Cyril
Aeg maha 1p
11.08.2014 02:32:29
Kuna Windowsil updatid otsa saavad? |
| Lasin just mingid "important update"is peale ja juba uued olevat valmis...kuna ta lõpetab selle updateimise? On seda ikka vaja iga päev teha? Mis selle suurem mõte on? Viiruste vastu võitlemine?
11.08.2014 06:43:49
| Keera kinni, kui pinda käivad. Või kasuta XP-d - sellele enam uuendusi juurde tulemas pole.
seeru
11.08.2014 07:13:13
Nii hull see ei ole. Tegelikult on XP-le peale aprilli iga kuu uuendusi edasi tulnud.
Kasutada lihtsat õpetust
http://www.pcworld.com/article/2310301/windows-xp-registry-hack-keeps-the-security-updates-rolling.html
siis saab XP uuendusi kuni aprill 2019
aga uuendusi on tulnud ka ilma seda hacki kasutamata.
Muidugi nüüd peab ise hoolikam olema ja mitte otseselt Windows Embedded POSReady uuendusi XP-le otsa lasta.
Mul mitu XP Pro masinat ja kõik saavad uuendusi.
Põhiliselt käib siis edasi turvaaukude lappimine.
indu
11.08.2014 09:30:07
Security Updates - These updates patch security vulnerabilities that could allow a system to become compromised. Security updates are classified as Critical, Important, Moderate, Low, or non-rated. Critical Security Updates are perhaps the most important updates to apply to your system. Ignoring these could leave your computer or server extremely vulnerable to hackers and malicious code.
Critical Updates - Critical Updates fix any major issue that is found in Microsoft products that could cause software errors or unexpected behavior. Together with Security Updates, they form the "High Priority" category of updates from Microsoft and should be set to download and install automatically.
Software Updates - Non-critical issues, such as extended features and minor bugs, are addressed using Software Updates.
Service Packs - Service Packs contain a rollup of all patches to date for a specific piece of software or operating system and usually have additional feature changes.
_________________ http://www.lossirestoran.eu/ |
seeru
11.08.2014 14:08:04
| Betamax kirjutas: |
Inimene tahab uuendustest lahti saada, aga sinna tekitad oma juhistega neid juurde  |
Jah, et kui ma panen XP peale mingi 2012 aasta versiooni plaadi pealt, siis mingi ~300 uuendust tuleb ikka otsa.
Ega Win7 ga eriti teistmoodi ole
Tuleb lihtsalt ära teha või siis uuendamine kinni keerata.
11.08.2014 15:10:30
| seeru kirjutas: |
Tuleb lihtsalt ära teha või siis uuendamine kinni keerata. |
...ja palvetada, et mingi uss kollitama ei tule...
12.08.2014 10:37:31
Karta on, et igasuguste op.süsteemide Updated saadavad inimesi kuni hauani ja siis veel ka järgmises elus edasi.
Katsetan enda tarbeks erinevaid Linuxite op.süsteeme ja samamoodi muudkui jooksevad kirjad, et paluks lahkelt teha järgmine Update. Praegugi tiritakse üht järgmist uuendust.
rex
12.08.2014 11:44:59
Saavad otsa kohe, kui lõpetad nende tellimise. Mina oma isiklikes arvutites ei lase jooksvaid uuendusi peale (ainult SP-d) ja uss pole kimbutamas käinud. Tulemüür ja antiviirus on muidugi peal. Kasutus üle keskmise tihe ja brauseri sihtmärgid tihtipeale suht ettearvamatud. Samas olen kuhjade kaupa ussidest puhtaks rookinud vaikimisi seades (installi update'id igal ööl kell 3 ja tee vajadusel külma näoga reboot) masinaid.
"Tähtis" update võib vabalt sisaldada näiteks hoopis patch'i, mis lubab kaugelt su mikri ja veebika sisse lülitada. OS-i disainimise ajal lihtsalt ei nähtud sellist vajadust veel ette. Teevad siis jooksvalt ära. Just because you're paranoid doesn't mean they aren't after you.
12.08.2014 11:55:34
| rex kirjutas: |
"Tähtis" update võib vabalt sisaldada näiteks hoopis patch'i, mis lubab kaugelt su mikri ja veebika sisse lülitada. OS-i disainimise ajal lihtsalt ei nähtud sellist vajadust veel ette. Teevad siis jooksvalt ära. Just because you're paranoid doesn't mean they aren't after you. |
Samas jällegi - karm arvutimaailm - näitab jällegi seda kuidas, tavakasutajate tarbeks, jällegi igasugu Javad ja Flashid ilmuvad ka sellistes maailmades kus varasemalt sellistest asjadest midagi kuulda ei tahetud. Sel juhul on tavakasutajal jällegi parem kui turvauuendused automaatselt toimuvad kuna tavakasutaja nagunii midagi kusagil seadistama ei hakka.
PS: Kirjutan praegu Linuxiga masinast kus siis samamoodi on plug-and-playna olemas nii Flash kui ka Java. Ja kena, et k6ik olemas on ning mingi värk ei kriiska, et on puudu kas üks v6i teine. Ja siis natike turvauuendusi üle elada ei v6ta tükki küljest.
DVDRW
27.02.2015 09:17:55
D620 1GB ram.
Panin windows 7 peale, võtab 7GB SSD-l. Installisin uuendused ka. Nüüd 16GB
Üks huvitav fakt, et kui vaja arvutile windows ja muu stuff panna, siis 90% ajakulu ~5tundi on update installimine.
27.02.2015 17:24:02
Väljalülitamise asemel võib system restore poolt kasutatavat kettamahtu piirata mõistlikule tasemele. Ja ketta puhastamisel kustutada kõik restore pointid peale viimase.
Kui päris välja lülitada, siis võib mõne ootamatu probleemi tekkimisel taastamisvõimaluse puudumine üsna tülikaks osutuda.
Ja siis veel seda, et see uus Windows Update Cleanup kustutab küll osa Windows Update'ga paigaldatud uuenduste installikatest, aga tundub sedasi, et ta ei tühjenda nende allalaadimiseks kasutatavat kausta %Windir%\SoftwareDistribution\Download\
Ka selle võib tühjaks teha üsna rahulikult. Windows Update sikutab sinna pärast tühjendamist natuke mingeid peeneid pudinaid tagasi, aga suurem osa vabanenud ruumist jääbki vabaks. Ja mis peamine - midagi ei lähe sellest katki.
27.02.2015 19:02:53
Värske installi järel suure hulga uuenduste korraga installimise ajal restore välja lülitada on mõistlik mõte küll. Hiljem võiks ta piiratud mahuga siiski uuesti käima lubada, gigabaidist jagub juba mitmele restore pointile.
Pekkiminemise puhul - kuidas kellel ja kui palju üks või teine töö aega võtab ja tüli tekitab - Windowsi uuesti installimine koos kõigi uuenduste, draiverite ja tarkvaraga on isegi juhul kui see töö on poolautomaatseks tehtud, kordades suurem töö kui system restore abil ühe sammu tagasivõtmine. Aga eks igaüks ise teab ja otsustab, mida ta teeb selle gigabaidi või oma ajaga.
krist2an
01.03.2015 16:11:47
Soovitaks Windows 98 või siis äärmisel juhul XP'd, mõlemad ei tohiks enam uuendusi saada. Sa võid loomulikult otsida netist mõne eriti algelise Windows 7 või 8 beta-versiooni ka. Loomulikult tuleb seal kogu Windows Update kinni keerata. Et ikka ilma uuendusteta oleks Kui oled eriti julge, võid proovida mõne surnud Linuxi distro tõmmata, need ka ei saa uuendusi: http://distrowatch.com/dwres.php?resource=discontinued
vikir57
01.03.2015 17:37:24
Kuna Win updapid otsa saavad |
| See % Windir% kustutamine pole eriti hea mõte.Sest Win võib uuesti aktiveerimist nõuda healjuhul.
rex
01.03.2015 18:21:36
Re: Kuna Win updapid otsa saavad |
| vikir57 kirjutas: |
| See % Windir% kustutamine pole eriti hea mõte.Sest Win võib uuesti aktiveerimist nõuda healjuhul. |
Ei ole jah hea mõte, kuigi pärast seda ei nõuta enam ei uuenduste tegemist ega ka uuesti aktiveerimist.
