praegune kellaaeg 08.11.2026 11:44:46
21.05.2014 22:03:42
SATA Express võidujooks jätkub: Marvell Announces New PCIe SSD Controller Supporting SATA Express |
Marvell today announced the launch of its new 88SS1083 PCI Express (PCIe) solid state drive (SSD) controller -a two-lane PCIe Gen2 SSD controller. With performance transfer rates up to 1 GB/s, Marvell's 88SS1083 controller allows SSD manufacturers to offer PCIe SSD at price parity to SATA SSD. The Marvell 88SS1083 is the industry's first controller to be fully compliant with the SATA Express standard, which leverages the most popular PCIe interface and brings in low latency, dual-lane support and 1 GB/s data transfer rate.
The new 88SS1083 controller also supports Separate RefClock with Independent SSC (SRIS), a critical feature as it eliminates the need for an expensive shielded cable for minimizing noise and instead allows for a cost-effective SATA Express cable. SATA Express host can connect either high-performance SATA Express SSDs or traditional SATA devices at similar accessory costs.
"Improving performance while maintaining low power becomes more important than ever, especially for today's ultrathin notebooks and tablets," said Rajan Pai, Vice President, Sales and Field Applications Engineering at Marvell. "The new 88SS1083 allows SSD OEMs to offer higher performance, PCIe-based SSD solutions at similar prices to SATA and is quickly becoming the controller of choice for global OEMs. Marvell is proudly pioneering a new generation of high-performance and low-power silicon solutions that is driving our industry forward."
Edasi lingil:
http://www.techpowerup.com/201051/marvell-announces-new-pcie-ssd-controller-supporting-sata-express.html
Teine link sama teema kohta:
Marvell Announces PCIe SSD Controller 88SS1083 Supporting SATA Express
http://www.thessdreview.com/daily-news/latest-buzz/marvell-announces-pcie-ssd-controller-88ss1083-supporting-sata-express/
sa ei või postitada uusi teemasid siia foorumisse sa ei või vastata selle foorumi teemadele sa ei või muuta oma postitusi selles foorumis sa ei või kustutada oma postitusi selles foorumis sa ei või vastata küsitlustele selles foorumis sa ei saa lisada manuseid selles foorumis sa ei või manuseid alla laadida selles foorumis
