praegune kellaaeg 21.09.2026 07:05:15
20.05.2014 11:34:11
Salvestus lindile ei taha veel mitte välja surra: IBM, Fujifilm squeeze more terabytes out of tape storage |
Summary: IBM's advance means a standard tape cartridge could store 154 terabytes of uncompressed data.
IBM said Monday that its researchers have advanced the amount of bits stored per square inch of tape storage courtesy of a prototype material from Fujifilm Corp.
The news, which comes out of IBM's Edge conference in Las Vegas, illustrates how older technologies can have a longer lifespan due to advances.
Inexpensive tape storage is a primary backup system for many enterprises even as they adopt big data and new technologies in the data center.
IBM said they can pack 85.9 billion bits of data per square inch on areal data density on linear magnetic particulate tape. At that density a standard tape cartridge could store 154 terabytes of uncompressed data, 62 times better than existing cartridges.
With the advance, IBM is keeping tape relevant for big data applications. Tape still has appeal given that it can last for decades and doesn't require power when not in use.
To boost the data on tape storage, IBM researchers tweaked the particles on the write field head and used algorithms to refine how tape stores data. IBM's first commercial tape product was announced more than 60 years ago.
Edasi lingil:
http://www.zdnet.com/ibm-fujifilm-squeeze-more-terabytes-out-of-tape-storage-7000029624/
sa ei või postitada uusi teemasid siia foorumisse sa ei või vastata selle foorumi teemadele sa ei või muuta oma postitusi selles foorumis sa ei või kustutada oma postitusi selles foorumis sa ei või vastata küsitlustele selles foorumis sa ei saa lisada manuseid selles foorumis sa ei või manuseid alla laadida selles foorumis
