praegune kellaaeg 16.11.2026 07:48:43
31.05.2014 10:10:38
Uus rekordkatsetus WiFi-maailmas: Huawei Successfully Tests Next Generation 10Gbps Wi-Fi |
Uus rekordkatsetus WiFi-maailmas: Ning eks siis aastal 2018 ole näha, kas jõuab kommertskasutusse.
[Shenzhen, China, May 29, 2014]: Huawei, a leading global information and communications technology (ICT) solutions provider, today announced that it has successfully achieved the industry’s first 10Gbps Wi-Fi service in laboratory trials at Huawei’s campus in Shenzhen. This important milestone, which delivered data over Wi-Fi 10 times faster than the fastest existing Wi-Fi capability commercially available today, will enable a new era of big data applications by using ultra-fast Wi-Fi technology based on advanced next generation architecture to boost data rates to 10Gbps.
The 10Gbps Wi-Fi prototype achieved a record transmission data rate of 10.53Gbps on 5GHz frequency bands. The success of this prototype development, and the ten folds increase in spectrum efficiency that made it possible, paves the way for the validation of technologies needed to support the creation of next generation Wi-Fi. Huawei believes that ultrafast Wi-Fi could become commercially available from 2018 pending the agreement of global standards requirements and sufficient chipset availability.
Edasi lingil:
http://www.huawei.com/ilink/en/about-huawei/newsroom/press-release/HW_341651
Üks kena pilt mis siis selle kavatsetava MIMO OFDM system-i lahti selgitab. Lühidalt öelduna see süsteem vajab siis hästi palju saatjaid ja vastuvõtjaid oma edukaks töötamiseks.
MIMO OFDM system
http://www.freepatentsonline.com/7068628.html
sa ei või postitada uusi teemasid siia foorumisse sa ei või vastata selle foorumi teemadele sa ei või muuta oma postitusi selles foorumis sa ei või kustutada oma postitusi selles foorumis sa ei või vastata küsitlustele selles foorumis sa ei saa lisada manuseid selles foorumis sa ei või manuseid alla laadida selles foorumis
