praegune kellaaeg 21.09.2026 07:49:38
29.05.2014 09:15:25
Kas internetti ka kosmoseränduritele: Wireless broadband can reach the moon, and maybe Mars |
PS: Sellisest katsetusest oli ka kunagi varem juttu, nüüd pajatatakse sellest pikemalt.
Aside from air, water and fresh vegetables, what would you need to survive on the moon? One thing that would likely feature high on the list is a decent, reliable wireless internet. And thanks to a group of researches from MIT and Nasa this kind of connectivity could be within the realms of possibility.
Between them, the two organisations have demonstrated for the first time that data communication technology is capable of providing those in space with the same kind of connectivity we enjoy on Earth, and can even facilitate large data transfers and high-definition video streaming.
To do this it uses four separate telescopes based at a ground terminal in New Mexico to send the uplink signal to the moon. A laser transmitter that can send information as coded pulses of invisible infrared light feeds into each of the telescopes, which results in 40 watts of transmitter power.
Nasa and MIT will present their findings at the CLEO laser technology conference in California on 9 June, but the findings have also been detailed by the Optical Society. The team will explain how their laser-powered communication uplink between the moon and Earth breaks previous record transmission speeds -- achieved by RF signals -- by a factor of 4,800.
The team has transmitted data across the 384,633km distance between Earth and the moon at a rate of 19.44mbps and has also managed to download data at a rate of 622mbps. "Communicating at high data rates from Earth to the moon with laser beams is challenging because of the 400,000-kilometre distance spreading out the light beam," says Mark Stevens of MIT Lincoln Laboratory. "It's doubly difficult going through the atmosphere, because turbulence can bend light-causing rapid fading or dropouts of the signal at the receiver."
Each of the four telescopes used to beam the connection to the moon transmits light through a different column of air, meaning that they all experience different bending effects from the atmosphere and increasing the chance that one of them will hit the receiver, which is hitched to a satellite currently orbiting the moon. The satellite is also equipped with a telescope, which collects the laser beam and focuses it into an optical fibre. A photodetector turns the pulses of light into electrical pulses, and from there they are converted into data.
http://www.wired.co.uk/news/archive/2014-05/23/internet-on-the-moon
Veel üks link lisaks ja siin siis inglased juba "kurdavad"...
Congratulations broadband providers, even the moon has faster connectivity than the UK
Thanks to work carried out by MIT and NASA, the moon now has faster broadband than some parts of the UK, after registering speeds of just under 20mbps.
According to Wired, the Earth's satellite is now able to receive large amounts of data, with video and audio streaming possible as a result of new, record-breaking broadband transmission speeds.
Read more:
http://www.itproportal.com/2014/05/28/congratulations-uk-broadband-providers-even-the-moon-has-faster-connectivity-than-us/#ixzz335BMnNJA
sa ei või postitada uusi teemasid siia foorumisse sa ei või vastata selle foorumi teemadele sa ei või muuta oma postitusi selles foorumis sa ei või kustutada oma postitusi selles foorumis sa ei või vastata küsitlustele selles foorumis sa ei saa lisada manuseid selles foorumis sa ei või manuseid alla laadida selles foorumis
