praegune kellaaeg 07.11.2026 18:41:12
Markspoiss
06.09.2014 15:18:23
mure zoneminderi installi/configa |
nimelt siis proovin seda tööle saada masinas kus on ka peal virtualmin ja sellepoolt confitud süsteem
kui panen adre kujul nimi/zm siis saan sellise asja ette:S
<?php
// ZoneMinder main web interface file, $Date$, $Revision$
// Copyright (C) 2001-2008 Philip Coombes
// This program is free software; you can redistribute it and/or
// modify it under the terms of the GNU General Public License
// as published by the Free Software Foundation; either version 2
// of the License, or (at your option) any later version.
// This program is distributed in the hope that it will be useful,
// but WITHOUT ANY WARRANTY; without even the implied warranty of
// MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the
// GNU General Public License for more details.
// You should have received a copy of the GNU General Public License
// along with this program; if not, write to the Free Software
// Foundation, Inc., 59 Temple Place - Suite 330, Boston, MA 02111-1307, USA.
error_reporting( E_ALL );
$debug = false;
if ( $debug )
// Use these for debugging, though not both at once!
phpinfo( INFO_VARIABLES );
//error_reporting( E_ALL );
// Use new style autoglobals where possible
if ( version_compare( phpversion(), "4.1.0", "<") )
$_SESSION = &$HTTP_SESSION_VARS;
$_SERVER = &$HTTP_SERVER_VARS;
// Useful debugging lines for mobile devices
if ( false )
ob_start();
$fp = fopen( "/tmp/env.html", "w" );
fwrite( $fp, ob_get_contents() );
fclose( $fp );
ob_end_clean();
if ( isset($_SERVER["HTTPS"]) && $_SERVER["HTTPS"] == 'on' )
$protocol = 'https';
else
$protocol = 'http';
define( "ZM_BASE_URL", $protocol.'://'.$_SERVER['HTTP_HOST'] );
if ( isset($_GET['skin']) )
$skin = $_GET['skin'];
elseif ( isset($_COOKIE['zmSkin']) )
$skin = $_COOKIE['zmSkin'];
else
$skin = "classic";
define( "ZM_BASE_PATH", dirname( $_SERVER['REQUEST_URI'] ) );
define( "ZM_SKIN_PATH", "skins/$skin" );
$skinBase = array(); // To allow for inheritance of skins
if ( !file_exists( ZM_SKIN_PATH ) )
Fatal( "Invalid skin '$skin'" );
require_once( ZM_SKIN_PATH.'/includes/init.php' );
$skinBase[] = $skin;
ini_set( "session.name", "ZMSESSID" );
session_start();
if ( !isset($_SESSION['skin']) || isset($_REQUEST['skin']) )
$_SESSION['skin'] = $skin;
setcookie( "zmSkin", $skin );
require_once( 'includes/config.php' );
require_once( 'includes/logger.php' );
if ( ZM_OPT_USE_AUTH )
if ( isset( $_SESSION['user'] ) )
$user = $_SESSION['user'];
else
unset( $user );
else
$user = $defaultUser;
require_once( 'includes/lang.php' );
require_once( 'includes/functions.php' );
if ( isset($_REQUEST['view']) )
$view = detaintPath($_REQUEST['view']);
if ( isset($_REQUEST['request']) )
$request = detaintPath($_REQUEST['request']);
if ( isset($_REQUEST['action']) )
$action = detaintPath($_REQUEST['action']);
require_once( 'includes/actions.php' );
foreach ( getSkinIncludes( 'skin.php' ) as $includeFile )
require_once $includeFile;
if ( isset( $_REQUEST['request'] ) )
foreach ( getSkinIncludes( 'ajax/'.$request.'.php', true, true ) as $includeFile )
if ( !file_exists( $includeFile ) )
Fatal( "Request '$request' does not exist" );
return;
else
if ( $includeFiles = getSkinIncludes( 'views/'.$view.'.php', true, true ) )
foreach ( $includeFiles as $includeFile )
Fatal( "View '$view' does not exist" );
if ( !$includeFiles || $view == 'error' )
foreach ( getSkinIncludes( 'views/error.php', true, true ) as $includeFile )
Kus vms on mul valesti?
| Kommentaarid: 20 loe/lisa |
16 |
Adebisi
| Kommentaarid: 58 loe/lisa |
55 |
Markspoiss
15.09.2014 13:18:31
hmm kummalisel kombel on jah:S kuigi Virtualminiga peaks see nagu ära installitud olema automaatselt:S miks ta nüüd ei tööta see on küll kummaline:/
EDIT: paistab, et see viga tekib peale zoneminderi installi :S miks ta selle php korstna laseb ja kustkohast ma aru ei saa
EDIT: teab ehk keegi mind aidata kuidas sellises koosluses asja tööle saaks?
Tänud!
16 |
