praegune kellaaeg 21.09.2026 09:27:35
25.06.2014 09:19:39
NASA tehnoloogiaidee, transistorid tööle vaakumtorus: How Vacuum Tubes, New Technology Might Save Moore's Law |
The transistor is one of the most profound innovations in all of human existence. First discovered in 1947, it has scaled like no advance in human history; we can pack billions of transistors into complicated processors smaller than your thumbnail. After decades of innovation, however, the transistor has faltered. Clock speeds stalled in 2005 and the 20nm process node is set to be more expensive than the 28nm node was for the first time ever. Now, researchers at NASA believe they may have discovered a way to kickstart transistors again -- by using technology from the earliest days of computing: The vacuum tube.
No, really. Stop laughing.
Edasi jutt ja pildid juba lingil:
http://hothardware.com/News/How-Vacuum-Tubes-New-Technology-Might-Save-Moores-Law-/#!20UBI#ixzz35YCtZ7zd
Ja veel üks link siia juurde:
The vacuum tube strikes back: NASA’s tiny 460GHz vacuum transistor that could one day replace silicon FETs
Way back in the salad days of digital computing (the 1940s and ’50s), computers were made of vacuum tubes — big, hot, clunky devices that, when you got right down to it, were essentially glorified light bulbs. This is why early computers like the ENIAC weighed more than 27 tons and consumed more power than a small town. Later, obviously, vacuum tubes would be replaced by probably the greatest invention of all time — the solid-state transistor — which would allow for the creation of smaller, faster, cheaper, and more reliable computers. Fast forward to 2014, though, and the humble CMOS field-effect transistor (FET) is starting to show its age. We’ve pretty much hit the limit on shrinking silicon transistors any further, and they can’t operate at speeds much faster than a few gigahertz. Which is why NASA’s Ames Research Center is going back to the future with its new vacuum transistor – a nanometer-scale vacuum tube that, in early testing, has reached speeds of up to 460GHz.
Edasi lingil:
http://www.extremetech.com/extreme/185027-the-vacuum-tube-strikes-back-nasas-tiny-460ghz-vacuum-transistor-that-could-one-day-replace-silicon-fets
sa ei või postitada uusi teemasid siia foorumisse sa ei või vastata selle foorumi teemadele sa ei või muuta oma postitusi selles foorumis sa ei või kustutada oma postitusi selles foorumis sa ei või vastata küsitlustele selles foorumis sa ei saa lisada manuseid selles foorumis sa ei või manuseid alla laadida selles foorumis
