praegune kellaaeg 21.09.2026 08:41:08
11.06.2014 09:23:52
Taas siis uus võimalus "häkkimiseks": Smart TVs subverted by radio attack |
Millions of smart TVs can be hijacked by burying attack code in signals broadcast to the net-connected devices, security experts warn.
The attack exploits loopholes in widely used technology that helps smart TVs receive tailored adverts.
Once hijacked, the TVs could be made to send messages on behalf of attackers, find other vulnerable devices in a home or launch other attacks across the net.
Detecting and stopping the attack would be difficult, said the researchers.
The attack uses the Hybrid Broadcast Broadband TV (HbbTV) standard that is widely supported in smart television sets sold in Europe.
The HbbTV system was designed to help broadcasters exploit the internet connection of a smart TV to add extra information to programmes or so advertisers can do a better job of targeting viewers.
But Yossef Oren and Angelos Keromytis, from the Network Security Lab, at Columbia University, have found a way to hijack HbbTV using a cheap antenna and carefully crafted broadcast messages.
"For this attack you do not need an internet address, you do not need a server," Mr Oren told Forbes. "You just need a roof and an antenna and once you are done with your attack, there's completely no trace of you."
Edasi lingil:
http://www.bbc.com/news/technology-27761756
K3ndu
11.06.2014 09:49:33
| S4'ja infapunaga saab ka peaaegu igat telekat "häkkida"
sa ei või postitada uusi teemasid siia foorumisse sa ei või vastata selle foorumi teemadele sa ei või muuta oma postitusi selles foorumis sa ei või kustutada oma postitusi selles foorumis sa ei või vastata küsitlustele selles foorumis sa ei saa lisada manuseid selles foorumis sa ei või manuseid alla laadida selles foorumis
