praegune kellaaeg 14.11.2026 09:35:31
21.06.2014 14:44:32
Avastati CryptoLockeri uus versioon: Preying on Assumptions: Symmetric Encryption in a CryptoLocker Variant |
This trojan was found on a compromised web server that was used to send mass emails with a malicious attachment. Upon execution, the malware searches all logical drives for common media and document files, appends .CRYPTOLOCKER to each file’s name and allegedly encrypts each file with 2048-bit RSA key. It places a text file in every subdirectory with ransom instructions. It persists on the system by copying itself to a TEMP folder, and adding that copy to the system autoruns. It also gives this copy a file-association to the “.CRYPTOLOCKER” file extension. When it finishes this dirty work, it displays a warning (seen above) with instructions for downloading the Tor Browser to (presumably) cough up some money for the private RSA key required to decrypt the files. This is a similar pattern that we have seen in recent ransomware variants.
Kogu jutt edasi lingil:
http://fakebit.com/symmetric-encryption-in-a-cryptolocker-variant/
CryptoLocker Variant Found with Weak Encryption
A modification of the infamous CryptoLocker ransomware Trojan that does not rely on the 2048-bit RSA encryption and does not communicate with a command and control server has been found in the wild.
Edasi lingil:
http://news.softpedia.com/news/CryptoLocker-Variant-Found-with-Weak-Encryption-447830.shtml
HacaX
21.06.2014 16:54:40
Voimas! Tavapressis tuleb nuud kindlasti ridamisi artikleid sellest kui paha Tor on - pahavara mitte ainult ei kasuta seda, vaid lausa promob kasutamiseks vajalikku softi
sa ei või postitada uusi teemasid siia foorumisse sa ei või vastata selle foorumi teemadele sa ei või muuta oma postitusi selles foorumis sa ei või kustutada oma postitusi selles foorumis sa ei või vastata küsitlustele selles foorumis sa ei saa lisada manuseid selles foorumis sa ei või manuseid alla laadida selles foorumis
