praegune kellaaeg 21.09.2026 08:39:40
13.10.2014 09:20:57
Samsung discovers a way to transfer 575MB/sec over 60GHz Wi-Fi tech |
Paistab, et Samsung on nüüd tegemas seda millest ta aasta v6i ka juba paar aastat tagasi juba kirjutas. Ehk siis 60GHz-i sageduse kasutamisest.
Ja kui 6igesti meeles, siis oli selleteemaline uudis ka HVF-is olemas.
Samsung claims to have developed a 60GHz Wi-Fi technology that is capable of transferring data at 4.6Gbps, or an insane 575MB/sec
Samsung is claiming to have developed an incredible new 60GHz Wi-Fi technology, something that will bridge the gap between theoretical, and actual, real-life Wi-Fi speeds.
The South Korean giant has said that this new 60GHz Wi-Fi technology is capable of 4.6Gbps, or an insane 575MB/sec. Considering the fastest Wi-Fi technology available right now is just 866Mbps, which transfers at around 108MB/sec, this is a massive increase. The 60GHz technology would be capable of transferring 1GB in less than two seconds. Samsung's announcement of this technology teases "Unlike the existing 2.4 GHz and 5 GHz Wi-Fi technologies, Samsung's 802.11ad standard 60 GHz Wi-Fi technology maintains maximum speed by eliminating co-channel interference, regardless of the number of devices using the same network".
The company has said that part of the success it found in its 60GHz Wi-Fi technology is that it uses millimeter waves, which travel by line of sight and are stopped by walls and other obstacles. Samsung uses wide-coverage, beam-forming antennae as well as micro beam-forming control technology to achieve the 575MB/sec, or 4.6Gbps speeds. Samsung has said that commercialization of the 60GHz Wi-Fi band spectrum would happen as soon as early 2015.
http://www.tweaktown.com/news/40544/samsung-discovers-a-way-to-transfer-575mb-sec-over-60ghz-wi-fi-tech/index.html
sa ei või postitada uusi teemasid siia foorumisse sa ei või vastata selle foorumi teemadele sa ei või muuta oma postitusi selles foorumis sa ei või kustutada oma postitusi selles foorumis sa ei või vastata küsitlustele selles foorumis sa ei saa lisada manuseid selles foorumis sa ei või manuseid alla laadida selles foorumis
