praegune kellaaeg 18.11.2026 01:24:35
kenkauksi
10.10.2014 23:56:13
Piltide üleslaadimine PHP's |
Ehitan siin vaikselt omale pokkerisaiti ja vaja custom avataride jaoks siis PHP skript teha. Olen PHP's täielik võhik ja olen tasapisi netist juppidest asja kokku pannud.
Hetkel skript teeb kõik vajaliku ära, aga olen just mures turvalisuse pärast.
Skript võtab vastu 48x48 pildi ja teeb sellest 2 muudetud pilti, originaali alles ei jäta.
Tahaks siis teada kas on võimalik kuidagi kellelgi midagi kahtlast üles laadida ja serverile ligi pääseda.
Kood:
<?php
include "C:/xampp/api/API.php";
if(isset($_COOKIE['username'])){
$username = $_COOKIE['username'];
$allowedExts = array("gif", "jpeg", "jpg", "png");
$temp = explode(".", $_FILES["file"]["name"]);
if(count($temp) !== 2)
if($temp[1] == "php")
echo "Looks like you are trying to upload shell. This attempt has been logged.";
exit;
else
echo "No periods allowed in filename, please try again.";
exit;
$extension = end($temp);
if ((($_FILES["file"]["type"] == "image/gif")
|| ($_FILES["file"]["type"] == "image/jpeg")
|| ($_FILES["file"]["type"] == "image/jpg")
|| ($_FILES["file"]["type"] == "image/pjpeg")
|| ($_FILES["file"]["type"] == "image/x-png")
|| ($_FILES["file"]["type"] == "image/png"))
&& ($_FILES["file"]["size"] < 10000)
&& in_array($extension, $allowedExts)) {
if ($_FILES["file"]["error"] > 0) {
echo "Return Code: " . $_FILES["file"]["error"] . "<br>";
} else {
move_uploaded_file($_FILES["file"]["tmp_name"],
"images/avatars/" . $username);
} else {
echo "Invalid file";
exit;
} else {
echo 'You need to be logged in to upload files. This attempt has logged.';
exit;
imagepng(imageCreateCorners("./images/avatars/" . $username, 20),"temp.png");
imageWaterMark('./images/watermark.png', './images/avatars/' . $username . '1.png');
imageWaterMark('./images/watermark2.png', './images/avatars/' . $username . '2.png');
$params = array("Command" => "AccountsEdit", "Player" => $username, "AvatarFile" => './images/avatars/' . $username . '1.png');
$api = Poker_API($params);
unlink('./images/avatars/' . $username);
echo "<meta http-equiv='refresh' content='0; url=http://127.0.0.1'>";
function imageWaterMark($src, $dest){
$image_1 = imagecreatefrompng('temp.png');
$image_2 = imagecreatefrompng($src);
imagealphablending($image_1, true);
imagesavealpha($image_1, true);
imagecopy($image_1, $image_2, 0, 0, 0, 0, 100, 100);
imagepng($image_1, $dest);
function imageCreateCorners($sourceImageFile, $radius) {
# test source image
if (file_exists($sourceImageFile)) {
$res = is_array($info = getimagesize($sourceImageFile));
else $res = false;
# open image
if ($res) {
$w = $info[0];
$h = $info[1];
if($w != 48 || $h != 48){
echo 'Image resolution must be 48x48px';
exit;
$type = $_FILES["file"]["type"];
switch ($type) {
case "image/jpeg": $src = imagecreatefromjpeg($sourceImageFile);
break;
case "image/gif": $src = imagecreatefromgif($sourceImageFile);
break;
case "image/png": $src = imagecreatefrompng($sourceImageFile);
break;
default:
$res = false;
# create corners
if ($res) {
$q = 5; # change this if you want
$radius *= $q;
# find unique color
do {
$r = rand(0, 255);
$g = rand(0, 255);
$b = rand(0, 255);
//something to do with transparent edges
while (imagecolorexact($src, $r, $g, $b) > 0 && imagecolorexact($src, $r, $g, $b) < 0);
$nw = $w*$q;
$nh = $h*$q;
$img = imagecreatetruecolor($nw, $nh);
$alphacolor = imagecolorallocatealpha($img, $r, $g, $b, 127);
imagealphablending($img, false);
imagesavealpha($img, true);
imagefilledrectangle($img, 0, 0, $nw, $nh, $alphacolor);
imagefill($img, 0, 0, $alphacolor);
imagecopyresampled($img, $src, 0, 0, 0, 0, $nw, $nh, $w, $h);
imagearc($img, $radius-1, $radius-1, $radius*2, $radius*2, 180, 270, $alphacolor);
imagefilltoborder($img, 0, 0, $alphacolor, $alphacolor);
imagearc($img, $nw-$radius, $radius-1, $radius*2, $radius*2, 270, 0, $alphacolor);
imagefilltoborder($img, $nw-1, 0, $alphacolor, $alphacolor);
imagearc($img, $radius-1, $nh-$radius, $radius*2, $radius*2, 90, 180, $alphacolor);
imagefilltoborder($img, 0, $nh-1, $alphacolor, $alphacolor);
imagearc($img, $nw-$radius, $nh-$radius, $radius*2, $radius*2, 0, 90, $alphacolor);
imagefilltoborder($img, $nw-1, $nh-1, $alphacolor, $alphacolor);
imagealphablending($img, true);
imagecolortransparent($img, $alphacolor);
# resize image down
$dest = imagecreatetruecolor($w, $h);
imagealphablending($dest, false);
imagesavealpha($dest, true);
imagefilledrectangle($dest, 0, 0, $w, $h, $alphacolor);
imagecopyresampled($dest, $img, 0, 0, 0, 0, $w, $h, $nw, $nh);
# output image
$res = $dest;
imagedestroy($src);
imagedestroy($img);
return $res;
| Kommentaarid: 178 loe/lisa |
158 |
Fukiku
11.10.2014 08:25:40
Ma pole just ka suuremasi PHP võlur, aga juba kohe alguses torkas silma, et Sa hoiad kasutajanime küpsises ja selle sama küpsisega antud kasutajanime järgi salvestad pildi ära. Sisuliselt tähendab see seda, et ma saan küpsist muutes suvalise kasutaja profiilile peeniseid laadida.
Siit tekib küsimus, et kas sa hoiad kogu oma rakenduse piires kasutajanime küpsises? See ei ole kindlasti turvaline eelpool nimetatud põhjusel, sest küpsis on kliendi brauseris ja seda saab väga lihtsalt muuta enne serverisse saatmist. Kõik kriitiline info peab olema hoitud serveri poolel sessioonis ja kliendi poolel on küpsises või URL-is ainult sessiooni ID, mis on juhuslik ja ära arvamine ei ole võimalik. Ühesõnaga, võta ette PHP dokumentatsioon näiteks siit: http://php.net/manual/en/book.session.php ja hakka kriitilise pilguga oma rakendust üle vaatama ja sessioonidele üle viima.
_________________ Foxic is just a simple fox
Enne kui sa küsid oma küsimuse - küsi seda vannipardilt! Rangelt soovitatav enne programmeerimise alafoorumisse uue teema tegemist. |
kenkauksi
11.10.2014 17:54:18
| Tänan, et sellele tähelepanu pöörasid. Eesmärk oli kuidagimoodi sait tööle saada ja siis hakata koodi üle vaatama ja parandama. Kindlasti viin kõik üle sessioonidele.
158 |
sigakoer
11.10.2014 19:45:34
| Sa pead ka kindel olema, et sessioonis usernamed ise punkte-slashe-tärne ei saa sisaldada.
| Kommentaarid: 40 loe/lisa |
39 |
kenkauksi
13.10.2014 16:05:38
Nii uus upload.php
<?php
if(isset($_COOKIE['SessionID'])){
session_id($_COOKIE['SessionID']);
session_start();
if($_SESSION['loggedin']){
$username = strtolower ($_SESSION['username']);
exit;
else
exit;
} else {
} else {
exit;
} else {
exit;
$params = array("Command" => "AccountsEdit", "Player" => $username, "AvatarFile" => 'C:/xampp/htdocs/library/images/avatars/' . $username . '1.png');
# test source image
} else {
$res = false;
# open image
if ($res) {
$w = $info[0];
$h = $info[1];
exit;
switch ($type) {
break;
break;
break;
default:
$res = false;
# create corners
if ($res) {
$radius *= $q;
# find unique color
do {
$r = rand(0, 255);
$g = rand(0, 255);
$b = rand(0, 255);
$nw = $w*$q;
$nh = $h*$q;
# resize image down
# output image
$res = $dest;
imagedestroy($src);
imagedestroy($img);
return $res;
ja sessiooni saab username nii:
$username = filter_input(INPUT_POST, 'username');
$_SESSION['username'] = $username;
Saan aru, et aint teatud resolutsiooniga saab pilte laadida ja midagi ei logi veel aga need on irrelevant, tahan teada kas seda koodi saab veel kuidagi kurjalt ära kasutada.
158 |
