praegune kellaaeg 21.09.2026 07:05:19
23.05.2014 08:46:33
Netist silma jäänud: Start-Up Demos Touchscreen-Anywhere System |
Metaio's Thermal Touch technology could be embedded in, say, a future generation of Google Glass, an Oculus virtual reality headset, or even in a smartphone. The interface provides a way to interact with real-world surfaces, such as viewing a virtual chess board on a table and then, through Thermal Touch, "moving" a virtual chess piece.
Forget dedicated touchscreens. A start-up called Metaio is now demonstrating an augmented-reality system that essentially turns any surface into a touchscreen.
The system utilizes regular and infrared cameras to detect heat left behind by touching a surface -- virtually any surface -- and integrating that with augmented reality to create a touch-sensitive surface.
This Thermal Touch interface provides a way for augmented reality users to interact with real-world surfaces, such as viewing a virtual chess board on a table and then, through Thermal Touch, actually reaching out and "moving" a virtual chess piece with your hand.
Kogu jutt siis lingil:
http://www.toptechnews.com/story.xhtml?story_id=11200B0K44U8
sa ei või postitada uusi teemasid siia foorumisse sa ei või vastata selle foorumi teemadele sa ei või muuta oma postitusi selles foorumis sa ei või kustutada oma postitusi selles foorumis sa ei või vastata küsitlustele selles foorumis sa ei saa lisada manuseid selles foorumis sa ei või manuseid alla laadida selles foorumis
