praegune kellaaeg 21.09.2026 09:27:08
25.06.2014 22:30:42
Midagi "netijälgimis-uudishimulikele": How to watch hacking, and cyberwarfare between the USA and China, in real tim |
How to watch hacking, and cyberwarfare between the USA and China, in real time
You’ve no doubt heard countless stories about how the internet is rife with hackers and ruled by malware-peddling malcontents. You’ve probably read dozens of paragraphs on how the next great theater of war will be online rather than offline, and how China and the US are already battling each other for cyber supremacy. The truth is, though, unless you’ve actually been hacked, it’s hard to appreciate just how real the prospect of cyberwar actually is; after all, the effects of hacking are mostly invisible to the untrained eye, with the exception of very-high-profile database breaches. Now, though, a security company has produced a fascinating geographic map that shows you global hacking attempts in real-time — and sure enough, you really can see China waging cyberwar against the US.
The real-time map, maintained by the Norse security company, shows who’s hacking who and what attack vectors are being used. The data is sourced from a network of “honeypot” servers maintained by Norse, rather than real-world data from the Pentagon, Google, or other high-profile hacking targets. In hacking a honeypot is essentially a juicy-looking target that acts as a trap — either to gather important data about the would-be assailants, or to draw them away from the real target. The Norse website has some info about its “honeynet,” but it’s understandably quite sparse on actual technical details.
Edasi juba lingil:
http://www.extremetech.com/extreme/185125-how-to-watch-hacking-and-cyberwarfare-between-the-usa-and-china-in-real-time
sa ei või postitada uusi teemasid siia foorumisse sa ei või vastata selle foorumi teemadele sa ei või muuta oma postitusi selles foorumis sa ei või kustutada oma postitusi selles foorumis sa ei või vastata küsitlustele selles foorumis sa ei saa lisada manuseid selles foorumis sa ei või manuseid alla laadida selles foorumis
