praegune kellaaeg 21.09.2026 07:49:41
30.05.2014 11:26:37
Androidil taas turvaprobleem: Adware comes to the World Cup 2014 through Android app |
We are not far off from the proverbial kickoff of the 2014 World Cup. The tournament takes place this year in the South American nation of Brazil, beginning in June. With a major sporting event comes web sites and apps, letting folks follow all of the action. However, in some cases, not all is what it seems.
Avast researchers uncovered an app that, while not actually dangerous, is designed to feed you only ads. "Some of the Android gaming apps we downloaded primarily displayed ads instead of letting us play. Let me just point out a few from many. We were unable to play Corner Kick World Cup 2014 at all because it displayed nothing but a white screen, with ads popping up now and then", says Flip Chytry.
There are immediate warning signs -- the app is less than one MB in size. It also does absolutely nothing. You will be opening a plain white screen that does nothing but display pop-up ads.
Edasi lingil:
http://betanews.com/2014/05/29/adware-comes-to-the-world-cup-2014-through-android-app/
sa ei või postitada uusi teemasid siia foorumisse sa ei või vastata selle foorumi teemadele sa ei või muuta oma postitusi selles foorumis sa ei või kustutada oma postitusi selles foorumis sa ei või vastata küsitlustele selles foorumis sa ei saa lisada manuseid selles foorumis sa ei või manuseid alla laadida selles foorumis
