praegune kellaaeg 21.09.2026 08:40:58
12.06.2014 19:14:57
Sony leiutab: Sony Creates Curved CMOS Sensors That Mimic the Eye |
Sony leiutab:
The retinas of humans and other animals line the curved inner surface of the eye. Now, in a bit of zoological mimicry, Sony engineers reports that they have created a set of curved CMOS image sensors using a "bending machine" of their own construction.
The result is a simpler lens system and higher sensitivity, Kazuichiro Itonaga, a device manager with Sony's R&D Platform in Atsugi-shi, Japan reported on Tuesday at the Symposium on VLSI Technology in Honolulu, Hawaii.
A curved CMOS sensor has a few advantages over a planar sensor, Itonaga said. Because of the geometry, it can be paired with a flatter lens and a larger aperture, which lets in more light. Photodiodes at the periphery of a sensor array will be bent toward the center, which means light rays will hit them straight on instead of obliquely. What's more, the strain induced on a CMOS sensor by bending it alters the band gap of the silicon devices in the sensor region, lowering the noise created by "dark current" — the current that flows through a pixel even when it is receiving no external light.
Edasi juba lingil:
http://spectrum.ieee.org/tech-talk/semiconductors/devices/sony-creates-curved-cmos-sensors-that-mimic-the-eye
sa ei või postitada uusi teemasid siia foorumisse sa ei või vastata selle foorumi teemadele sa ei või muuta oma postitusi selles foorumis sa ei või kustutada oma postitusi selles foorumis sa ei või vastata küsitlustele selles foorumis sa ei saa lisada manuseid selles foorumis sa ei või manuseid alla laadida selles foorumis
