praegune kellaaeg 21.09.2026 07:49:09
28.05.2014 12:13:08
BGR kirjutab: How to guarantee your Android phone isn’t spying on you |
BGR kirjutab:
Last week, a developer revealed to the world just how easy it is for a nefarious hacker to use your Android phone to spy on you. With some simplecode that utilized a serious security hole, the developer was able to create a program that caused an Android handset’s camera to covertly capture photos on command, and then transmit those photos to a remote server without the user ever knowing.
The idea that your smartphone might be taking photos of you and sending them to a hacker without your knowledge is absolutely terrifying. But as it turns out, there’s an app that can guarantee your phone isn’t spying on you.
Edasi lingil:
http://bgr.com/2014/05/27/android-spy-apps-blocking-office-anti-spy/
sa ei või postitada uusi teemasid siia foorumisse sa ei või vastata selle foorumi teemadele sa ei või muuta oma postitusi selles foorumis sa ei või kustutada oma postitusi selles foorumis sa ei või vastata küsitlustele selles foorumis sa ei saa lisada manuseid selles foorumis sa ei või manuseid alla laadida selles foorumis
