandist nagu WiFi calling. Ja järgmises loos sellest siis juttu tehakse.
Tösi, jutt on T-Mobile lahendusest, aga see on (töenäoliselt) ainult aja küsimus millal ka Eesti ISP-d analoogset teenust pakkuma hakkavad.
T-Mobile is giving a $200 Personal CellSpot wireless router to each customer with a Simple Choice plan, with a $25 deposit. The ASUS TM-AC1900 dual-band router gives WiFi calling priority over other network traffic so your calls are not compromised.
I’m becoming a fan of T-Mobile.
Not a customer (yet), but a fan of how it does business.
It has been lobbing grenades at its wireless competitors for a while now with its Un-carrier events and announcements. It is changing the way wireless companies offer their services.
T-Mobile has done things like making streaming music not count against data plans, allowing a no-strings test drive of an iPhone 5S, simplifying plans and dropping prices, and offering to pay early termination fees if you switch service to T-Mobile.
Its latest Un-carrier move was to introduce free Wi-Fi calling and texting to all customers.
I think it’s a pretty genius move, and one that really has no downside for T-Mobile or its customers.
Coverage counts
Wi-Fi calling means that anytime your phone is on a Wi-Fi network, your calls will be routed through Wi-Fi instead of the nearest cell tower.
The move is a way to expand T-Mobile’s network, which is a good thing.
I think the true worth of a wireless company is whether there’s good coverage where and when you need it.
Large nationwide networks are what we hear about in commercials, and T-Mobile’s network is big, but it’s not as big as AT&T’s or Verizon’s.
But what we really want is wireless coverage that works reliably in our living rooms.
What does almost everyone have in their living room (and the entire house)?
Wi-Fi.
All T-Mobile phones sold today can use a Wi-Fi network to place and receive calls.
It’s a great feature and one that other carriers are quickly adopting.
Here are some numbers from T-Mobile:
20.5 million Wi-Fi calling-enabled devices use the T-Mobile network.
5 million customers a month use Wi-Fi calling.
More than 114 million Wi-Fi calls are placed on the T-Mobile network each month.
Most Wi-Fi networks are compatible with Wi-Fi calling. For instance, I was able to make a call from Starbucks but not from my office.
It seems we (and I suspect most other corporate Wi-Fi networks) block the network ports for Wi-Fi calling so as not to slow down the network.
Once you enable Wi-Fi calling on your phone, how can you be sure it’s working from a particular network?
On the iPhone 5c I used, the carrier label on the top left of the screen changed from T-Mobile to T-Mobile Wi-Fi.
A couple of what-ifs
What if you don’t have Wi-Fi? Or if your home’s Wi-Fi could use some help?
T-Mobile wants to make it really easy to make WiFi calls from your house, so it’s giving a $200 wireless router to each customer with a Simple Choice plan. All you have to do is ask for a T-Mobile Personal CellSpot and pay a $25 deposit.
The CellSpot is actually an ASUS TM-AC1900 dual-band wireless router that can either be an addition to your home network or replace your current router.
The CellSpot differs from the commercially available ASUS version; it gives WiFi calling priority over other network traffic so your calls are not compromised if the kids are streaming cartoons from Netflix.
It’s easy to set up and uses 802.11 a/b/g/n/ac, which means it’s fast but works with all devices.
After you plug it into your broadband modem, it’s easy to configure a network name and password.
Join the new network from your phone and all your calls will travel through the CellSpot.
Faster, better range
The router has four Ethernet ports to connect your wired devices and two USB ports to wirelessly share a printer or hard drive.
The CellSpot proved to be a much faster Wi-Fi router than my older Apple Airport Express. It also offered significantly longer range outside my house and into my yard.
I really like the CellSpot, and if I were a T-Mobile customer, I’d be driving down to the T-Mobile store today to pick one up.
http://www.dallasnews.com/business/technology/headlines/20141018-t-mobile-wi-fi-calling-personal-cellspot-bring-a-clear-signal.ece
sa ei või postitada uusi teemasid siia foorumisse sa ei või vastata selle foorumi teemadele sa ei või muuta oma postitusi selles foorumis sa ei või kustutada oma postitusi selles foorumis sa ei või vastata küsitlustele selles foorumis sa ei saa lisada manuseid selles foorumis sa ei või manuseid alla laadida selles foorumis
