praegune kellaaeg 21.09.2026 10:16:52
08.08.2014 09:49:49
MS versus Linux. jälle nad "södivad" - seekord siis vaatenurk "MS-i kaevikutest": Why Microsoft |
Ning loodetavasti tuleb "Linuxite kaevikutest" peagi omapoolne nägemus sellest värgist.
Why Microsoft
Learn about Microsoft's strategic and technical differentiation
Microsoft vs. Linux
Microsoft has built a comprehensive next-generation server platform that spans on-premises infrastructure and cloud services. We're helping you realize added value from your existing Linux investments through Hyper-V virtualization and System Center management tools, and we have worked with our partners to enable Ubuntu, OpenLogic, CentOS, Oracle Linux, and openSUSE and SUSE Linux Enterprise Server to run with high performance on the Microsoft Azure cloud.
However, sometimes your solution is focused solely on server-side operating systems, and that's where Linux falls short. Windows Server gives you the highly manageable, secure, cost-effective, cloud-ready platform you need to support your company's innovative IT goals.
Edasi jutt juba lingil:
http://www.whymicrosoft.com/Pages/linux.aspx
neros
08.08.2014 10:11:33
Wow.... r22gi aga loogist allapoole vood... Seda poleks MSilt küll oodanud... huvitav n2ha mis leegis6jad seal k2ima just pandi
_________________ GitHub
.NET Core & Azure baasil lahendused ja arhitektuur - kontakt. |
13.08.2014 16:47:57
Edit: Paistab, et nüüd tulistatakse Linuxi-kaevikutest. Ja loo sisu tundub viitavat siis vastust MS-i "tulistamisele" natuke aega tagasi:
PS: Mina ise, "vana inimesena" ootan juba oma 15 aastat, et millal see s6da juba ükskord ühele poole saaks.
Linux vs. Windows Internet Battle No Longer Exists Because Linux Is Winning
Windows and Linux communities used to virtually battle each other regarding the superiority of one platform or the other, but that is no longer happening, at least not at the same scale. One of the reasons for that might be that Linux is actually gaining ground.
We need to get some things straight right from the start. The Linux desktop market share has increased only slightly in the last couple of years. It's on the rise, but the trend is not breaking any records. The number is somewhere around 1.5% - 2%. It might be a little higher or a little lower, but it’s still a very small number.
The server market share is the other way around, with Linux and BSD leading the charge. An optimistic percentage places Windows server at about 30%. On the other hand, servers are not really a concern for users, so we'll ignore them for now.
The desktop is the public face of an operating system, or in the case of Linux, a huge number of Linux-based operating systems. When people talk about the Linux and Windows features, options, pros and cons, they usually refer to the desktop versions.
Up until a few years ago, the battle between the two platforms was fierce, usually followed by various jokes and puns, but that has stopped for the most part. There could be a number of reasons for it, but the main one is that Windows is actually losing and Linux is gaining ground.
The thing is that a lot of people don't actually delete their Windows OS and install a Linux one. They are running both systems at the same time and they know what the strengths of each platform are. The communities have started to blend and less users are willing to make fun of an OS that they actually use at home.
Linux' rise in popularity has many catalysts. One of them is definitely Valve with its Steam distribution platform. The advent of gaming on Linux is helping people understand that entertainment is possible on completely free operating systems.
The other major catalysts for the adoption of Linux are the system installers and the software center. It used to be hard to install a Linux distro, but that has changed dramatically. Developers have been working to streamline the installation of Linux systems and the procedure has become so simple that anyone who can install a Windows OS can also install a Linux distro.
The usability of Linux operating systems is also getting a lot better, as users can easily install their favorite applications, and to top it all off, more and more devs bring their apps and games to the open source environment. Soon, most of the major companies will start making their software for both platforms and they won't be able to ignore Linux any longer.
Linux is winning a fight and it's not even trying to. There is no PR department for Linux and the people involved in open source projects are only trying to do one thing, improve the software. If Linux is helped in the process, all the better.
http://news.softpedia.com/news/Linux-vs-Windows-Internet-Battle-No-Longer-Exists-Because-Linux-is-Winning-454869.shtml
sa ei või postitada uusi teemasid siia foorumisse sa ei või vastata selle foorumi teemadele sa ei või muuta oma postitusi selles foorumis sa ei või kustutada oma postitusi selles foorumis sa ei või vastata küsitlustele selles foorumis sa ei saa lisada manuseid selles foorumis sa ei või manuseid alla laadida selles foorumis
