praegune kellaaeg 21.09.2026 10:16:52
11.08.2014 09:21:33
Inimeste uudishimu on ikka piiritu: How to Use Your Cat to Hack Your Neighbor’s Wi-Fi |
Inimeste uudishimu on ikka piiritu. Ning vajadusel tuleb ka koduloomad rakendada selle "uudishimu-vankri" ette.
Late last month, a Siamese cat named Coco went wandering in his suburban Washington, DC neighborhood. He spent three hours exploring nearby backyards. He killed a mouse, whose carcass he thoughtfully brought home to his octogenarian owner, Nancy. And while he was out, Coco mapped dozens of his neighbors’ Wi-Fi networks, identifying four routers that used an old, easily-broken form of encryption and another four that were left entirely unprotected.
Unbeknownst to Coco, he’d been fitted with a collar created by Nancy’s granddaughter’s husband, security researcher Gene Bransfield. And Bransfield had built into that collar a Spark Core chip loaded with his custom-coded firmware, a Wi-Fi card, a tiny GPS module and a battery—everything necessary to map all the networks in the neighborhood that would be vulnerable to any intruder or Wi-Fi mooch with, at most, some simple crypto-cracking tools.
In the 1980s, hackers used a technique called “wardialing,” cycling through numbers with their modems to find unprotected computers far across the internet. The advent of Wi-Fi brought “wardriving,” putting an antenna in a car and cruising a city to suss out weak and unprotected Wi-Fi networks. This weekend at the DefCon hacker conference in Las Vegas, Bransfield will debut the next logical step: The “WarKitteh” collar, a device he built for less than $100 that turns any outdoor cat into a Wifi-sniffing hacker accomplice.
Edasi jutt juba lingil:
http://www.wired.com/2014/08/how-to-use-your-cat-to-hack-your-neighbors-wi-fi/
Max Powers
11.08.2014 09:25:34
| Kassid kipuvad sama rada käima
sa ei või postitada uusi teemasid siia foorumisse sa ei või vastata selle foorumi teemadele sa ei või muuta oma postitusi selles foorumis sa ei või kustutada oma postitusi selles foorumis sa ei või vastata küsitlustele selles foorumis sa ei saa lisada manuseid selles foorumis sa ei või manuseid alla laadida selles foorumis
