uus teema   vasta Uudised »  Turvalisus ja privaatsus »  Tõsine OpenSSL turvaauk "Heartbleed" märgi kõik teemad loetuks
Forss
Forss
sõnum 08.04.2014 23:55:27 Tõsine OpenSSL turvaauk "Heartbleed" vasta tsitaadiga
Soomlased avastasid OpenSSLis tõsise turvaaugu. Kahju on saanud tuhanded populaarsed veebilehed, tuntuimatest Yahoo, Imgur, Flickr ja Lastpass.
http://www.theverge.com/2014/4/8/5594266/how-heartbleed-broke-the-internet
"... He told us OpenSSL runs on top of two of the most widely used Web servers: Apache and nginx. He pointed out that it also runs on e-mail servers and chat services, VPN and other software that use the code library.
“Many devices that use embedded Linux including routers and other devices may also be susceptible,” Westin said. “Attackers who exploit the vulnerability can monitor all data passing between a service and client, or decrypt historical encrypted data that has been collected.”
He left us with a warning: Many modern operating systems use vulnerable versions of Open SSL including Debian Wheezy, Ubuntu 12.04.4 LTS, CentOS 6.5, Fedora 18, OpenBSD 5.3, FreeBSD 8.4, NetBSD 5.0.2 and OpenSUSE 12.2."
http://www.sci-tech-today.com/news/Heartbleed-Bug-Breaks-Web-Security/story.xhtml?story_id=0200028EM7FC
Rohkem infot:
http://www.heartbleed.com
http://filippo.io/Heartbleed/
https://blog.ipredator.se/2014/04/how-to-test-if-your-openssl-heartbleeds.html
https://gist.github.com/dberkholz/10169691
https://github.com/blog/1818-security-heartbleed-vulnerability
sõnum 09.04.2014 09:02:09 Re: Tõsine OpenSSL turvaauk "Heartbleed" vasta tsitaadiga
Parandused olid väljas juba eile nii Debianile kui Ubuntule, ainsaks tõsisemaks probleemiks võib olla enne paranduse rakendamist toimunud andmete leke ja vigase openssl-i abil genereeritud sertifikaadid - viimased tuleb kõik uued teha. Kui serdid on genereeritud enne vigase openssl versiooni paigaldust, siis pole see vajalik.
tomes
sõnum 09.04.2014 15:36:09 vasta tsitaadiga
Välja tuleb vahetada mitte vigase versiooniga genereeritud, vaid koos vigase versiooniga kasutuses olnud võtmed ja sertifikaadid.
Kommentaarid: 65 loe/lisa Kasutajad arvavad:  :: 0 :: 0 :: 59
Vael
sõnum 09.04.2014 16:08:05 vasta tsitaadiga
Kas see puudutab ka ID kaardiga tuvastamist? Ja kui siis peaks sertifikaate uuendama Ubuntus?
tomes
sõnum 09.04.2014 17:59:25 vasta tsitaadiga
Vael, antud turvaaugu abil saadi kätte serveri vahemälus olev privaatvõti - ID-kaart privaatvõtmeid välja ei anna, seega pole uuendamiseks vajadust.
sõnum 09.04.2014 21:20:16 vasta tsitaadiga
tomes kirjutas:
Õige märkus, aitäh.
kriimsilm
kriimsilm
sõnum 09.04.2014 22:17:51 vasta tsitaadiga
Ja kasutajad peaksid muutma enda paroolid.
Kes seda nüüd oskab öelda, millised serverid on vigast versiooni kasutanud ning kui paljud loginad hashimata ja soolamata väärtuseid serverisse saadavad?
sõnum 09.04.2014 23:44:02 vasta tsitaadiga
Kuigi ehk enamusele AHV-idest on see ehk iseenesestmõistetav, siis igaks juhuks märgin siin veel, et paroole vahetada on mõtet ikkagi vaid neis veebikeskkondades, kus tegelikult ikka sisselogimisel krüpteeritud ühendust kasutatakse. Kui ühendus käib üle http ja mitte üle https-i (nagu näiteks HV icon_smile.gif ), siis ei ole sel mingit mõtet, sest siin ei ole ühendus krüpteeritud nagunii.
sõnum 09.04.2014 23:45:32 vasta tsitaadiga
Jah aga siin on ainult üks aga...ilma testimata on ilmvõimatu teada saada, kas serveris on openSSL juba patchitud või ei.
Paroolimuutmine ei anna mingit effekti, kui serveri ise plaastrit selga pole saanud.
Vaata kasutaja äripakkumisi
O: Mikrotik cAP AX 072
Kommentaarid: 233 loe/lisa Kasutajad arvavad:  :: 0 :: 0 :: 195
sõnum 10.04.2014 08:20:24 vasta tsitaadiga
Etz kirjutas:
Nii palju annab, et kui keegi on parooli juba välja nuhkinud ja pole kontot veel üle võtnud, siis peab ta seda uuesti nuhkima hakkama, kui kontot üle võtma tahab hakata. Ühesõnaga, pead võimalikult tihti vahetama seda parooli. icon_razz1.gif
Testimiseks on aga olemas Jared Staffordi (jspenguin@jspenguin.org) koostatud skript: https://gist.github.com/sh1n0b1/10100394
sõnum 10.04.2014 09:01:22 vasta tsitaadiga
Dogbert, küllap vist, seega ca 600 parooli ootab mul muutmist... icon_confused.gif
henri17
henri17
sõnum 10.04.2014 09:58:27 vasta tsitaadiga
Natuke mugavam tööriist serveri testimiseks, http://filippo.io/Heartbleed/
Forss
Forss
sõnum 10.04.2014 11:18:16 vasta tsitaadiga
Kas mõni Eesti veebileht on ka tunnistanud turvaauku ja soovitanud paroole vahetada?
Mina olen ainukesena näinud LHV facebookis teadet, kuigi viga neid ei puuduta.
Edit: Väike Googeldus ja paar teadet leidsin veel:
https://www.ria.ee/ria-palub-susteemiadministraatoritel-uuendada-serverite-tarkvara/
http://www.kahvel.ee/30342/ardi-jurgens-zone-ee-platvorm-ei-sisaldanud-heartbleedi-norkust/
Vael
sõnum 10.04.2014 16:06:31 vasta tsitaadiga
Ikka kripeldab see panganduse teema? Pole hetkel aega, et uurida rohkem aga kuidas pangas ID kaardi https saidil kasutamine siis nii kardinaalselt erineb muudest saitidest?
sõnum 11.04.2014 17:14:15 vasta tsitaadiga
Apple pajatab siis samal teemal, ehk on kellelegi sellest kasu:
Heartbleed: Apple says iOS, OSX, and other key web services not affected
Apple has confirmed that iOS, OSX, and other "key" web services were not vulnerable to the Heartbleed bug that has affected numerous popular websites. “Apple takes security very seriously. iOS and OS X never incorporated the vulnerable software and key Web-based services were not affected,” an Apple spokesperson told Re/code.
The statement comes just a few days after the vulnerability was disclosed. Apple did not specify which key web services it's referring to and if any of its properties were indeed hit -- though the wording at least suggest that nothing critical was compromised.
Edasi lingil:
http://www.techspot.com/news/56358-heartbleed-apple-says-ios-osx-and-other-key-web-services-not-affected.html
tomes
sõnum 11.04.2014 19:44:31 vasta tsitaadiga
Vael, nagu juba öeldud, siis antud turvavea tõttu oli võimalik kätte saada serveri privaatvõti. Viimase olemasolul saab esineda serverina, samuti dekrüpteerida kliendilt serverile saadetud andmeid. Kui serverile on turvapaik paigaldatud, genereeritud uus privaatvõti ja sellele vastav sertifikaat, siis on korras, sest sinu privaatvõtit pole kätte saadud. Nimelt genereeritakse ID-kaardi privaatvõtmed kiibi sees, neid sealt "maha lugeda" pole võimalik (just seepärast pole võimalik ka ID-kaarti kopeerida).
number
külaline
sõnum 11.04.2014 23:12:47 vasta tsitaadiga
viimati muutis number 26.06.2014 01:21:29, muudetud 1 kord
Vael
sõnum 11.04.2014 23:37:57 vasta tsitaadiga
tomes kirjutas:
Olgu tänud.
Aga teine küsimus ka veel seonduv. Kasutan vahetevahel Ubuntu 12.04LTS ja serverina seda ei kasuta. Kahtlaseid sertifikaate Security Updates vist pole väga vajadust tõmmata siis?(Descriptionis ka öeldud, et CA poolt kontrollimata...)
hans
Nii ränk on olla.
sõnum 12.04.2014 12:02:25 vasta tsitaadiga
http://imgs.xkcd.com/comics/heartbleed_explanation.png
Kommentaarid: 103 loe/lisa Kasutajad arvavad:  :: 3 :: 0 :: 80
tomes
sõnum 12.04.2014 16:19:31 vasta tsitaadiga
Vael kirjutas:
Kui sa ei tea, mida teed, siis jäta parem tegemata.
sõnum 23.06.2014 21:35:27 vasta tsitaadiga
ZDNet pajatab, et seesama probleem on jätkuvalt püsti:
Heartbleed: Over 300,000 servers still exposed
Summary: Two months after the infamous 'Heartbleed' bug was discovered, over half of vulnerable servers remain unpatched and still exposed.
Edasi lingil:
http://www.zdnet.com/heartbleed-over-300000-servers-still-exposed-7000030813/
