praegune kellaaeg 21.09.2026 08:39:07
12.06.2014 19:00:21
Psst. We've got 400Gb/s Ethernet working - but don't tell anyone |
Jälle leiutatakse - aga ärge sellest siis kellelegi rääkige.
Californian company Ixia has shown what it claims is the the world’s first functioning 400Gb/s Higher Speed Ethernet test rig, based on the IEEE P802.3bs protocol. The company says that this bandwidth is sufficient for 50,000 simultaneous high definition Netflix video streams.
The 400GbE Jumpstart Test system provided wire rate packet generation/reception at 400Gb/s and has successfully completed the industry’s first 400GbE interoperability test with Ciena, which makes open, programmable networking platforms and software.
As we previously reported, 400Gb/s is the next step between 100Gb/s and a terabit. The standard is expected to be ratified in Q1 2017.
Edasi juba lingil:
http://www.theregister.co.uk/2014/06/12/400gbs_ethernet/
sa ei või postitada uusi teemasid siia foorumisse sa ei või vastata selle foorumi teemadele sa ei või muuta oma postitusi selles foorumis sa ei või kustutada oma postitusi selles foorumis sa ei või vastata küsitlustele selles foorumis sa ei saa lisada manuseid selles foorumis sa ei või manuseid alla laadida selles foorumis
