praegune kellaaeg 20.11.2026 13:13:34
spider364
13.09.2014 09:01:49
MYBB Foorumi Inline moderation error |
TEEMA LEIDNUD LAHENDUSE JA V6IB SULGEDA. EEMALDASIN SELLE JA OLIGI KORRAS
<script src="http://code.jquery.com/jquery-latest.js"></script>
<script type="text/javascript" src="https://ajax.googleapis.com/ajax/libs/jquery/1.6.2/jquery.min.js"></script>
<script type="text/javascript">jQuery.noConflict();</script>
Lisasin enda lehele foorumi MyBB 1.8. Kui tahan aga seal teemat sulgeda, liigutada mujale vms viskab sildi ette "Sorry, but you did not select any threads to perform inline moderation on, or your previous moderation session has expired (Automatically after 1 hour of inactivity). Please select some threads and try again."
Googeldasin ja otsisin probleemile lahendust aga seal pakuti varianti, et header includes tekib conflikt. Otsisin ja vaatasin ent ma ei avastanud koodist midagi mis v6iks segada. Kood siis järgmine, igaks juhuks lisan.
Pildid et paremini aru oleks saada mida m6tlen.
<link rel="alternate" type="application/rss+xml" title="{$lang->latest_threads} (RSS 2.0)" href="{$mybb->settings['bburl']}/syndication.php" />
<link rel="alternate" type="application/atom+xml" title="{$lang->latest_threads} (Atom 1.0)" href="{$mybb->settings['bburl']}/syndication.php?type=atom1.0" />
<meta http-equiv="Content-Type" content="text/html; charset={$charset}" />
<meta http-equiv="Content-Script-Type" content="text/javascript" />
<script type="text/javascript" src="{$mybb->asset_url}/jscripts/jquery.js?ver=1800"></script>
<script type="text/javascript" src="{$mybb->asset_url}/jscripts/jquery.plugins.min.js?ver=1800"></script>
<script type="text/javascript" src="{$mybb->asset_url}/jscripts/general.js?ver=1800"></script>
<link type="text/css" rel="stylesheet" href="cache/themes/global/thanks/thx.css" />
<script type="text/javascript" src="jscripts/thx.js"></script>
{$stylesheets}
lang.unknown_error = "{$lang->unknown_error}";
lang.select2_match = "{$lang->select2_match}";
lang.select2_matches = "{$lang->select2_matches}";
lang.select2_nomatches = "{$lang->select2_nomatches}";
lang.select2_inputtooshort_single = "{$lang->select2_inputtooshort_single}";
lang.select2_inputtooshort_plural = "{$lang->select2_inputtooshort_plural}";
lang.select2_inputtoolong_single = "{$lang->select2_inputtoolong_single}";
lang.select2_inputtoolong_plural = "{$lang->select2_inputtoolong_plural}";
lang.select2_selectiontoobig_single = "{$lang->select2_selectiontoobig_single}";
lang.select2_selectiontoobig_plural = "{$lang->select2_selectiontoobig_plural}";
lang.select2_loadmore = "{$lang->select2_loadmore}";
lang.select2_searching = "{$lang->select2_searching}";
var cookieDomain = "{$mybb->settings['cookiedomain']}";
var cookiePath = "{$mybb->settings['cookiepath']}";
var cookiePrefix = "{$mybb->settings['cookieprefix']}";
var deleteevent_confirm = "{$lang->deleteevent_confirm}";
var removeattach_confirm = "{$lang->removeattach_confirm}";
var loading_text = '{$lang->ajax_loading}';
var saving_changes = '{$lang->saving_changes}';
var use_xmlhttprequest = "{$mybb->settings['use_xmlhttprequest']}";
var my_post_key = "{$mybb->post_code}";
var rootpath = "{$mybb->settings['bburl']}";
var imagepath = "{$theme['imgdir']}";
var yes_confirm = "{$lang->yes}";
var no_confirm = "{$lang->no}";
var MyBBEditor = null;
var spinner_image = "{$theme['imgdir']}/spinner.gif";
var spinner = "<img src='" + spinner_image +"' alt='' />";
</script> |
