Psych0
15.09.2014 14:03:39
Drupalisse lehekülje lisamine, kus ei ole Drupalit? |
Hei,
Kas on võimalik lisada Drupalil jooksvale leheküljele, ala www.lehekylg.ee, otsa /facebookgame lehekülg, kus on täiesti eraldiseisev kood?
Muidu apache2'ga jooksvates serverites teeksin lihtsalt "/var/www/facebookgame" kausta ning tõstaksin sinna koodi, kuid Drupalil on mingisugune täiesti oma süsteem.
| Kommentaarid: 61 loe/lisa |
57 |
andrusny
15.09.2014 14:13:50
Drupalis saab sisu alale admin paneelist koodi lisada, ehk aitab ( include("fbgame.php") php ja muud toed tuleb seal ennem sisse lülitada)
| Kommentaarid: 7 loe/lisa |
Psych0
15.09.2014 15:28:01
Kood on muidu sellisel kujul:
57 |
Donald
23.09.2014 01:25:58
| Näita oma .htacess faili. Seal peaksid ära määrama oma directoryd, mida sa ei taha rewriteda.
| Kommentaarid: 10 loe/lisa |
9 |
Psych0
23.09.2014 13:20:25
# Apache/PHP/Drupal settings:
# Protect files and directories from prying eyes.
<FilesMatch "\.(engine|inc|info|install|make|module|profile|test|po|sh|.*sql|theme|tpl(\.php)?|xtmpl|svn-base)$|^(code-style\.pl|Entries.*|Repository|Root|Tag|Template|all-wcprops|entries|format)$">
Order allow,deny
</FilesMatch>
# Don't show directory listings for URLs which map to a directory.
Options -Indexes
# Follow symbolic links in this directory.
Options +FollowSymLinks
# Make Drupal handle any 404 errors.
ErrorDocument 404 /index.php
# Force simple error message for requests for non-existent favicon.ico.
<Files favicon.ico>
# There is no end quote below, for compatibility with Apache 1.3.
ErrorDocument 404 "The requested file favicon.ico was not found.
</Files>
# Set the default handler.
DirectoryIndex index.php
# Override PHP settings. More in sites/default/settings.php
# but the following cannot be changed at runtime.
# PHP 4, Apache 1.
<IfModule mod_php4.c>
php_value magic_quotes_gpc 0
php_value register_globals 0
php_value session.auto_start 0
php_value mbstring.http_input pass
php_value mbstring.http_output pass
php_value mbstring.encoding_translation 0
</IfModule>
# PHP 4, Apache 2.
<IfModule sapi_apache2.c>
</IfModule>
# PHP 5, Apache 1 and 2.
<IfModule mod_php5.c>
</IfModule>
# Requires mod_expires to be enabled.
<IfModule mod_expires.c>
# Enable expirations.
ExpiresActive On
# Cache all files for 2 weeks after access (A).
ExpiresDefault A1209600
<FilesMatch \.php$>
# Do not allow PHP scripts to be cached unless they explicitly send cache
# headers themselves. Otherwise all scripts would have to overwrite the
# headers set by mod_expires if they want another caching behavior. This may
# fail if an error occurs early in the bootstrap process, and it may cause
# problems if a non-Drupal PHP file is installed in a subdirectory.
ExpiresActive Off
</FilesMatch>
</IfModule>
# Various rewrite rules.
<IfModule mod_rewrite.c>
RewriteEngine on
# If your site can be accessed both with and without the 'www.' prefix, you
# can use one of the following settings to redirect users to your preferred
# URL, either WITH or WITHOUT the 'www.' prefix. Choose ONLY one option:
# To redirect all users to access the site WITH the 'www.' prefix,
# (http://example.com/... will be redirected to http://www.example.com/...)
# adapt and uncomment the following:
# RewriteCond %{HTTP_HOST} ^example\.com$ [NC]
# RewriteRule ^(.*)$ http://www.example.com/$1 [L,R=301]
# To redirect all users to access the site WITHOUT the 'www.' prefix,
# (http://www.example.com/... will be redirected to http://example.com/...)
# uncomment and adapt the following:
# RewriteCond %{HTTP_HOST} ^www\.example\.com$ [NC]
# RewriteRule ^(.*)$ http://example.com/$1 [L,R=301]
# Modify the RewriteBase if you are using Drupal in a subdirectory or in a
# VirtualDocumentRoot and the rewrite rules are not working properly.
# For example if your site is at http://example.com/drupal uncomment and
# modify the following line:
# RewriteBase /drupal
# If your site is running in a VirtualDocumentRoot at http://example.com/,
# uncomment the following line:
# RewriteBase /
# Rewrite URLs of the form 'x' to the form 'index.php?q=x'.
RewriteCond %{REQUEST_FILENAME} !-f
RewriteCond %{REQUEST_FILENAME} !-d
RewriteCond %{REQUEST_URI} !=/favicon.ico
RewriteRule ^(.*)$ index.php?q=$1 [L,QSA]
</IfModule>
# $Id: .htaccess,v 1.90.2.5 2010/02/02 07:25:22 dries Exp $ |
57 |
Donald
24.09.2014 14:39:44
| RewriteCond %{REQUEST_URI} !^/facebookgame/.*$ |
Kui su dir on /facebookgame, nagu sa eelnevalt mainisid.
Ehk siis lükka see sinna lisaks, kus teised Rewrite Conditionid, kõik muu jäta ka loomulikult alles eelnevalt ja pärast.
</IfModule>
9 |
Psych0
24.09.2014 15:07:38
| Donald kirjutas: |
</IfModule>
Suured tänud - peaaegu töötab. Nimelt www.example.ee/facebookgame/ viskab 403 errorit, aga www.example.ee/facebookgame/index.html ei viska.
57 |
Donald
24.09.2014 15:30:51
Proovi:
</IfModule> |
Või tee oma /facebookgame/ diri uus .htacces file ja lisa (midagi muud pole vaja)
RewriteEngine Off
</IfModule> |
Siis sa keelad lihtsalt selles diris kõik rewrited ära.
9 |
Psych0
26.09.2014 15:26:24
| Donald kirjutas: |
RewriteEngine Off
</IfModule> |
Siis sa keelad lihtsalt selles diris kõik rewrited ära. |
Forbidden
You don't have permission to access /facebookgame/ on this server.
Edit: esimesel juhul ka 403.
E2: Sain tööle, kui index.html ümber nimetada index.php'ks, aga rakenduse PHP osa ei tööta lihtsalt (näiteks jqueryga laadides game.php kuskile div-i sisse ei juhtu midagi).
57 |
andrusny
26.09.2014 16:03:41
Kui õigesti laed peaks ikka töötama küll, ku teed
$( "#sisu" ).load( "leht.php" ); peaksid kenasti lehe toimimist alal sisu nägema, kusjuures leht millel asub JQ ei pea isegi php olema.
Psych0
26.09.2014 18:22:23
| andrusny kirjutas: |
$( "#sisu" ).load( "leht.php" ); peaksid kenasti lehe toimimist alal sisu nägema, kusjuures leht millel asub JQ ei pea isegi php olema. |
Noo, ma arendan muidu nii, et kõik töötab virtuaalmasinas ja töötab õigesti.
57 |
