praegune kellaaeg 21.09.2026 07:04:56
19.05.2014 12:40:02
Taas kirjutatakse Fusion reaktoritest: Almost Free Fusion Power by 2020 If You Donate a Few Bucks Now |
Fossil fuels are drying up, solar-capturing technology isn't advancing quickly enough and batteries just aren't cutting it. Fusion power was seen as even more remote than geothermal and effective solar power harnessing, but this might no longer be the case.
In fact, you can contribute a few dollars and be among the ones responsible for the enabling of commercial fusion power by the end of this decade.
You see, a crowd-funding campaign has appeared on Indiegogo, set up by a group of researchers from LPP Fusion, based in New Jersey.
The campaign says that it only needs to reach its funding goal of $200,000 / €145,000 in order to start making fusion reactors by 2020.
Fusion reactors which will each cost $500,000 / €290,000, curiously enough, much less than nuclear reactors.
The fusion reactors would also be a lot smaller, capable of fitting inside a garage or shipping container while producing 5 MW (megawatts) for 0.06 cents per kWh.
Edasi juba lingil:
http://news.softpedia.com/news/Almost-Free-Fusion-Power-by-2020-If-You-Donate-a-Few-Bucks-Now-442793.shtml
sa ei või postitada uusi teemasid siia foorumisse sa ei või vastata selle foorumi teemadele sa ei või muuta oma postitusi selles foorumis sa ei või kustutada oma postitusi selles foorumis sa ei või vastata küsitlustele selles foorumis sa ei saa lisada manuseid selles foorumis sa ei või manuseid alla laadida selles foorumis
