praegune kellaaeg 10.11.2026 08:31:48
08.07.2014 11:47:14
LiFi esimene "turvapeavalu": Networked Light Bulbs Can Expose WiFi Password |
PS: Väikseks meenutuseks, LiFi on siis netivõrk kus infot edastatakse spetsiaalsete LED-lampide kaasabil. Ning teine tuntud nimetus on siis VLC. Selle nime all katseti seda ka Elisa poolt Tallinnas.
A group of researchers has discovered that a specific type of LED light bulbs with network connectivity could be used by an attacker to capture and decrypt the credentials for the WiFi network from a distance of about 30 meters / 98 feet.
LIFX light bulbs are WiFi-enabled and can function in a network that is controlled through different wireless protocols using an app for mobile devices (iOS or Android). The user can thus control the light source by changing its color or intensity, programming it to turn on or off according to a predefined schedule.
These light bulbs can be installed in a mesh network that is controlled by only one of them. In case this master LED bulb becomes unavailable, another one replaces it automatically.
Researchers at Context Information Security analyzed the way these smart light bulbs communicate with the network they’re connected to and discovered that there are three communication components in the LIFX bulb network: mobile device to bulb, bulb WiFi, and bulb mesh network communication.
LIFX bulbs rely on the 6LoWPAN wireless specification that is built on top of the IEE 802.15.4 standard, which specifies the media access control for low-rate wireless personal area networks.
By reversing the firmware of the light bulbs, the Context engineers observed that AES encryption was implemented for securing the communication through WiFi.
“AES, being a symmetric encryption cipher, requires both the encrypting party and the decrypting party to have access to the same pre-shared key. In a design such as the one employed by LIFX, this immediately raises alarm bells, implying that each device is issued with a constant global key.
“If the pre-shared key can be obtained from one device, it can be used to decrypt messages sent from all other devices using the same key. In this case, the key could be used to decrypt encrypted messages sent from any LIFX bulb,” they write in a blog post.
With the necessary knowledge, an attacker could be able to collect the encrypted WiFi credentials and decrypt them, without having to authenticate in any way or raising any alarm, from 30 meters / 98 feet away.
The vendor has been made aware of the glitch discovered during the research and responded promptly by issuing a firmware update, which encrypts all 6LoWPAN communications with a key derived from the WiFi credentials.
However, hacking the LIFX light bulbs is not an easy feat to pull, because the effort involved and the complexity of the task is not of ordinary levels.
Context researchers had to gain physical access to the micro-controllers embedded in the device in order to extract the firmware, identify the correct JTAG pins on the chips, use special equipment to issue commands to the chips, as well as reverse the extracted firmware.
Simon Walker from LIFX said that “prior to the patch, no one other than Context had exposed this vulnerability, most likely due to the complexity of the equipment and reverse engineering required.”
http://news.softpedia.com/news/Networked-Light-Bulbs-Can-Expose-WiFi-Password-449843.shtml
Algallikalink siis kah:
Hacking into Internet Connected Light Bulbs
http://contextis.com/blog/hacking-internet-connected-light-bulbs/
FluffyOwl
30.09.2014 15:16:50
Uudist lugedes küll tegu ei ole LiFiga.
Pigem on juttu led lampidest mis kannavad edasi WiFi signaali.
LiFi on siiski täiesti teine tehnoloogia kus kantakse signaali edasi nähtava valguse ja selle inimsilmale märkamata jääva "värelusega" mis tekitatakse. LiFi seadmed ei ühildu wifi seadmetega.
Nii et kahjuks on pealkiri väga vale ja eksitav.
EDIT: Ajasid kuidagi tootjafirma nimega sassi ?
_________________ - : ) - |
30.09.2014 19:42:20
| FluffyOwl kirjutas: |
EDIT: Ajasid kuidagi tootjafirma nimega sassi ? |
On küll tegelikult üks ja sama kuna seesama signaal vilgutataksegi ju LED-lampidega ja mida kiiremat ühendust vaja on, seda körgema sagedusega neid LED-lampe vilgutatakse. Ja vot seda "vilkumist" saab siis kinni püüda ja lahti häkkida - sellest käib siis see jutt.
Nii, et tegelikult üks ja sama tehnoloogia ja mida siis üritatakse kahe erineva nimetuse all maailmale maha müüa.
PS: Aga seda tahaks ma ikkagi väga näha, et kui palju neid firmasid ja kodusid olema saab kus ööpäev läbi kogu aeg lampe pöletatakse, sest kui lambid välja lülitatakse, siis seda "valgusWiFi-t enam olemas pole". Ja eriti veel igasuguste energiasäästu järjest karmimate nöuete valguses.
Järgmisel lingil siis selgitatakse natuke seda tehnoloogiat:
LiFi: light-based broadband puts WiFi in the shade
Tsitaat:
LiFi, or visible light communications (VLC), replaces the radio waves used by WiFi with streams of light from LED bulbs.
Read more: http://www.theweek.co.uk/technology/55813/lifi-light-based-broadband-puts-wifi-shade#ixzz3Ep1Pd2tq
30.09.2014 20:26:30
Lahe loogika. Tähendab, et kui krüpteerimata wifi võrku saab igaüks vaevata sisse, tähendab see automaatselt seda, et WPA2 krüpteeritud wifi võrku pääseb sama lihtsalt. Ja mitte ainult Wifi WPA2, vaid ka ükskõik millisel sideprotokollil ja mistahes krüpteeringuga teise raadiovõrku.
See on ju sinu väite põhjal täpselt sama lihtne, sest signaaliks on ju seesama elektromagnetvälja võngutamine. Seda saab samamoodi kinni püüda ja siis "häkkida" - tähendab, et pole turvaline.
FluffyOwl
02.10.2014 00:27:13
Vaidlen siiski vastu endiselt ... sul on nn "research" tegemata
Ühtegi LiFi toodet ei ole seni veel tootmiseski sest sandart on arendamisel.
Tegu on siiski lambi pirniga millele on pandud sisse WiFi "raadiosignaal" et saaks kontrollida lambi värve, tugevust ja muud jama.
http://lifx.co/
Lugemist : http://en.wikipedia.org/wiki/Li-Fi
Olen LiFi arengut pikalt juba jälginud kuna arvan et tegu on hea asendusega WiFile sest LiFi signaali ei saaks varastada näiteks naabrid kortermajas teiselpool seina. No olgu saaksid varastada tegelased kuskil akna taga kui kardinat pole ette tõmmanud aga see on omaette teema
04.10.2014 11:12:05
Veel üks kena pildike ja mis siis üheselt lahti selgitab kuidas see LiFi (teise nimega VLC) siis töötab.
Aga kui arvestada, et seda ideed katsetati juba aastaid tagasi ja paljud firmad on sellest ideest tänaseks päevaks loobinud, siis on üleüldse küsimus, et kas ja palju see kunagi üleüldse levima hakkab.
Ning seda veel siis ka energiakriisi tingimustes kus vaevalt leidub kedagi kes ööpäevaringselt lampe p6letada soovib.
Nüüd siis see kena pilt ise kah:
http://www.quora.com/What-is-a-LiFi-Technology
sa ei või postitada uusi teemasid siia foorumisse sa ei või vastata selle foorumi teemadele sa ei või muuta oma postitusi selles foorumis sa ei või kustutada oma postitusi selles foorumis sa ei või vastata küsitlustele selles foorumis sa ei saa lisada manuseid selles foorumis sa ei või manuseid alla laadida selles foorumis
