praegune kellaaeg 21.09.2026 09:27:34
28.06.2014 23:15:12
Microsofti-maailmas "sahistatakse": Microsoft rumored to be planning to replace 'Surface' branding with 'Lumia' |
Summary: Would it help or hurt Microsoft more if the company consolidated its mobile branding using the 'Nokia' and 'Lumia' brands instead of using the current 'Surface' branding?
Branding is hard. Branding is expensive.
But according to known leaker @evleaks, Microsoft may be doing just that. According to his unnamed sources, Microsoft may be moving toward rebranding its Surface tablets as "Lumia" devices.
@evleaks also claimed that Microsoft may be negotiating to keep the Nokia brand longer than originally planned so that it can use it for future phones and possibly other devices.
Edasi lingil:
http://www.zdnet.com/microsoft-rumored-to-be-planning-to-replace-surface-branding-with-lumia-7000031028/
sa ei või postitada uusi teemasid siia foorumisse sa ei või vastata selle foorumi teemadele sa ei või muuta oma postitusi selles foorumis sa ei või kustutada oma postitusi selles foorumis sa ei või vastata küsitlustele selles foorumis sa ei saa lisada manuseid selles foorumis sa ei või manuseid alla laadida selles foorumis
